英国Varley、Varley齿轮泵、Varley汽油胶泵、Varley叶片泵、Varley无泡沫机动泵、Varley立式涡轮泵、Varley农用泵、Varley消防泵、Varley浆液位移泵
上海轶舜国际贸易有限公司特价代理英国Varley齿轮泵、Varley汽油胶泵、Varley叶片泵、Varley无泡沫机动泵、Varley立式涡轮泵、Varley农用泵、Varley消防泵、Varley浆液位移泵、Varley柴油机喷油器实验装置、Varley手动高压实验单位。
Varley pumps 瓦利泵工程有限公司成立于1931年,公司长期以来一直承诺质量第一,技术第一,销量第一;产品主要用到钢厂、冶金、化工等企业。
以下部分型号列举:
Size 150 API 676 Pump Set Size 20 Pump (20SR-04)
Pump set built in accordance with API 676 complete with API 682 Seal and Flush Plan 11.
流量: 40 m3/hour (146.4 igpm)
压力: 10 Bar (150 psi)
介质: 柴油
材质: ASTM A216 WCB (铸钢)
标准泵.
流量: 5.5 m3/hour (20 igpm)
压力: 20 Bar (300 psi) Max
材质: Grade 220 Cast Iron
Size 20 Motorised Pump Set
(20M2T4R-04) Size 200 API 676 Pump Set
成套标准泵带电机.
压力: 10 Bar (150 psi) Max
材质: Grade 220 铸铁 Pump set built in accordance with API 676 complete with API 682 Seal and Flush plan 53B.
流量: 55 m3/hour (146.4 igpm)
压力: 6 Bar (90 psi)
介质: 石油/排污水
材质: 不锈钢
Twin Set Unit (8980S-10-6) Lube Oil Pump (8401-A-M)
Twin Set based on Size 10 Pumps.
流量:>2.7 m3/hour (10 igpm)
介质: 燃料油
材质: Grade 220 铸铁
Engine driven main lube oil pump and Fuel oil feed pump for Diesel Engine
流速: 290 m3/hour (1060 igpm) 润滑油l, 14 m3/hour (50 igpm) 燃油
压力: 6 Bar (90 psi) 润滑油, 10 Bar (145 psi) 燃料油
材质: LM25 TF (铸铝)
Spare parts API676 Gear Pumps
Varley代理 Varley厂家 Varley价格 Varley经销 Varley型号 Varley现货
Varley agent Varley manufacturer Varley price Varley distribution Varley model Varley spot
Varley gear pump, Varley gasoline glue pump, Varley vane pump, Varley no foam motor pump, Varley vertical turbine pump, Varley agricultural pump, fire pump, Varley Varley serous displacement pump
