SMR60罗德与施瓦茨R&S?SSMR60?數位示波器
支援頻寬 200MHz / 350MHz / 500MHz / 1GHz同級產品中 最佳性能表現,為各式日常量測任務的最佳首選!< 1ps 的觸發抖動5G 取樣率 / 50M 記憶深度 (max.)每秒 1 百萬次訊號捕獲率即時完整之 FFT 量測:游標顯示、遮罩測試、自動峰值追蹤R&S SSMR60 數位示波器
The R&S SSMR60/60 are CW generators with pulse modulation capability and a lower limit frequency of 1 GHz.They cover the range up to 50 GHz (SSMR60) and 60 GHz (SMR60).The lower limit can be expanded to 10 MHz by the Frequency Extension 0.01 GHz to 1 GHz (option ?SMR-B11).Owing to their excellent price/performance ratio the two models are ideal for economical microwave test setups up to 60 GHz.
Should the measurement tasks become more demanding, both models can be upgraded any time by means of options to give an AM/FM signal generator or a synthesized sweep generator featuring fast, fully synthesized, analog ramp sweep.The SSMR60/60 stand out from other generators for their excellent spectral purity. Advanced frequency synthesis makes for low SSB phase noise and high spurious suppression, both of which are for example prerequisites for reliable receiver measurements.Special microwave filters in the output path of the instrument ensure excellent harmonics suppression.
This is necessary to obtain unequivocal results in scalar network analysis measurements. Microwave signal generators are frequently used for calibrating test receivers. This task calls for a highly accurate and stable output level settable with high resolution.This is ensured by a high-precision, frequency-response-compensated level control. A minimum level of –20 dBm can be set. This range can be extended to –110 dB with the optional RF Attenuator SMR-B18.CW generator with pulse modulation and digital frequency sweepHigh output level >+3 dBm (at 50 GHz)Fast quasi-analog ramp sweep
Level sweep with a minimum step time of 1 msEasily upgradeable to AM/FM signal generator and synthesized sweep generator with analog ramp sweep owing to flexible options conceptOptional pulse generator for radar and EMC applicationsCompact, lightweight, user-friendly –ideal in the lab and for field applications
联系人:黄文俊
地址:深圳市龙华新区人民南路莱蒙水榭春天7栋凤凰苑24C/24D
邮编:518131
电话:13928415151
传真:0755-83176509
公司网址:http://www.itestworld.com
