深圳市东测科技有限公司
  • SMR50罗德与施瓦茨R&S SMR50 數位示波器?
  • 发布时间:2014/5/22 21:43:59   修改时间:2014/5/22 21:43:59 浏览次数:713
    支援頻寬 200MHz / 350MHz / 500MHz / 1GHz同級產品中 最佳性能表現,為各式日常量測任務的最佳首選!< 1ps 的觸發抖動5G 取樣率 / 50M 記憶深度 (max.)每秒 1 百萬次訊號捕獲率即時完整之 FFT 量測:游標顯示、遮罩測試、自動峰值追蹤R&S SMR50 數位示波器
    The R&S SMR50/60 are CW generators with pulse modulation capability and a lower limit frequency of 1 GHz.They cover the range up to 50 GHz (SMR50) and 60 GHz (SMR60).The lower limit can be expanded to 10 MHz by the Frequency Extension 0.01 GHz to 1 GHz (option ?SMR-B11).Owing to their excellent price/performance ratio the two models are ideal for economical microwave test setups up to 60 GHz.
    Should the measurement tasks become more demanding, both models can be upgraded any time by means of options to give an AM/FM signal generator or a synthesized sweep generator featuring fast, fully synthesized, analog ramp sweep.The SMR50/60 stand out from other generators for their excellent spectral purity. Advanced frequency synthesis makes for low SSB phase noise and high spurious suppression, both of which are for example prerequisites for reliable receiver measurements.Special microwave filters in the output path of the instrument ensure excellent harmonics suppression.
    This is necessary to obtain unequivocal results in scalar network analysis measurements. Microwave signal generators are frequently used for calibrating test receivers. This task calls for a highly accurate and stable output level settable with high resolution.This is ensured by a high-precision, frequency-response-compensated level control. A minimum level of –20 dBm can be set. This range can be extended to –110 dB with the optional RF Attenuator SMR-B18.CW generator with pulse modulation and digital frequency sweep
    High output level >+3 dBm (at 50 GHz)Fast quasi-analog ramp sweepLevel sweep with a minimum step time of 1 msEasily upgradeable to AM/FM signal generator and synthesized sweep generator with analog ramp sweep owing to flexible options conceptOptional pulse generator for radar and EMC applicationsCompact, lightweight, user-friendly –ideal in the lab and for field applications
深圳市东测科技有限公司公司现货销售、租赁惠普(安捷伦)、泰克、安立、爱得万、横河、安腾、力科、马可尼(IFR)、R&S、Exfo等品牌之眼图仪、光谱分析仪、光时域反射仪(OTDR)、可调激光源、光功率计、光衰减器、光纤熔接机等光纤通信仪…  更多>>
深圳市东测科技有限公司
联系人:黄文俊
地址:深圳市龙华新区人民南路莱蒙水榭春天7栋凤凰苑24C/24D
邮编:518131
电话:13928415151
传真:0755-83176509
公司网址:http://www.itestworld.com
  • 陈苗 在2024/9/22 13:42:00留言
  • 详细留言:您好 请添加我 的微信 twenty626
  • 韩女士 在2022/11/24 10:01:00留言
  • 详细留言:KLA Thermawave OP2600,KLA Tencor 5200XP,KLA 6420,KLA 2315。想了解报价和产品规格说明书。
  • 张鸿益 在2022/4/29 14:07:00留言
  • 详细留言:請與我聯繫。謝謝
  • 汪丽 在2021/12/13 10:48:00留言
  • 详细留言:需求CI-T120 管脚检查机
