深圳市东测科技有限公司
  • CRT-400Albert CRT-400 分析表?
  • 发布时间:2014/5/22 21:49:38   修改时间:2014/5/22 21:49:38 浏览次数:1034
    The CRT-400, Alber's handheld Cellcorder utilizes the well-proven and patented DC Resistance Test to eliminate the guesswork when trying to identify a failing battery. ● Designed specifically to comply with IEEE Recommended Practices for Battery Maintenance and Testing ● DC Resistance Test proactively identifies failing batteries. ● Designed for use in all industries.
    What's New in the CRT-400 The Cellcorder CRT-400 is Alber's newest handheld cell voltage and resistance tester. This exciting addition to Alber's test, diagnostic and trending products measures and records cell float voltage, internal cell resistance, and intercell connection resistance.
    Another exciting feature is a new USB port and Flash drive that allows quick transfer of data files to a computer. Using the Alber Battery Analysis Software, test results can be displayed and analyzed to determine battery state of health. The Flash drive also doubles as an interim storage device until test data is saved permanently. Other features include a graphical reflective LCD display for better contrast, and new cables and clamps.
    Accurate Data in a Fraction of Normal Test Time The Cellcorder cell resistance tester displays and records cell float voltage, internal cell resistance, and intercell connection resistance. A compatible hydrometer lets you transfer specific gravity and temperature data using the IR port. Use the Cellcorder on a single cell or multicell modules. The Flash drive allows virtually unlimited data storage. Use the Flash drive or IR port to transfer readings to a PC for analysis and report generation. The high contrast, 128 x 64 pixel, backlit graphical display shows menus and test results. A fully charged Cellcorder can test for seven hours, and isolated operation helps ensure safety and makes the Cellcorder easy to move around.
    Cellcorder Advantages Low Cost - The Alber Cellcorder replaces three instruments that individually cost more than this one. Significant savings also result from taking more readings in less time and analyzing data faster. Multicell Capability - The Cellcorder reads either single cells or multicell modules. Reliable Readings - The Cellcorder performs even in high noise environments - without the need to disconnect the battery from service. Up to a 60 amp DC load (on 2V cells) is used to calculate internal cell resistance and intercell resistance. Circuitry rejects the 50Hz/60Hz ripple often troublesome to AC-based impedance and conductance meters. The Cellcorder CRT-400 comes with a 256M Flash drive, resistance and voltage test leads, carrying case, AC charger, and data trending and analysis software. An optional printer is available. The Bluetooth? word mark and logos are registered trademarks owned by Bluetooth SIG, Inc and any use of such marks by Alber is under license. Other trademarks and trade names are those of their respective ownersSystem Features Float Voltage Readings - The Cellcorder measures the voltage applied during full float operation. The voltage range covers all cells or modules up to 20 volts, with accuracy to four full digits. Internal Cell Resistance - Using a patented process, the Cellcorder applies a momentary load and calculates internal cell resistance by determining instantaneous voltage drop and load current. Algorithms make this measurement possible on cells floating on-line or off-line. Intercell Resistance - The Cellcorder measures the resistance between two electrically connected cell terminals. The measurement consists of connector resistance and contact resistance at the points of connection to the cell terminals. Auto Ranging - The Cellcorder automatically selects the correct voltage range, load resistor, and test time.
深圳市东测科技有限公司公司现货销售、租赁惠普(安捷伦)、泰克、安立、爱得万、横河、安腾、力科、马可尼(IFR)、R&S、Exfo等品牌之眼图仪、光谱分析仪、光时域反射仪(OTDR)、可调激光源、光功率计、光衰减器、光纤熔接机等光纤通信仪…  更多>>
深圳市东测科技有限公司
联系人:黄文俊
地址:深圳市龙华新区人民南路莱蒙水榭春天7栋凤凰苑24C/24D
邮编:518131
电话:13928415151
传真:0755-83176509
公司网址:http://www.itestworld.com
  • 陈苗 在2024/9/22 13:42:00留言
  • 详细留言:您好 请添加我 的微信 twenty626
  • 韩女士 在2022/11/24 10:01:00留言
  • 详细留言:KLA Thermawave OP2600,KLA Tencor 5200XP,KLA 6420,KLA 2315。想了解报价和产品规格说明书。
  • 张鸿益 在2022/4/29 14:07:00留言
  • 详细留言:請與我聯繫。謝謝
  • 汪丽 在2021/12/13 10:48:00留言
  • 详细留言:需求CI-T120 管脚检查机
