霍尼韦尔(HONEYWELL)ML7421电动执行器,电动执行器调节控制,用于阀门系列: V5011, V5013, V5015, V5049, V5050,
V5095, V5328, V5329.
霍尼韦尔(HONEYWELL)ML7421电动执行器的详细介绍
ML7421执行器1800N 0/2..10V
电动执行器调节控制,用于阀门系列: V5011, V5013, V5015, V5049, V5050, V5095, V5328,
V5329.
霍尼韦尔电动执行器ML7421ML7420ML7425 霍尼韦尔西安代理
防护等级IP54
位置指示器刻度盘
控制信号丢失时的阀杆位置可选:关闭,半开,全开
阀杆强度1800N
电源24Vac | 12VA
控制输入信号0/2..10V; 0/4..20mA
手动操作是
位置的反馈信号2..10V
V5011P1012/ML7420A8088-SBE032
V5011P1020/ ML7420A8088-SBE040
V5011P1038/ML7420A8088-SBE050
V5328A1179/ML7420A8088-SBE065
V5328A1187/ ML7420A8088-SBE080
V5088A1005/ML7421B1023-SBE100
V5088A1013/ ML7421B1023-SBE125
V5088A1021/ML7421B1023-SBE150
型号
T6373BC1130
T6818DP08
T6800H2WN
T6861H2WB
VC6013AJC1000T
VN6013AJC1000T
VC6013APC1000T
VN6013APC1000T
VC6013MJ6000T
VC6013AFC1000T
电动蝶阀 (产地中国天津)
V4BFW16-050/OM-1-E
V4BFW16-065/OM-1-E
V4BFW16-080/OM-1-E
V4BFW16-100/OM-1-E
V4BFW16-125/OM-2-E
V4BFW16-150/OM-2-E
V4BFW16-200/OM-3-E
V4BFW16-250/OM-4-E
V4BFW16-300/OM-4-E
V4BFW16-350/OM-7-E
V4BFW16-400/OM-8-E
V4BFW16-450/OM-9-E
V4BFW16-500/OM-10-E
V4BFW16-600/OM-12-E
V4BFW16-050/OM-P1-E
V4BFW16-065/OM-P1-E
V4BFW16-080/OM-P1-E
V4BFW16-100/OM-P1-E
V4BFW16-125/OM-P2-E
V4BFW16-150/OM-P2-E
V4BFW16-200/OM-P3-E
V4BFW16-250/OM-P4-E
V4BFW16-300/OM-P4-E
V4BFW16-350/OM-P7-E
V4BFW16-400/OM-P8-E
V4BFW16-450/OM-P9-E
V4BFW16-500/OM-P10-E
V4BFW16-600/OM-P12-E
电动二通调节阀 座阀 冷水
V5011N1040/ML7420A8088-E
V5011N1057/ML7420A8088-E
V5011P1004/ML7420A8088-E
V5011P1012/ML7420A8088-E
V5011P1020/ML7420A8088-E
V5011P1038/ML7420A8088-E
V5211F1004/ML7420A8088-E
V5211F1012/ML7420A8088-E
V5328A1161/ML7420A8088-E
V5328A1179-E/ML7420A8088-E
V5328A1187-E/ML7420A8088-E
V5088A1005-E/ML7421B1023-E
V5088A1013-E/ML7421B1023-E
V5088A1021-E/ML7421B1023-E
电动二通调节阀 座阀 冷水
V5013P1002/ML7420A8088-E
V5013P1010/ML7420A8088-E
V5013P1028/ML7420A8088-E
V5329A2077/ML7420A8088-E
V5329A2085/ML7420A8088-E
V5050A2088/ML7421B1023-E
V5050A2106/ML7421B1023-E
V5050A2114/ML7421B1023-E
ML6420A3007-E
ML7420A8088-E
ML7421A1032-E
ML7421B1023-E
ML7425A8018-E
电动二通调节阀 座阀 蒸汽
V5011N2048/ML7420A8088-E
V5011N2055/ML7420A8088-E
V5011P2036/ML7420A8088-E
V5011P2002/ML7420A8088-E
V5011P2010/ML7420A8088-E
V5011P2028/ML7420A8088-E
V5211F2002/ML7421A1032-E
V5211F2010/ML7421A1032-E
V5328A2003/ML7420A8088-E
V5328A2011/ML7421A1032-E
V5328A2029/ML7421A1032-E
V5088A2003-E/ML7421B1023-E
V5088A2011-E/ML7421B1023-E
V5088A2029-E/ML7421B1023-E
CN7505A2001
CN7510A2001
CN7220A2007
CN7234A2008
CN6105A1011
CN6110A1004
CN6120A1002
CN6134A
电动调节球阀
