深圳市东测科技有限公司
  • CI00250AM1Amplifier Research?CI00250AM1
  • 发布时间:2014/5/22 22:24:49   修改时间:2014/5/22 22:24:49 浏览次数:656
    Complete Testing Solutions to the following standards: ? EN/IEC 61000-4-6 ? IEC 60601-1-2 ? EN 50130-4 ? EN 61000-6-1/2? EN 55024 ? CISPR 14-2
    The Model CI00250A is a fully self-contained state of the art system designed to test RF Conducted Immunity. The CI00250A contains all the instruments needed to perform conducted immunity testing to the IEC 61000-4-6 specification. The system contains a signal generator, 3 channel power meter, 75W minimum AR amplifier 10kHz to 250MHz, and control software.
    Everything is contained in a single housing, which eliminates setup issues. This system will have the versatility needed for every test laboratory and equipment manufacturer. The RF amplifier and the signal generator can be used independently of the system. If special needs arise or standards were to change a larger amplifier can be connected to the system. The use of spectrum analyzers and monitoring equipment may also be controlled by the software.
    EXPORT CONTROLLED DATAThese commodities, technology, or software are controlled for export in accordance with the U.S. Export Administration Regulations. Diversion contrary to U.S. law is prohibited.
深圳市东测科技有限公司公司现货销售、租赁惠普(安捷伦)、泰克、安立、爱得万、横河、安腾、力科、马可尼(IFR)、R&S、Exfo等品牌之眼图仪、光谱分析仪、光时域反射仪(OTDR)、可调激光源、光功率计、光衰减器、光纤熔接机等光纤通信仪…  更多>>
深圳市东测科技有限公司
联系人:黄文俊
地址:深圳市龙华新区人民南路莱蒙水榭春天7栋凤凰苑24C/24D
邮编:518131
电话:13928415151
传真:0755-83176509
公司网址:http://www.itestworld.com
  • 陈苗 在2024/9/22 13:42:00留言
  • 详细留言:您好 请添加我 的微信 twenty626
  • 韩女士 在2022/11/24 10:01:00留言
  • 详细留言:KLA Thermawave OP2600,KLA Tencor 5200XP,KLA 6420,KLA 2315。想了解报价和产品规格说明书。
  • 张鸿益 在2022/4/29 14:07:00留言
  • 详细留言:請與我聯繫。謝謝
  • 汪丽 在2021/12/13 10:48:00留言
  • 详细留言:需求CI-T120 管脚检查机
