anritsu MS2036A 频谱分析仪
![](http://img54.chem17.com/9/20160716/636042850694765806566.jpg)
For field engineers and technicians who need all essential RF measurements anytime and anywhere, the MS2036A VNA Masters are the first and only truly portable handhelds with integrated 2-port vector network analyzer from 2 MHz to 6 GHz, spectrum analyzer from 9 kHz to 7.1 GHz, and power meter capabilities in a single instrument.
Ideally suited for aerospace and defense application, the VNA Master offers valuable measurement capabilities that can replace obsolete instruments and improve operator mobility. In this way, field engineers and technicians can more quickly install, deploy, and maintain RF systems in the field.
VNA Master is also an excellent solution for low-cost manufacturing and other general purpose applications given the broad frequency coverage, excellent performance, and integrated capabilities.
Vector Network Analysis from 2 MHz to 6 GHz
Spectrum Analysis from 9 kHz to 7.1 GHz
Power Meter analysis from 10 MHz to 6 GHz
Vector Corrected 1-port and 1-path 2-port measurements for phase matching cables and precisely finding faults in antennas, connectors, and cables
Vector Voltmeter replacement
2 ms/data points sweep speed
USB/Ethernet for data transfer
Store 1000 traces and setups in internal memory
Memory card slot for data storage and transfer
High resolution daylight viewable TFT color display
Built-in and custom editable Cable and Signal Standard List
Automate repetitive tasks with remote programming via Ethernet connector
Weight 9 lbs (4 kg)
Option
Description
Option Ordering Number
Option 5
Power Monitor (requires external detector)
MS2036A-005
Option 10
Bias Tee variable voltage
MS2036A-010
Option 15
Vector Voltmeter
MS2036A-015
Option 25
Interference Analysis
MS2036A-025
Option 19
High Accuracy Power Meter (requires PSN50 or MA24106A, sold separately)
MS2036A-019
Option 27
Channel Scanner
MS2036A-027
Option 31
GPS Receiver (includes GPS antenna)
MS2036A-031
