Agilent 81623A 探头
![](http://www.cechina.cn/UpLoad/CompanyFile/2014/1/13/f826f608-8052-42cf-a174-5b5e23716000.jpg)
81623A Ge, +10dBm至-80dBm, 750至1800纳米
5mm Diameter
=波长范围:750至1800纳米
=探测器类型(传感元件):Germanium
=探测器尺寸(直径):5毫米
=功率范围:+10到-80 dBm的
=波长精度(不确定性):+ / - 3.5%(1000至1650 纳米)
The analog output is the BNC connector on the back of the
optical head. It outputs a voltage directly proportional to the
strength of the optical signal at the optical input in the current
range. The analog signal is always in the range between 0 and
2V, 2V corresponding to a full power input signal in the current
range, 0V corresponding to no input signal.
During autoranging, the level to which 2V corresponds changes.
You should disable autoranging when using the analog output.
Disabling Autoranging
Applications
Possible applications for the analog output are:
? to close the feedback loop controlling the current supplied to
a laser
? to aid positioning the system for fiber alig纳米ent tasks
? to monitor optical power on an oscilloscope
The analog signal reacts instantaneously to the input signal,
whereas the power shown on the display is subject to averaging.
库存相关测试仪
可调激光源:AGILENT 81940A AGILENT 81949A AGILENT 81950A AGILENT 91980A AGILENT 81989A HP 8167B HP 8168F HP 8168E
AGILENT 81689A AGILENT 81480A/B AGILENT 81682A/B AGILENT81680A/B AGILENT 81640A/B 81642A AGILENT 81600B AQ4321A/D AQ4320D TSL-510
光谱仪:7004A/70950B 86142A/B 86140A/B 86141B 86143B 86145B 86142B MS9710A/B/C MS9740A MS9780A AQ6315E AQ6317B/C AQ6370B/C AQ6330 AQ6331 AQ6375 AQ6373 AQ6319 Q8381 Q8383 Q8384 Q8347 Q8344A
光示波器/眼图仪:86100A/B/C/D 86105A/B/C 86103A 83481A 83482A 83483A 83485A/B 83487A 86116C 54754A 86112A 86117A/B 86118A 86108A 83446A
光功率主机:8153A 8163A/B 8164A/B 1830-C 1830-R 1835-C 1936-C 1918-C 2936-C
光源模块:81551SM 81552SM 81553SM 81554SM 81650A 81651A 81652A 81653A 81654A 81655A 81656A 81657A 81663A
光功率模块:81531A 81532A 81533A 81533B 81618A 81619A 81536A 81632A/B 81633A 81634A/B 81635A 81636B
光功率探头:81521B 81525A 81524A 81623A/B 81624A/B 81625A/B 81626B 81628A/B
回损仪RM3750B RM3070B RX30701 RM3050 PS3650B ORL-55 IQ-3200 FOT-300 HP81534A 81610A 81611A 81612A 81613A 81614A
波长计:86120B/C 81622A AQ6140 TQ8325 Q8326 WA-1100 WA-1500 WA-1600 WA-1650 WA-7100 WA-7600 FTB5320
衰减器:8157A 8156A 8158B HA9 FVA-60B MN9610B
宽谱光源HP83437A 83438A
误码分析仪86130A 37717A/B/C 37718A/B/C N4903A N4906A
![](http://www.itestworld.com/uploads/braner/wxh.png)
