TEP-PS-100-240AC/ 5DC/4
ETR-U-18-230UC/21
MINI PS-100-240AC/24DC/2
MINI-PS-100-240AC/24DC/1.3
QUINT-PS-100-240AC/48DC/5
MINI PS-100-240AC/5DC/3
CM 50-PS-120-230AC/24DC/2.5/F
MINI SYS-PS-100-240AC/24DC/1.5
MINI PS-100-240AC/2X15DC/1
QUINT-PS/1AC/24DC/5
TRIO-PS/3AC/24DC/10
QUINT-DC-UPS/24DC/10
QUINT-DC-UPS/24DC/20
菲尼克斯Phoenix光电转换器PSI-MOS-PROFIB/FO 850 E
菲尼克斯Phoenix接口转换器PSM-ME-RS232/RS485-P
菲尼克斯Phoenix中继器PSM-ME-RS485/RS485-P
菲尼克斯Phoenix串行设备服务器FL COM SERVEN RS232
菲尼克斯Phoenix工业模拟MODEM:PSI-DATA/FAX-MODEM/RS232
菲尼克斯Phoenix蓝牙转换器:PSI-WL-RS232-RS485/BT
菲尼克斯Phoenix蓝牙适配器PSI-WL-PLUG-RS232/BT
菲尼克斯RS-232电缆:PSM-KA-9SUB25/BB/2 METER
菲尼克斯终端模块:PSI-MOS-RS232/FO 660 E
菲尼克斯T型模块PSI-MOS-RS232/FO 660 T
菲尼克斯系统电源:MINI-SYS-PS-100-240AC/24DC/1.5
菲尼克斯Phoenix全向天线:RAD-ISM-2400-ANT-OMNI-2-1
RAD-ISM-2400-ANT-OMNI-9-0
菲尼克斯Phoenix定向天线:RAD-ISM-2400-ANT-PAN-8-0
菲尼克斯Phoenix双向无线传输系统:RAD-ISM-2400-SET-BD-BUS-ANT
菲尼克斯Phoenix单向无线传输系统:RAD-ISM-2400-SET-UDANT
菲尼克斯Phoenix耦合I/O模块IB IL BK-PLSET/CP
IB IL SCN-12-ICP
IB IL SCN-12-OCP
IB IL SCN-6 SHIELD
IB IL SCN-8-CP
IB IL TEMP 2 RTD
IB IL 400 ELR R-3A
IL PB BK DP/V1-PAC
IB IL 24 DI 4-PAC
IB IL TEMP 2 RTD-PAC
菲尼克斯Phoenix耦合I/O模块IB IL 24 SEG/F-PAC
IB IL AI 2/SF-PAC
IB IL AO 1/SF-PAC
IB IL AI 2/SF
FLS PB M12 DO 8 M12-2A
FLS PB M12 DIO 8/8 M12
FLS PB M12 DI 16 M12
FL COM SERVER RS232
SAC-2P-M12MSB/ 2,0-910/M12FSB
IB IL 24 DI 16
IB IL 24 DI 2
IB IL 24 DO 16
IB IL 24 DO 8
IB IL TEMP 2 RTD
IBS ST 24 BK-T
IB ST 24 DO16/3
VIOK 1.5-2D
FL MC 10/100 BASE-T/FO G1300ST
IF 2FX SM SC-DJ
FL IF 2TXVS-RI-D
FLM BK PB M12 DI 8 M12
FLM DI 8 M12
IB IL AO 2/U/BP
IBS IL 24 BK-T/U
IBS S5 DSC/I-T
FLS IB M12 DI 8 M12
ILB IB 24 DI16
IBS PC ISA SC/I-T
IB ST 24 DI32/2
IB ST 24 DO32/2
IB ST 24 DI 16/4
IB ST 24 DO16/3
ILB IB 24 DI16 DO16
SUBCON-PLUS-PROFIB/SC2
SUBCON-PLUS-PROFIB/PG/SC2
RAD-ISM-2400-SET-UD-ANT
菲尼克斯Phoenix交换机FL SWITCH 4TX/FX
菲尼克斯Phoenix交换机FL SWITCH 8TX
菲尼克斯Phoenix交换机FL SWITCH MM HS
菲尼克斯Phoenix交换机FL SWITCH SF 14TX/2FX
菲尼克斯Phoenix交换机FL SWITCH MCS 16TX
FL SWITCH MCS 14TX/2FX
FL SWITCH SF 8TX
FL SWITCH SF 6TX/2FX
FL SWITCH SFN 5TX
FL SWITCH SFN 4TX/FX
FL SWITCH SFN 6TX/2FX
ILC 200 IB-PAC
ILC 200 UNI-PAC
ILC 350 PN
TP 06S
TP 10T
IL PB BK DI8 DO4-PAC
IBS IL 24 BK-T/U-PAC
IB IL 24 DI 8-PAC
IB IL 24 DI 16-PAC
IB IL 24 DI 32/HD-PAC
IB IL 24 DO 8-PAC
IB IL 24 DO 16-PAC
菲尼克斯Phoenix耦合I/O模块IB IL 24 DO 32/HD-PAC
IB IL 24 DI 4-ME
IB IL 24 DO 4-ME
菲尼克斯Phoenix耦合I/O模块IB IL AI 8/SF-PAC
IB IL AO 2/SF-PAC
IB IL AI 2/SF-ME
IB IL AO 2/U/BP-ME
IB IL 24 PWR IN/F-PAC
IB IL 24 DO 4-PAC
IB IL 24 DI 16-PAC
ASI MA PB XL AB
