TSL-510Santec TSL-510 Tunable Laser
High Performance Tunable LaserSantec built the world’s first commercially available narrow linewidth tunable laser in 1987. Growing from that innovative start, we have developed a range of laser solutions for a wide variety of applications across many technical fields. Whatever your application, Santec can offer a tunable laser that will not only integrate seamlessly with your system, but will also increase your measurement capability and accuracy.
OverviewThe TSL-510 provides market-leading performance in a compact, easy to use package. Continuous, mode-hop-free wavelength sweeps can be performed over its full 130nm tuning range with the highest output power of comparable bench top lasers on the market today. A variety of options are available to provide high output power, high SNR and high wavelength accuracy if required. GPIB interface with the industry standard SCPI command set allow full remote control and measurement automation.
Features+10dBm peak output power (types A & C)130nm tuning range within 1260-1680nmMode-hop-free wavelength sweeps100nm/s sweep speed>65dB SNR (types B & D)Swept Test System Option
Enable to measure the WDL/PDL characteristics of optical components and modules at high speed, with high accuracy and high resolution.F171
联系人:黄文俊
地址:深圳市龙华新区人民南路莱蒙水榭春天7栋凤凰苑24C/24D
邮编:518131
电话:13928415151
传真:0755-83176509
公司网址:http://www.itestworld.com
