深圳市东测科技有限公司
  • TT1000ABarfield?TT1000A??涡轮温度测绘仪
  • 发布时间:2014/5/22 21:56:18   修改时间:2014/5/22 21:56:18 浏览次数:1228
    The TT1000A is a completely self-contained, battery powered, aircraft turbine temperature system tester capable of measuring system lead resistance, insulation, and performing indicator run-outs with a range up to1000 °C. The unit was specifically designed to meet all requirements for testing aircraft Chromel/Alumel (CH/AL) turbine temperature measuring systems and provides an accurate display of thermocouple outputs in degrees Celsius (°C)
    The TT1000A is engineered for maximum ease of operation and includes an automatic digital display that practically eliminates human error and reduces testing time to a minimum. The test leads incorporate automatic temperature compensation to remove induced voltage caused by a “Cold Junction” created when the test leads are attached to the aircraft.
    All of the features designed into the TT1000A have been added to reduce maintenance time and cost as well as provide a maintenance friendly tester for measuring and displaying resistance of thermocouple, thermocouple rings and system lead circuits. Simulates CH/AL thermocouple with or without simulated system lead resistance. Simulates thermocouple outputs and system lead resistances from 0 to 25 ohms. Measures and displays insulation resistance of system wiring and other components. Measures and displays values of CH/AL thermocouple in terms of degrees Celsius (°C) temperature.
深圳市东测科技有限公司公司现货销售、租赁惠普(安捷伦)、泰克、安立、爱得万、横河、安腾、力科、马可尼(IFR)、R&S、Exfo等品牌之眼图仪、光谱分析仪、光时域反射仪(OTDR)、可调激光源、光功率计、光衰减器、光纤熔接机等光纤通信仪…  更多>>
深圳市东测科技有限公司
联系人:黄文俊
地址:深圳市龙华新区人民南路莱蒙水榭春天7栋凤凰苑24C/24D
邮编:518131
电话:13928415151
传真:0755-83176509
公司网址:http://www.itestworld.com
  • 陈苗 在2024/9/22 13:42:00留言
  • 详细留言:您好 请添加我 的微信 twenty626
  • 韩女士 在2022/11/24 10:01:00留言
  • 详细留言:KLA Thermawave OP2600,KLA Tencor 5200XP,KLA 6420,KLA 2315。想了解报价和产品规格说明书。
  • 张鸿益 在2022/4/29 14:07:00留言
  • 详细留言:請與我聯繫。謝謝
  • 汪丽 在2021/12/13 10:48:00留言
  • 详细留言:需求CI-T120 管脚检查机