IB IL 400 CN-PWR-IN
IB IL 400 ELR R-3A
IL PB BK DP/V1
IB IL DI16-PLSET/ICP
IB IL SCN-PWR IN-CP
IB IL DO16-PLSET/OCP
IB IL SCN 6-SHIELD-TWIN
IB IL 24 DI 2
菲尼克斯Phoenix耦合I/O模块IB IL 24 DO 2
IB IL AI 2/SF 230
IBS IL 24 BK-T/U
SST-IBS-CLX-RLL
1.网络集线器 / 转发器 / 开关
2832551 FL HUB 8TX-ZF
2832564 FL HUB 16TX-ZF
2832810 FL SWITCH 4TX/FX
2832085 FL SWITCH 5TX
2832218 FL SWITCH 8TX
2832593 FL SWITCH SF 14TX/2FX
2832661 FL SWITCH SF 15TX/FX
2832726 FL SWITCH SF 7TX/FX
2832771 FL SWITCH SF 8TX
2832849 FL SWITCH SF 16TX
2832933 FL SWITCH SF 6TX/2FX
2832577 FL SWITCH SF 7TX/FX ST
2832603 FL SWITCH SF 4TX/3FX ST
2832674 FL SWITCH SF 6TX/2FX ST
2.模块化控制开关
2832328 FL SWITCH MM HS
2832331 FL MXT
2832522 FL SWITCH MM HS/M
2832535 FL MXT/M
2832344 FL IF 2TX VS-RJ-F
2832357 FL IF 2TX VS-RJ-D
2832742 FL IF 2HCS 100-D
2832852 FL IF 2POF 10/100-D
2832412 FL IF 2FX SC-F
2832425 FL IF 2FX SC-D
2832205 FL IF 2FX SM SC-D
2884033 FL IF 2FX ST-D
2832739 FL IF TX/HCS 100-D
2832807 FL IF TX/POF 10/100-D
2832470 FL CB IF
2832483 FL IF MEM 2TX-D
2832904 FL IF 2PSE-F
Order No. Type Description
3.控制转换开关
2832700 FL SWITCH MCS 16TX
2832713 FL SWITCH MCS 14TX/2FX
4.PROFINET INTERBUS 代理服务器
2832111 FL PN/IBS
5.网关
2744490 FL COM SERVER RS232
2708740 FL COM SERVER RS485
2313041 FL COM SERVER RS232 PRO
2313054 FL COM SERVER RS485 PRO
2831060 FL IBS SC/I-T
2862327 FL IL 24 BK-B-PAC
2862314 FL IL 24 BK-PAC
2878816 FL IL 24 BK-PN-PAC
2863986 FL IL 24 BK ETH/IP-PAC
6.控制软件
2831044 FL SWT
2832166 FL SNMP OPC SERVER
2832179 FL OPC SNMP AGENT
7.媒体转换器
2708193 FL MC 10/100BASE-T/FO-660
2744513 FL MC 10BASE-T/FO POF
2744788 FL MC 10BASE-T/FO G850
2708164 FL MC 10/100BASE-T/FO G1300
2708986 FL MC 10/100 BASE-T/FO G1300ST
2708177 FL MC 10/100BASE-T/FO G1300 SM
8.SFN开关
2891851 FL SWITCH SFN 4TX/FX
2891453 FL SWITCH SFN 4TX/FX ST
2891152 FL SWITCH SFN 5TX
2891929 FL SWITCH SFN 8TX
9.电缆及附件
2832250 FL CAT5 PATCH 0,3
2832263 FL CAT5 PATCH 0,5
2832276 FL CAT5 PATCH 1,0
2832221 FL CAT5 PATCH 1,5
2832289 FL CAT5 PATCH 2,0
2832292 FL CAT5 PATCH 3,0
2832580 FL CAT5 PATCH 5,0
2832616 FL CAT5 PATCH 7,5
2832629 FL CAT5 PATCH 10,0
2744814 FL CAT5 HEAVY
2744827 FL CAT5 HEAVY CONF/
2744830 FL CAT5 FLEX
2744843 FL CAT5 FLEX CONF/
2744856 FL PLUG RJ45 GR/2
2744571 FL PLUG RJ45 GN/2
2744869 FL CRIMPTOOL
2744610 FL CAT5 TERMINAL BOX
2832991 FL RJ45 PROTECT CAP
2832496 FL PBX 8TX
2832506 FL PBX 6TX/4FX
2832865 FL SEC PAC 4TX
2832687 FL PF SEC 2TX
2832690 FL PF SEC 8TX
2891165 FL PF 2TX CAT5E
2891068 FL PF 2TX CAT 6
2891071 FL PF 8TX CAT 6
2891178 FL PF 8TX CAT5E 此信息来自买卖机械网
