上海轶舜国际贸易有限公司
  • TRANSDUCER TECHNIQUES称重传感器
  • 发布时间:2017/5/26 9:26:31   修改时间:2017/5/26 9:26:31 浏览次数:753
  •  TRANSDUCER TECHNIQUES传感器、TRANSDUCER TECHNIQUES称重传感器、TRANSDUCER TECHNIQUES扭矩传感器、TRANSDUCER TECHNIQUES特殊传感器
              上海轶舜国际贸易有限公司特价供应美国TRANSDUCER TECHNIQUES传感器、TRANSDUCER TECHNIQUES称重传感器、TRANSDUCER TECHNIQUES扭矩传感器、TRANSDUCER TECHNIQUES特殊传感器等全系列产品。
            美国Transducer Techniques公司成立于1979年,专门从事设计和制造全系列的称重传感器,扭矩传感器,专用传感器和相关仪器仪表。Transducer Techniques公司的传感器具有独特的设计重量和力量等多元化的过程控制,可在工厂自动化以及其他数百个应用服务等工业领域测量。所有的传感器传感元件都配有保税箔应变计和连接电缆。
    SLB-25 Capacity: 25 lbs Mini Compression Button
    SLB-50 Capacity: 50 lbs Mini Compression Button
    SLB-100 Capacity: 100 lbs Mini Compression Button
    SLB-250 Capacity: 250 lbs Mini Compression Button
    SLB-500 Capacity: 500 lbs Mini Compression Button
    SLB-750 Capacity: 750 lbs Mini Compression Button
    SLB-1K Capacity: 1,000 lbs Mini Compression Button
    LB0-100 Capacity: 100 lbs Compression Load Button
    LB0-100A Capacity: 100 lbs Compression Load Button
    LB0-250 Capacity: 250 lbs Compression Load Button
    LB0-500 Capacity: 500 lbs Compression Load Button
    LB0-750 Capacity: 750 lbs Compression Load Button
    LB0-1K Capacity: 1,000 lbs Compression Load Button
    LB0-2K Capacity: 2,000 lbs Compression Load Button
    LB0-3K Capacity: 3,000 lbs Compression Load Button
    LB0-5K Capacity: 5,000 lbs Compression Load Button
    LB0-10K Capacity: 10,000 lbs Compression Load Button
    LB0-15K Capacity: 15,000 lbs Compression Load Button
    LB0-20K Capacity: 20,000 lbs Compression Load Button
    LB0-30K Capacity: 30,000 lbs Compression Load Button
    LB0-50K Capacity: 50,000 lbs Compression Load Button
    LBC-100 Capacity: 100 lbs Compression Load Button
    LBC-100A Capacity: 100 lbs Compression Load Button
    LBC-250 Capacity: 250 lbs Compression Load Button
    LBC-500 Capacity: 500 lbs Compression Load Button
    LBC-750 Capacity: 750 lbs Compression Load Button
    LBC-1K Capacity: 1,000 lbs Compression Load Button
    LBC-2K Capacity: 2,000 lbs Compression Load Button
    LBC-3K Capacity: 3,000 lbs Compression Load Button
    LBC-5K Capacity: 5,000 lbs Compression Load Button
    LBC-10K Capacity: 10,000 lbs Compression Load Button
    LBC-15K Capacity: 15,000 lbs Compression Load Button
    LBC-20K Capacity: 20,000 lbs Compression Load Button
    LBC-30K Capacity: 30,000 lbs Compression Load Button
    LBC-50K Capacity: 50,000 lbs Compression Load Button
    LBM-50 Capacity: 50 lbs Calibrated in Compression
    LBM-100 Capacity: 100 lbs Calibrated in Compression
    LBM-200 Capacity: 200 lbs Calibrated in Compression
    LBM-500 Capacity: 500 lbs Calibrated in Compression
    LBM-1K Capacity: 1,000 lbs Calibrated in Compression
    LBM-2K Capacity: 2,000 lbs Calibrated in Compression
    LBM-2.5K Capacity: 2,500 lbs Calibrated in Compression
    LBM-5K Capacity: 1,000 lbs Calibrated in Compression
    LBM-8K Capacity: 8,000 lbs Calibrated in Compression
    LBM-10K Capacity: 10,000 lbs Calibrated in Compression
上海轶舜国际贸易有限公司主要经营欧洲、美国、日本等厂家的工控机电设备、仪器仪表、泵阀、电线电缆及各种自动化产品的备品配件。经过长年的业务经验,积累了丰富的信息资源,使公司拥有了完善的技术查询系统及资深的技术人员,能保证为客户作…  更多>>
上海轶舜国际贸易有限公司
联系人:张兵
地址:上海市真南路1226弄康建商务广场8号楼202室
邮编:200333
电话:021-51872309
传真:021-51875868
公司网址:http://www.yishun.group
  • 安迪吕 在2024/12/18 23:34:00留言
  • 详细留言:在寻找stpi 续电器 245451
  • Jackie Jackie 在2024/11/15 23:35:00留言
  • 详细留言:Ins50 -120 mycom driver
  • 齐继旺 在2024/10/8 12:51:00留言
  • 详细留言:32轴卡:TURBO PMAC和TURBO PMAC2的报价单 本项目是用于工业检测
  • 支锋利 在2024/7/8 8:59:00留言
  • 详细留言:FIN538S1.150.M-ENERDOOR,有现货吗?
  • 于生 在2024/7/1 11:44:00留言
  • 详细留言:400ul 陶瓷定量泵 FMI