VBA216-020P/CN7505A2001
VBA216-025P/CN7505A2001
VBA216-032P/CN7505A2001
VBA216-040P/CN7505A2001
VBA216-050P/CN7510A2001
VBA216-065P/CN7220A2007
VBA216-080P/CN7220A2007
VBA216-065F/CN7220A2007
VBA216-080F/CN7220A2007
VBA216-100F/CN7234A2008
VBA216-125F/CN7234A2008
VBA216-150F/CN7234A2008
VF20T
UB1211CH
P906C2004
V5032Y0015A
V5032Y0020A
V5032Y0025A
V5032Y0032A
V5032Y0040A
V5032Y0050A
V5032Y0065A
V5032Y0080A
V4SV065
V4SV080
V4SV100
V4SV125
V4SV150
V4SV200
V4SV250
V4SV300
V4SV350
DPCV-40A
DPCV-50A
DPCV-65A
DPCV-80A
DPCV-100A
DPCV-125A
DPCV-150A
DPCV-40B
DPCV-50B
DPCV-65B
DPCV-80B
DPCV-100B
DPCV-125B
DPCV-150B
有效阀门行程运行时间
20mm1,9minML7421A1032
38mm3,5minML7421B1023
附件
双重末端开关SPDT,可调(250 V~, 10 A)43191680-002
高温工具包用于:
V5011R/S, V5013R/E; V5328A/V5329A DN15..3243196000-001
V5016A/V5025A/V5050A DN15..80; V5049A DN15..65;
V5095ADN20..80;V5328A/V5329A DN40..8043196000-0
ML7425A弹簧复位电动阀门执行器,ML7425A电动阀门执行器可以弹簧复位。
ML7425A弹簧复位电动阀门执行器的详细介绍
霍尼韦尔M6410C/L M7410C电动小线性阀门执行器。M6410 M7410执行器180..300N 3-pt用于区域控制
电动执行器浮点控制,用于阀门系列: V5822, V5823, V5832, V5833。也用于V5077B/V5078B阀门系列(带有适配器)。
霍尼韦尔M6410C/L M7410C电动小线性阀门执行器的详细介绍
防护等级IP43/IP42
位置指示器红色指示器
端部开关功能/数值SPDT;1 A感应值, 5 A电阻
控制输入信号3-pt
有效阀行程6,5mm
运行时间150s;50Hz
附加描述用于M7410型号,阀门帽可用于手动调整。用于带有两个端部开关的型号, 2nd开关可调。
阀杆强度电源手动操作内置开关电缆长度
180N24Vac | 0,7VAno-1,5mM7410C1007
180N24Vac | 0,7VAno-3mM7410C-SL
300N24Vac | 0,7VAno-1,5mM7410C1015
180N24Vac | 0,7VAyes-1,5mM6410C2023
180N24Vac | 0,7VAyes11,5mM6410C3021
180N24Vac | 0,7VAyes21,5mM6410C4029
300N24Vac | 0,7VAyes-1,5mM6410C2031
300N24Vac | 0,7VAyes21,5mM6410C4037
180N230Vac | 7VAyes-1,5mM6410L2023
180N230Vac | 7VAyes21,5mM6410L4029
300N230Vac | 7VAyes-1,5mM6410L2031
300N230Vac | 7VAyes21,5mM6410L4037
附件
适配器用于阀门系列V5077B/V5078B0903403
霍尼韦尔M6061A,L旋转阀门执行器。M6061M7061标准线性旋转阀执行器电动执行器用于阀门系列V5421, V5431, V5441。
霍尼韦尔M6061A,L旋转阀门执行器的详细介绍
防护等级IP54
位置指示器可逆刻度盘
旋转角度90o
手动操作是
附加描述通过齿轮离合的手动操作。
浮点
扭矩电源控制输入信号位置的反馈信号运行时间
10Nm24Vac | 3,5VA3-pt可选1,5minM6061A1013
20Nm24Vac | 3,5VA3-pt可选1,6minM6061A1021
30Nm24Vac | 3,5VA3-pt可选2,3minM6061A1039
40Nm24Vac | 3,5VA3-pt可选3,5minM6061A1047
10Nm230Vac | 3,5VA3-pt可选1,5minM6061L1019
20Nm230Vac | 3,5VA3-pt可选1,6minM6061L1027
30Nm230Vac | 3,5VA3-pt可选2,3minM6061L1035
40Nm230Vac | 3,5VA3-pt可选3,5minM6061L1043
调节控制
10Nm24Vac | 2,4VA0/2..10V-1,5minM7061E1012
20Nm24Vac | 2,4VA0/2..10V-3,0minM7061E1020
附件用于浮点控制马达
反馈电位计10 kohmVMP10-90
辅助开关包VMS2
附件用于调节控制马达
位置0..10 V的反馈信号VMU1
反馈开关VRS1
霍尼韦尔M6063A,L旋转阀门执行器。M6063紧凑线性旋转阀执行器电动执行器用于阀门系列V5433A/G, V5442F/G。
