keysight是德 N5225A PNA微波网络分析仪
![](http://img55.chem17.com/9/20160716/636042842861034731512.jpg)
主要特性和功能
获得卓越的测量和设计成果
PNA 提供出色的测量完整性,可将深入的洞察转变为更优秀的设计
使用性能出众的微波网络分析仪,应对苛刻的测量挑战
是德科技 S 参数测量提供超高精度
最大频率 50 GHz
动态范围 127 dB
输出功率 13 dBm
轨迹噪声 0.003 dBrms
内置端口数量 2 或 4 端口
谐波 -60 dBc
本底噪声 -114 dBm
扫描速度最高可达 201 个点 5.5 ms
网络分析仪系列 PNA 高性能
仪器类型 矢量网络分析仪
应用
S 参数
平衡测量
材料
脉冲射频
元器件
天线
混频器/变频器
放大器
台式 是
Hardware options
N5225A-200 2 ports, single source, base hardware configuration
N5225A-201 2 ports, single source, with configurable test set
N5225A-210 2 ports, single source, with metrology configuration
N5225A-217 2 ports, single source, configurable test set, extended power range
N5225A-219 2 ports, single source, configurable test set, extended power range, bias-tees
N5225A-400 4 ports, dual source, base hardware configuration
N5225A-401 4 ports, dual source, with configurable test set
N5225A-410 4 ports, dual source, with metrology configuration
N5225A-417 4 ports, dual source, configurable test set, extended power range
N5225A-419 4 ports, dual source, configurable test set, extended power range, bias-tees
Additional capability
N5225A-008 Pulsed RF Measurements
N5225A-010 Time Domain
N5225A-020 Add IF inputs
N5225A-021 Add pulse modulator to internal first source
N5225A-022 Add pulse modulator to internal second source
N5225A-025 Add four internal pulse generators
N5225A-028 Noise figure measurements using standard receivers
N5225A-080 Frequency offset measurements
N5225A-082 Scalar calibrated converter measurements
N5225A-083 Vector and scalar calibrated converter measurements
N5225A-084 Embedded LO measurements
N5225A-086 Gain compression application
N5225A-087 Intermodulation distortion measurements
N5225A-118 Fast CW Mode
N5225A-460 Integrated true-mode stimulus application
N5225A-551 N-port calibrated measurements
N5225A-088 Source phase control
N5225A-302 Application for use with temperature-characterized CalPods
N5225A-301 Application for use with standard CalPods
N5225A-089 Differential and I/Q devices application
N5225A-007 Automatic Fixture Removal
N5225A-015 Dynamic Uncertainty for S-Parameter Measurements
N5225A-090 Spectrum Analyzer
N5225A-093 Extended Spectrum Analyzer to 110 GHz
N5225A-094 Extended Spectrum Analyzer above 110 GHz
Calibration Software for Self-Maintainers
N5225A-897 Built-in performance test software for inclusive calibration, perpetual license
N5225A-898 Built-in performance test software for standards compliant calibration, perpetual license
Calibration documentation
N5225A-1A7 Calibration + Uncertainties + Guardbanding (Not Accredited)
N5225A-A6J ANSI Z540-1-1994 Calibration
N5225A-UK6 Commercial calibration certificate with test data
Accessories
N5225A-1CP Rack mount kit for installation with handles
N5225A-1CM Rack mount kit for installation without handles
N1966A 脉冲/IO 适配器
N6171A MATLAB 软件
