5001iXCalifornia Instruments?5001iX
The California Instruments 5001iX AC/DC Power Source/Analyzer, 5 kVA is a flexible AC/DC power source with a high performance power analyzer. Compliant with IEC/EN 61000-3-2 and IEC/EN 61000-3-3, the 5001iX is capable of handling complex applications that have traditionally required multiple instruments. The sleek integrated design of the 5001iX avoids the cable clutter that is commonly found in AC test systems. The unit is rack mountable with a 4U chassis design. All connections are made internally and the need for external digital multimeters, power harmonics analyzer and current shunts or clamps is completely eliminated.
Using a state of the art digital signal processor in conjunction with precision high resolution A/D converters, the 5001iX provides more accuracy and resolution than can be found in other harmonic power analyzers. Since many components in the 5001iX are shared between the AC/DC source and the power analyzer, the total cost of the integrated system is less than the typical cost of a multiple unit system.
Types of regulatory testing that can be performed on the 5001iX include IEC61000-4-11, IEC61000-4-14 and IEC61000-4-28. ***Opt. 413, IEC61000-4-13 - Harmonics and Interharmonics test firmware available***
Specifications:Output Power AC 5 kVAPhase Output 1Max. Current Per Phase Low V range: AC 37DC 26High V range: AC 18.5DC 13Input Voltage 208-240V
联系人:黄文俊
地址:深圳市龙华新区人民南路莱蒙水榭春天7栋凤凰苑24C/24D
邮编:518131
电话:13928415151
传真:0755-83176509
公司网址:http://www.itestworld.com
