上海轶舜机电设备有限公司
  • AIRFLEX
  • 发布时间:2013/3/11 8:38:29   修改时间:2013/3/11 8:38:29 浏览次数:478
  • 美国AIRFLEX离合器,AIRFLEX刹车,AIRFLEX弹簧式离合器,AIRFLEX压缩式离合器
          上海轶舜机电设备有限公司优惠供应美国AIRFLEX离合器,AIRFLEX刹车,AIRFLEX弹簧式离合器,AIRFLEX压缩式离合器,AIRFLEX水冷式离合器。Airflex是FAWICK离合器的原制造商,在工业离合器和刹车市场具有很高的知名度。AIRFLEX刹车/离合器设计理念:出众的性能,较高的寿命,最佳的质量。AIRFLEX基于40年的生产和设计经验,为了提供更好的动力传动系统,AIRFLEX不断创新,满足客户各种需要。 Airflex 的总部设在美国 Cleveland, OH ,产品主要包括刹车和离合器,并分为以下种类型: 压缩式离合器/刹车: CB, CM, VC系列扩张式刹车和离合器: e, eb, er, ve系列油冷式/气冷式多片离合器/刹车: ar, as, sb, sc系列气冷式盘形刹车/离合器: dba, dbb, dbbs, dc系列离合器/刹车组合: cbc, dcb, fspa系列弹簧式离合器: cs, cte系列钳式离合器/刹车: dp, h系列水冷式离合器: WCB2 and WCBD, WCS, WCSB系列 CB4000 CB Element CBC16100 CBC Clutch/Brake Combination CM21000 CM Element CS8000 Spring Applied Drum Brake CTE8070 Spring Applied Drum Brake DBA8080.6 DBA Disc Centering Adjustment - Vertical Swing Motor Applications DBA8082 229DBA Model "494" Disc Centering Option DBB8100 Spring Applied Disc Brake DBB8104 DBB Brake With Corrosion Resistant Components DC20000 DC Element EB7000 EB and ER Element GC15100 Eaton/Geislinger Damping Torsional Flexible Coupling M-103-A SC Operation and Construction M-103-B SC and SA Installation and Mounting Instructions M-103-C Magnetic Clutches - Maintenance and Service Instructions PP3000 FSPA Applications RS9010 AA2, B2, B3, C2 Rotorseal RS9030 RH Rotorseal RS9040 RS 9040 Rotorseal Models AD ADP BP and FDA RS9070 BT Rotorseal TRS3064 Timing Rotorseal and Cam Limit Switch 4.0 Parts Timing Rotorseal (TRS) Parts List Cam Limit Sw Cam Limit Switch Exploded View Drawing and Parts List VC5000 VC Element VC5001 VC Grinding Mill Clutches WC11050 WCB Water Cooled Tensioners WCB11060 WCB With Corrosion Resistant Components WCS11110 WCS With Corrosion Resistant Components WSB11200 WCSB Brake WCB11070 WCB2 Water Cooled Tensioners CA10000 225DP100 Caliper Brakes
          AIRFLEX代理 AIRFLEX厂家 AIRFLEX价格 AIRFLEX经销 AIRFLEX型号 AIRFLEX现货
          AIRFLEX agent AIRFLEX manufacturer AIRFLEX price AIRFLEX distribution AIRFLEX model AIRFLEX spot
          The United States AIRFLEX clutch, AIRFLEX brake, AIRFLEX spring clutch, AIRFLEX compression type clutch
上海轶舜机电设备有限公司是一家集设备、备品备件采购、国际国内物流、市场咨询和调研于一体的技术型贸易公司。经过多年的发展,现已成为一家优秀的工业产品经销商,代理的品牌超过900多个,备有大量库存。 上海轶舜机电设备有限公司专业从事工…  更多>>
上海轶舜机电设备有限公司
联系人:张经理
地址:上海市新村路681号702室
邮编:200333
电话:021-51083016
传真:021-51875868
公司网址:http://www.gmeit.cn
  • Cady Lin 在2014/7/24 16:14:00留言
  • 详细留言:您好,请问贵公司可有提供一下品牌型号产品: 品牌: 迪普玛比例放大器 型号:EDM-M231-20EO 数量:1个 如果有的话,可否提供报价,及税费,运费,货期情况,不胜感谢!!
