Agilent安捷伦81525A光功率计探头
![](http://www.cechina.cn/UpLoad/CompanyFile/2014/1/13/0a9f30d1-cbef-4080-b430-1377a5c8b4a8.jpg)
Agilent安捷伦81525A光功率计探头光万用表
81525A是一种高功率InGaAs光学头。规格:5MM。 27-70 dBm.800到1650 nm。它是用在:HP8163A,HP8164A,HP8153A | | |
Agilent 81525A 大功率 InGaAs 光学探头,5 毫米
详细资料:
81525A|Agilent 81525A|HP 81525A
Specifications at a glance for the 81525A:
Wavelength Range: 800 to 1650 nm
Detector Type (Sensor Element): InGaAs
Detector Size (diameter): 5 mm
Power Range: -70 to +23 dBm (800 - 1650 nm)
Wavelength Accuracy (Uncertainty): +/- 3.0% (900 to 1600 nm)
Additional Information
主要特性与技术指标
The Agilent optical power heads are specially designed for low PDL, low spectral ripple and high return loss and are used for optical component test. The heads come with a magnetic D-shape adapter and provide a safe stand.
Applicable Fiber Type: Standard Single-mode And Multimode max. 100 um core size, NA < 0.3
Linearity: -50 to +10 dBm
Connector Type Options:
81000FA: FC/PC connector adapter
81000KA: SC/PC connector adapter
81000PA: E-2000 connector adapter
81000VA: ST/PC connector adapter
81003LA : LC/PC connector adapter
The 81525A is a high power InGaAs optical head. Specs: 5mm. +27 to -70 dBm.800 to 1650 nm. It is used with: HP8163A, HP8164A, HP8153A.
库存相关测试仪
可调激光源:AGILENT 81940A AGILENT 81949A AGILENT 81950A AGILENT 91980A AGILENT 81989A HP 8167B HP 8168F HP 8168E
AGILENT 81689A AGILENT 81480A/B AGILENT 81682A/B AGILENT81680A/B AGILENT 81640A/B 81642A AGILENT 81600B AQ4321A/D AQ4320D TSL-510
光谱仪:7004A/70950B 86142A/B 86140A/B 86141B 86143B 86145B 86142B MS9710A/B/C MS9740A MS9780A AQ6315E AQ6317B/C AQ6370B/C AQ6330 AQ6331 AQ6375 AQ6373 AQ6319 Q8381 Q8383 Q8384 Q8347 Q8344A
光示波器/眼图仪:86100A/B/C/D 86105A/B/C 86103A 83481A 83482A 83483A 83485A/B 83487A 86116C 54754A 86112A 86117A/B 86118A 86108A 83446A
光功率主机:8153A 8163A/B 8164A/B 1830-C 1830-R 1835-C 1936-C 1918-C 2936-C
光源模块:81551SM 81552SM 81553SM 81554SM 81650A 81651A 81652A 81653A 81654A 81655A 81656A 81657A 81663A
光功率模块:81531A 81532A 81533A 81533B 81618A 81619A 81536A 81632A/B 81633A 81634A/B 81635A 81636B
光功率探头:81521B 81525A 81524A 81623A/B 81624A/B 81625A/B 81626B 81628A/B
回损仪RM3750B RM3070B RX30701 RM3050 PS3650B ORL-55 IQ-3200 FOT-300 HP81534A 81610A 81611A 81612A 81613A 81614A
波长计:86120B/C 81622A AQ6140 TQ8325 Q8326 WA-1100 WA-1500 WA-1600 WA-1650 WA-7100 WA-7600 FTB5320
衰减器:8157A 8156A 8158B HA9 FVA-60B MN9610B
宽谱光源HP83437A 83438A
误码分析仪86130A 37717A/B/C 37718A/B/C N4903A N4906A
![](http://www.itestworld.com/uploads/braner/wxh.png)
