CI00400AAmplifier Research?CI00400A
he Model CI00400A is a fully self-contained state of the art system designed to test RF Conducted Immunity.The system contains a signal generator, 3 channel power meter, 100W nominal AR amplifier 10kHz to 400MHz, directional coupler, and control software. Everything is contained in a single housing, which eliminates setup issues.
This system provides the versatility needed for every test laboratory and equipment manufacturer.The RF amplifier and the signal generator can be used independently of the system.If special needs arise or standards were to change a larger amplifier can be connected to the system.
The use of spectrum analyzers and monitoring equipment may also be controlled by the software. Option 1 adds an additional power head for testing automotive standards such as Ford, GM, Chrysler, BMW, Renault, and ISO11452-4. Option 2 adds data acquisition capability. Option 3 provides a laptop PC preloaded with the test software. Option 4 is a lower cost solution providing all the functions and features of the full CI00400A base model without the cost of the internal amplifier.
EXPORT CONTROLLED DATAThese commodities, technology, or software are controlled for export in accordance with the U.S. Export Administration Regulations. Diversion contrary to U.S. law is prohibited.
联系人:黄文俊
地址:深圳市龙华新区人民南路莱蒙水榭春天7栋凤凰苑24C/24D
邮编:518131
电话:13928415151
传真:0755-83176509
公司网址:http://www.itestworld.com
