深圳市东测科技有限公司
  • Vitronics TF-40 自动托盘成型机
  • 发布时间:2017/3/16 10:51:31   修改时间:2017/3/16 10:51:31 浏览次数:988
    The suction cups pick up the blank from the horizontal magazine. The blank is then unloaded onto the guides and carried by the main chain, which is pushed from the rear to a position underneath the rear hot-melt glue guns that apply the glue stitches indicated in the program to the reinforced corners. Two pneumatic devices pre-fold the corner flaps at a 90° angle to fit the blank in the propellers of the main station where the pressers fold and glue the flaps. Then, the chain moves the blank forward in a continuous cycle, passing in front of the front glue applicators to reach a pneumatic actuator which centers the blank in the hopper (forming area) where the cycle starts. The mold activates and strong pressure is applied between the corners and the side of the tray being glued with the glue still hot during the forming piston stroke . The tray stops between the four spring stopping devices in order for the mold to come out easily. The top flaps are folded by four pneumatic cylinders (one for each corner in order to follow the natural fold of the blank). Four side pressers fold and glue the flaps along the side of the box. During this operation, slight pressure is applied between the tray top flaps and the four pneumatic stopping devices at the bottom of the box to make sure the sizes and squaring are correct. The operating cycle is PLC-controlled, according to specific parameters previously set in the program with the color interface. Up to 80 sizes can be saved and are controlled in hundredths of a second to optimize and compensate for special weather conditions and/or conditions of the cardboard used.
    FEATURES DETAILS FEATURES DETAILS
     Production rate  40 pcs / min.  Minimum box size  190 x 280 mm
     Power required  10 kW  Maximum box size  600 x 600 mm
     Compressed air consumption  36 nl / cycle  Minimum tray size  340 x 420 mm
     Total weight  1700 kg  Maximum tray size  1000 x 1300 mm
     Dimensions  6000 x 1800 H 2000 mm  Outlet box side and front TS43 / LT
深圳市东测科技有限公司公司现货销售、租赁惠普(安捷伦)、泰克、安立、爱得万、横河、安腾、力科、马可尼(IFR)、R&S、Exfo等品牌之眼图仪、光谱分析仪、光时域反射仪(OTDR)、可调激光源、光功率计、光衰减器、光纤熔接机等光纤通信仪…  更多>>
深圳市东测科技有限公司
联系人:黄文俊
地址:深圳市龙华新区人民南路莱蒙水榭春天7栋凤凰苑24C/24D
邮编:518131
电话:13928415151
传真:0755-83176509
公司网址:http://www.itestworld.com
  • 陈苗 在2024/9/22 13:42:00留言
  • 详细留言:您好 请添加我 的微信 twenty626
  • 韩女士 在2022/11/24 10:01:00留言
  • 详细留言:KLA Thermawave OP2600,KLA Tencor 5200XP,KLA 6420,KLA 2315。想了解报价和产品规格说明书。
  • 张鸿益 在2022/4/29 14:07:00留言
  • 详细留言:請與我聯繫。謝謝
  • 汪丽 在2021/12/13 10:48:00留言
  • 详细留言:需求CI-T120 管脚检查机
