深圳市东测科技有限公司
  • 2393AIFR 2393A 频谱分析仪
  • 发布时间:2014/5/22 23:32:05   修改时间:2014/5/22 23:32:05 浏览次数:958
    The analyzer was tested up to 3 GHz. The peak reading of the spectrum is less then it should be.The peal at 10 MHz is about 20 dB less and at 3 GHz the peak is about 5 dB less then the input power. The frequency reading was correct. This item is sold AS-IS for calibration - repairIFR 2393A 9KHz-26.5GHz Spectrum Analyzer Product OverviewFully synthesized Spectrum Analyzers to 26.5 GHz3 Hz to 30 MHz resolution bandwidth filtersExcellent intermodulation performance+30 to -135 dBm measurement rangeMeasurements to 300 GHz with external mixersOptional built-in tracking generatorReceiver mode with AM and FM demodulatorsOptional quasi-peak detector and EMC filtersThe 2390A series of spectrum analyzers from IFR combine exceptional performance with excellent value for money. There are three instruments in the range:-
    2392A 9 kHz to 2.9 GHz2390A 9 kHz to 22 GHz2393A 9 kHz to 26.5 GHzFrequency Accuracy All three instruments are fully synthesized to give accurate frequency measurements. Even on wide spans the 2390A series gives precise frequency measurements and an integral frequency counter enables the measurement of individual signals to 1 Hz resolution. Fundamental mixing to 12 GHz enables the microwave versions to reach their maximum frequency in only two harmonic sweeps. This gives excellent sensitivity and accuracy right up to 26.5 GHz. Narrow Resolution The 2390A series all have resolution bandwidths down to 3 Hz. Narrow resolution bandwidths provide the ability to resolve closely spaced signals or sidebands. The 3 Hz filter is also used for close in signal analysis, for example it can be used to identify 50 or 60 Hz power line sidebands on oscillators. The average displayed noise level when using a 3 Hz filter is less than -135 dBm at 2.9 GHz and below -125 dBm at 26.5 GHz. This makes 2390A series suitable for locating and identifying low level spurious and harmonic signals.
    Wideband Filters for Spread Spectrum and Pulsed Signals When analyzing signals with wide spectrum bandwidths such as digitally modulated carriers or pulsed radar, the resolution bandwidth of the spectrum analyzer can limit the measurement. The 2390A series have 10 MHz and 30 MHz bandwidth filters. These give the best available characterization of wideband signals and have an impulse bandwidth >5 MHz. In zero span mode a minimum sweep time of 200 ns/div makes displaying radar pulses precise and straightforward.
    AM and FM Receiver Modes The 2390A series features built-in receivers for both AM and FM signals. Modulation detection can be set to narrowband or wideband mode. For an FM transmission a modulation scale of 1 kHz to 5 MHz per division allows direct measurement of the modulation component of carrier signals up to ±20 MHz deviation. Frequency synthesizer settling time can be measured using the DC coupled output from the FM detector. A high quality audio output through either a built-in speaker or headphone connector allows audible detection of noise or distortion. It can also be used to identify the source of interfering transmissions.
深圳市东测科技有限公司公司现货销售、租赁惠普(安捷伦)、泰克、安立、爱得万、横河、安腾、力科、马可尼(IFR)、R&S、Exfo等品牌之眼图仪、光谱分析仪、光时域反射仪(OTDR)、可调激光源、光功率计、光衰减器、光纤熔接机等光纤通信仪…  更多>>
深圳市东测科技有限公司
联系人:黄文俊
地址:深圳市龙华新区人民南路莱蒙水榭春天7栋凤凰苑24C/24D
邮编:518131
电话:13928415151
传真:0755-83176509
公司网址:http://www.itestworld.com
  • 陈苗 在2024/9/22 13:42:00留言
  • 详细留言:您好 请添加我 的微信 twenty626
  • 韩女士 在2022/11/24 10:01:00留言
  • 详细留言:KLA Thermawave OP2600,KLA Tencor 5200XP,KLA 6420,KLA 2315。想了解报价和产品规格说明书。
  • 张鸿益 在2022/4/29 14:07:00留言
  • 详细留言:請與我聯繫。謝謝
  • 汪丽 在2021/12/13 10:48:00留言
  • 详细留言:需求CI-T120 管脚检查机
