ATS-1AUDIO PRECISION?ATS-1
ATS-1 analyzers bring bench-quality, high-precision test and measurement to maintenance, engineering and production facilities. Whether in broadcast, communications, bench or production use, the ATS-1 offers a complete, easy-to-use audio test set housed in a rugged metal case that’s ready for almost anything.ATS-1 provides comprehensive two-channel analog and digital generation and measurement. With twelve different measurement functions selectable at the push of a button, they are comprehensive while remaining user-friendly. Easy-to-set-up sweep capability produces graphs of frequency response, distortion vs. frequency and even amplitude sweeps. Non-volatile storage of up to 30 tests allows easy, one-button recall of your favorite test setup.
ndependent analog and digital signal generatorsDigital interface analysisHP8903 emulation modeA wide range of analog and digital test signalsProgrammatic control for high-speed automation (GPIB)A full complement of graphing and reporting optionsModel OptionsATS-1AATS-1 Access Audio Test System with IEEE-488 GPIB interfaceATS-1DDATS-1 Dual Domain (digital and analog) Audio Test System with IEEE-488 GPIB interface. 48kHz digital audio.
GENERATOR PERFORMANCESine Frequency Range10 Hz–120 kHz.Frequency Accuracy±0.5%IMD Test SignalsSMPTE, DINMaximum Amplitude (balanced)24.7 VrmsAmplitude Accuracy±0.3 dBFlatness (20 Hz–20 kHz)±0.05 dBResidual THD+N, 1 kHz-92 dB + 3 μVAnalog Output Configurations unbalanced & balancedDigital Output Sampling Rate 28.8 kHz to 52.8 kHzEncoded audio formats
NoneANALYZER PERFORMANCEMaximum Rated Input Voltage140 VrmsMaximum Bandwidth<10 Hz to 200 kHzAmplitude Accuracy (1 kHz)±0.1 dB +100 μVAmplitude Flatness (20 Hz–20 kHz)±0.02 dBResidual Input Noise (20 kHz BW)1.5 μVrmsResidual THD+N (20 kHz BW)–92 dB + 3 μVFFT ResolutionN/AIMD Measurement CapabilitySMPTE, DINDC Voltage Measurement N/A
联系人:黄文俊
地址:深圳市龙华新区人民南路莱蒙水榭春天7栋凤凰苑24C/24D
邮编:518131
电话:13928415151
传真:0755-83176509
公司网址:http://www.itestworld.com
