4033 FL IF 2FX ST-D
2832739 FL IF TX/HCS 100-D
2832807 FL IF TX/POF 10/100-D
2832470 FL CB IF
2832483 FL IF MEM 2TX-D
2832904 FL IF 2PSE-F
2832700 FL SWITCH MCS 16TX
2832713 FL SWITCH MCS 14TX/2FX
2832111 FL PN/IBS
2744490 FL COM SERVER RS232
2708740 FL COM SERVER RS485
2313041 FL COM SERVER RS232 PRO
2313054 FL COM SERVER RS485 PRO
2831060 FL IBS SC/I-T
2862327 FL IL 24 BK-B-PAC
2862314 FL IL 24 BK-PAC
2878816 FL IL 24 BK-PN-PAC
2863986 FL IL 24 BK ETH/IP-PAC
2831044 FL SWT
2832166 FL SNMP OPC SERVER
2832179 FL OPC SNMP AGENT
2708193 FL MC 10/100BASE-T/FO-660
2744513 FL MC 10BASE-T/FO POF
2744788 FL MC 10BASE-T/FO G850
2708164 FL MC 10/100BASE-T/FO G1300
2708986 FL MC 10/100 BASE-T/FO G1300ST
2708177 FL MC 10/100BASE-T/FO G1300 SM
2891851 FL SWITCH SFN 4TX/FX
2891453 FL SWITCH SFN 4TX/FX ST
2891152 FL SWITCH SFN 5TX
2891929 FL SWITCH SFN 8TX
2832250 FL CAT5 PATCH 0,3
2832263 FL CAT5 PATCH 0,5
2832276 FL CAT5 PATCH 1,0
2832221 FL CAT5 PATCH 1,5
2832289 FL CAT5 PATCH 2,0
2832292 FL CAT5 PATCH 3,0
2832580 FL CAT5 PATCH 5,0
2832616 FL CAT5 PATCH 7,5
2832629 FL CAT5 PATCH 10,0
2744814 FL CAT5 HEAVY
2744827 FL CAT5 HEAVY CONF/
2744830 FL CAT5 FLEX
2744843 FL CAT5 FLEX CONF/
2744856 FL PLUG RJ45 GR/2
2744571 FL PLUG RJ45 GN/2
2744869 FL CRIMPTOOL
2744610 FL CAT5 TERMINAL BOX
2832991 FL RJ45 PROTECT CAP
2832496 FL PBX 8TX
2832506 FL PBX 6TX/4FX
2832865 FL SEC PAC 4TX
2832687 FL PF SEC 2TX
2832690 FL PF SEC 8TX
2891165 FL PF 2TX CAT5E
2891068 FL PF 2TX CAT 6
2891071 FL PF 8TX CAT 6
2891178 FL PF 8TX CAT5E
菲尼克斯分布式I/O模块
2736013 FLS IB M12 DI 8 M12
2736026 FLS IB M12 DIO 4/4 M12-2A
2736039 FLS IB M12 DO 8 M12-2A
2736042 FLS DN M12 DIO 4/4 M12-2A
2736055 FLS DN M12 DO 8 M12-2A
2736068 FLS DN M12 DI 8 M12
2736071 FLS CO M12 DIO 4/4 M12-2A
2736084 FLS CO M12 DO 8 M12-2A
2736097 FLS CO M12 DI 8 M12
2736107 FLS PB M12 DIO 4/4 M12-2A
2736110 FLS PB M12 DO 8 M12-2A
2736123 FLS PB M12 DI 8 M12
2736220 FLS PB M12 DI 16 M12
2736314 FLS IB M12 DI 16 M12
2736327 FLS DN M12 DI 16 M12
2736372 FLS PB M12 DIO 8/8 M12
2736385 FLS IB M12 DIO 8/8 M12
2736398 FLS DN M12 DIO 8/8 M12
2736479 FLS CO M12 DI 16 M12
2736482 FLS CO M12 DIO 8/8 M12
菲尼克斯Phoenix光电转换器PSI-MOS-PROFIB/FO 850 E
菲尼克斯Phoenix接口转换器PSM-ME-RS232/RS485-P
菲尼克斯Phoenix中继器PSM-ME-RS485/RS485-P
菲尼克斯Phoenix串行设备服务器FL COM SERVEN RS232
菲尼克斯Phoenix工业模拟MODEM:PSI-DATA/FAX-MODEM/RS232
菲尼克斯Phoenix蓝牙转换器:PSI-WL-RS232-RS485/BT
菲尼克斯Phoenix蓝牙适配器PSI-WL-PLUG-RS232/BT
菲尼克斯RS-232电缆:PSM-KA-9SUB25/BB/2 METER
菲尼克斯终端模块:PSI-MOS-RS232/FO 660 E
菲尼克斯T型模块:PSI-MOS-RS232/FO 660 T
菲尼克斯系统电源:MINI-SYS-PS-100-240AC/24DC/1.5
菲尼克斯Phoenix全向天线:RAD-ISM-2400-ANT-OMNI-2-1
RAD-ISM-2400-ANT-OMNI-9-0
菲尼克斯Phoenix定向天线:RAD-ISM-2400-ANT-PAN-8-0
菲尼克斯Phoenix双向无线传输系统:RAD-ISM-2400-SET-BD-BUS-ANT
菲尼克斯Phoenix单向无线传输系统:RAD-ISM-2400-SET-UD-ANT
菲尼克斯Phoenix耦合I/O模块IB IL BK-PLSET/CP
IBS STME 24 BK DIO 8/8/3-LK
IBS STME 24 BK DIO 8/8/3-T
IBS STME 24 BK RB-LKDIO8/8/3LK
IBS STME 24 BK RB-T DIO8/8/3LK
IBS STME 24 BK RB-T
IB IL 24 PWR IN/2-F-D-PAC
IBS CT 24 IO GT-LK-OPC
IBS IL 24 BK RB-LK-PAC
IBS OPTOSUB-MA/M/L-LK-OPC
IBS RL 24 DI 16/8-LK
IBS RL 24 DIO 8/8/8-LK
IBS RL 24 DO 16/8-R-LK
IBS RL PLUG-LK/POF
PSM-LWL-KDHEAVY-980/1000
PSI-MOS-PROFIB/FO 850 T
PSI-MOS-RS485W2/FO 850 T
IB IL MUX-CAB PSI
IB IL SCN-12-OCP
IB IL SCN-6 SHIELD
IB IL SCN-8-CP
IB IL TEMP 2 RTD
IB IL 400 ELR R-3A
IB IL 24 PWR IN/2-F
IB IL 230 PWR IN
IB STME 24 AO 4/SF4
IB STME 24 DO 8/3-2A
IB STME 24 DIO 8/8R/3
