Agilent 81002FF 积分球
![](http://www.cechina.cn/UpLoad/CompanyFile/2014/1/13/d0fa1a71-40aa-48e7-b895-95e19f3e93b8.JPG)
81002FF积分球 - 球有一个外径80毫米,并具有高度扩散内衬材料。积分球的一个基本思想是光线进入的领域,是散布在室内表面均匀功率密度。在总功率小部分退出该领域,通过一个小的光圈在光学头检测器。球体是用于多种应用程序:
高功率 - 创建了一个球约41 dB的衰减,具有最大功率40 dBm的规范+(10瓦),提供最高的功率处理能力可用。球的大小允许这个高功率是很容易扩散和消散。注:球可以建一个稍微大口径的光学头,减少到大约31 dB的衰减。较大的光圈,这是特殊的选项可用#500。
大光束直径/大数值孔径 - 球体的大尺寸,使一个很大的光功率“目标”,允许它从一个测量点源不适用了0.5和9毫米到一个开放的光束。该发射装置或光纤到球体对齐非关键
The Agilent 81002 FF Integrating Sphere is an accessory for the
Agilent 8163A Lightwave Multimeter, Agilent 8163A Lightwave
Measurement System, Agilent 8166A Lightwave Multichannel System,
and the HP 8153A Lightwave Multimeter. It can be used with all Agilent
Technology Optical Heads and all HP Optical Heads.
The Integrating Sphere is compatible with all connector adapters and
bare fiber adapters Agilent 81000xx, which can be used with these
optical heads.
Connections to the Agilent 81002 FF Integrating Sphere
The Agilent 81002 FF Integrating Sphere has three main advantages, it
allows measurements with:
? high optical power levels,
? large emission sources, either widely diverging point sources (high
numerical aperture (NA)) or light sources with large beam diameters,
? polarized optical sources; it scrambles the input polarization.
The Agilent 81002 FF Integrating Sphere allows the measurement of high
optical power levels up to 10 W (+40 dBm) due to its typical optical
attenuation of 40 dB. The optical loss of the integrating sphere shifts the
dynamic range of a connected optical head by +40 dB to higher power
levels.
库存相关测试仪
可调激光源:AGILENT 81940A AGILENT 81949A AGILENT 81950A AGILENT 91980A AGILENT 81989A HP 8167B HP 8168F HP 8168E
AGILENT 81689A AGILENT 81480A/B AGILENT 81682A/B AGILENT81680A/B AGILENT 81640A/B 81642A AGILENT 81600B AQ4321A/D AQ4320D TSL-510
光谱仪:7004A/70950B 86142A/B 86140A/B 86141B 86143B 86145B 86142B MS9710A/B/C MS9740A MS9780A AQ6315E AQ6317B/C AQ6370B/C AQ6330 AQ6331 AQ6375 AQ6373 AQ6319 Q8381 Q8383 Q8384 Q8347 Q8344A
光示波器/眼图仪:86100A/B/C/D 86105A/B/C 86103A 83481A 83482A 83483A 83485A/B 83487A 86116C 54754A 86112A 86117A/B 86118A 86108A 83446A
光功率主机:8153A 8163A/B 8164A/B 1830-C 1830-R 1835-C 1936-C 1918-C 2936-C
光源模块:81551SM 81552SM 81553SM 81554SM 81650A 81651A 81652A 81653A 81654A 81655A 81656A 81657A 81663A
光功率模块:81531A 81532A 81533A 81533B 81618A 81619A 81536A 81632A/B 81633A 81634A/B 81635A 81636B
光功率探头:81521B 81525A 81524A 81623A/B 81624A/B 81625A/B 81626B 81628A/B
回损仪RM3750B RM3070B RX30701 RM3050 PS3650B ORL-55 IQ-3200 FOT-300 HP81534A 81610A 81611A 81612A 81613A 81614A
波长计:86120B/C 81622A AQ6140 TQ8325 Q8326 WA-1100 WA-1500 WA-1600 WA-1650 WA-7100 WA-7600 FTB5320
衰减器:8157A 8156A 8158B HA9 FVA-60B MN9610B
宽谱光源HP83437A 83438A
误码分析仪86130A 37717A/B/C 37718A/B/C N4903A N4906A
![](http://www.itestworld.com/uploads/braner/wxh.png)