M6063紧凑线性旋转阀执行器
防护等级IP44
端部开关功能/数值SPST;1A感应值, 3 A电阻
扭矩7Nm
控制输入信号3-pt
旋转角度90o
手动操作是
运行时间100s
电缆长度1,5m
附加描述通过齿轮离合的手动操作。
电源内置端部开关
24Vac | 3VA0M6063A1003
24Vac | 3VA2M6063A4007
230Vac | 3VA0M6063L1009
230Vac | 3VA2M6063L4003
M6063L的连杆用于替换M676A,C075041061
霍尼韦尔电动阀门驱动器/执行器ML7420。ML7420A执行器适用于霍尼韦尔HVAC阀门,内带一个选择正反作用插头,用于提供模拟输出0-10Vdc或2-10Vdc的调制控制。
霍尼韦尔电动阀门驱动器/执行器ML7420的详细介绍
ML7420A执行器适用于霍尼韦尔HVAC阀门,内带一个选择正反作用插头,用于提供模拟输出0-10Vdc或2-10Vdc的调制控制。ML7425A,B是弹簧返回的执行器。
特点*安装方便快捷。
*无需连杆。
*标准导管式接线连接。
*无需调整。
*阀门定位准确。
*低功耗。
*高的关断压力。
*终端推力限位开关。
* 0-10Vdc或2-10Vdc信号输入。
*带位置反馈信号输出。
*正反作用可选。
*同步马达。
*防腐设计。
*免维护。
电器特性
防护等级IP54
电源24Vac(正负15%)50Hz/60Hz
功耗7VA最大(24Vac)
轴杆推力600N
执行器行程20mm
输入信号0-10Vdc或2-10Vdc
信号源输出阻抗1千欧姆
负载最大1mA
环境温度负10°C至50°C
储存温度负40°C至70°C
最大阀介质温度150°C,若介质温度超过150°C,需用高温组件43196000-001/002,温度范围扩展到220°C。
湿度5-95%相对湿度(无结露)
隔离保护等级(24Vac)
认证标志UL94-5V防火符合CE要求
电缆接口两个标准的开孔位于执行器壳上
材料壳ABS-FR塑料
基座PGTP-FR塑料
支架铸造铝
重量1.3公斤
附加描述控制作用是可逆的。通过使用可用插头可以定义执行器参数。
座阀调节驱动器600N(DN80及以下口径阀用) ML7420A6033-E升级为ML7420A8088-E 24Vac 50/60Hz, Non-Spring Return, Modulating, 600N, 20mm
座阀调节驱动器1800N(DN80及以下口径阀用) ML7421A1032 C 24Vac 50/60Hz, Non-Spring Return, Modulating, 1800N, 20mm (for Combustion LoB only)
座阀调节驱动器1800N(DN100及以上口径用) ML7421B1023-E 24Vac 50/60Hz, Non-Spring Return, Modulating, 1800N, 38mm
座阀调节驱动器600N(弹簧自动复位) ML7425A6016-E 24Vac 50/60Hz, Spring Return, Modulating, 600N, 20mm
风阀驱动器,5NM,浮点型 用于DN40及以下口径 CN6105A1011
风阀驱动器,10NM,浮点型 用于DN50球阀 CN6110A1003
风阀驱动器,20NM,浮点型 用于DN65-80球阀 CN6120A1002
风阀驱动器,34NM,浮点型 DN100及以上口径 CN6134A1003
风阀驱动器,5NM,调节型 用于DN40及以下口径 CN7505A2001
风阀驱动器,10NM,调节型 用于DN50球阀 CN7510A2001
风阀驱动器,20NM,调节型 用于DN65-80球阀 CN7220A2007
风阀驱动器,34NM,调节型 DN100及以上口径
CN7234A2008
浮点型电动执行器 开关型 600N ML6420A3007-E
PI型电动执行器 调节型 600N ML7420A8088-E
PI型电动执行器 调节型 1800N ML7421A1032-E
PI型电动执行器 调节型 1800N ML7421B1023-E
PI型电动执行器 调节型 600N ML7425A8018-E
ML7420A6033-SBE025 Kombi-8 执行器配合 V5011P1004 DN25 ML7420A6033-SBE025
ML7420A6033-SBE032 Kombi-8 执行器配合 V5011P1012 DN32 ML7420A6033-SBE032
ML7420A6033-SBE040 Kombi-8 执行器配合 V5011P1020 DN40 ML7420A6033-SBE040
ML7420A6033-SBE050 Kombi-8 执行器配合 V5011P1038 DN50 ML7420A6033-SBE050
ML7420A6033-SBE065 Kombi-8 执行器配合 V5328A1179 DN65 ML7420A6033-SBE065
ML7420A6033-SBE080 Kombi-8 执行器配合 V5328A1187 DN80 ML7420A6033-SBE080
ML7421B1023-SBE100 Kombi-8 执行器配合 V5088A1005 DN100 ML7421B1023-SBE100
ML7421B1023-SBE125 Kombi-8 执行器配合 V5088A1013 DN125 ML7421B1023-SBE125
ML7421B1023-SBE150 Kombi-8 执行器配合 V5088A1021DN150 ML7421B1023-SBE150
