CI00400AM4Amplifier Research?CI00400AM4
Complete testing solutions to the following standards: ? MIL-STD-461D & E CS114 ? DO160D & E BCI Testing ? EN/IEC 61000-4-6 ? IEC 60601-1-2 ? EN 50130-4 ? EN 61000-6-1/2 ? EN 55024
The Model CI00400A is a fully self-contained state of the art system designed to test RF Conducted Immunity. The CI00400AM4 has an additional power head for testing automotive standards such as Ford, GM, Chrysler, BMW, Renault, and ISO11452-4.
The system contains a signal generator, 3 channel power meter, 100W nominal AR amplifier 10kHz to 400MHz, directional coupler, and control software. Everything is contained in a single housing, which eliminates setup issues.This system provides the versatility needed for every test laboratory and equipment manufacturer.
The RF amplifier and the signal generator can be used independently of the system.If special needs arise or standards were to change a larger amplifier can be connected to the system. The use of spectrum analyzers and monitoring equipment may also be controlled by the software. If the customer already owns a suitable amplifier, the CI00400AM5 option is a lower cost solution providing all the functions and features of the full CI00400A base model without the cost of the internal amplifier.
EXPORT CONTROLLED DATAThese commodities, technology, or software are controlled for export in accordance with the U.S. Export Administration Regulations. Diversion contrary to U.S. law is prohibited.![](http://www.cechina.cn/UpLoad/CompanyFile/2014/5/22/111bb574-a76c-44e8-ac22-3a85609e7294.jpg)
