上海创弗实业有限公司
  • 倍加福OBR7500-R101-2EP-IO-0,3M-V1
  • 发布时间:2016/12/2 11:16:16   修改时间:2016/12/2 11:16:16 浏览次数:1574
  • OBR7500-R101-2EP-IO-0,3M-V1
    偏振滤波器反射传感器,具有多种安装选项的微型设计,扩展温度范围
    - 40°C…60°C、保护IP69K程度高,IO链路接口服务和过程数据,系列:R101,建筑类型(S2):微型住房,住房:PC(聚碳酸酯),光源类型:调制的可见红光,工作电压:10…30 V DC
    OBR7500-R101-2EP-IO-0,3M-V31
    Retroreflective sensor
    Retroreflective sensor with polarization filter, Miniature design with versatile mounting options, Extended temperature range
    -40°C ... 60°C, High degree of protection IP69K, IO-link interface for service and process data, Series: R101, Construction type(S2): Miniature housing, Housing: PC (Polycarbonate), Light type: modulated visible red light, Operating voltage: 10 ... 30 V DC
    OBR7500-R101-EP-IO-0,3M-V3
    OBR7500-R101-EP-IO-V3
    OBR7500-R101-P1-Y0429
    -40°C ... 60°C, High degree of protection IP69K, Series: R101, Construction type(S2): Miniature housing, Housing: PC (Polycarbonate), Light type: modulated visible red light, Operating voltage: 10 ... 30 V DC, Signal output: 1 push-pull (4 in 1) output, short-circuit protected, reverse polarity protected, overvoltage protected
    ML7-6/59/102/115/126b
    Retroreflective sensor for standard applications, miniature design, front optical face, 3.5 m detection range, red light, dark on, NPN output, weak signal output, fixed cable, Reliable sensor for standard applications, Miniature design with versatile mounting options, Automatic adjustment of sensitivity via TEACH-IN, Resistant against noise: reliable operation under all conditions, Certified by ECOLAB, Construction type(S2): Miniature housing, Housing: PC (glass-fiber-reinforced Makrolon)
    ML7-6/59/82b/103/143
    Retroreflective sensor for standard applications, miniature design, front optical face, 3.5 m detection range, red light, dark on, PNP output, weak signal output, M8 plug, Reliable sensor for standard applications, Miniature design with versatile mounting options, Automatic adjustment of sensitivity via TEACH-IN, Resistant against noise: reliable operation under all conditions, Certified by ECOLAB, Construction type(S2): Miniature housing, Housing: PC (glass-fiber-reinforced Makrolon)
    ML7-6/59/102/115
    Retroreflective sensor for standard applications, miniature design, front optical face, 3.5 m detection range, red light, dark on, NPN output, fixed cable, Reliable sensor for standard applications, Miniature design with versatile mounting options, Automatic adjustment of sensitivity via TEACH-IN, Resistant against noise: reliable operation under all conditions, Certified by ECOLAB, Construction type(S2): Miniature housing, Housing: PC (glass-fiber-reinforced Makrolon)
    ML7-6/59/102/126b/143
    Retroreflective sensor for standard applications, miniature design, front optical face, 3.5 m detection range, red light, dark on, NPN output, weak signal output, M8 plug, Reliable sensor for standard applications, Miniature design with versatile mounting options, Automatic adjustment of sensitivity via TEACH-IN, Resistant against noise: reliable operation under all conditions, Certified by ECOLAB, Construction type(S2): Miniature housing, Housing: PC (glass-fiber-reinforced Makrolon)
    ML7-6/59/102/143
    Retroreflective sensor for standard applications, miniature design, front optical face, 3.5 m detection range, red light, dark on, NPN output, M8 plug, Reliable sensor for standard applications, Miniature design with versatile mounting options, Automatic adjustment of sensitivity via TEACH-IN, Resistant against noise: reliable operation under all conditions, Certified by ECOLAB, Construction type(S2): Miniature housing, Housing: PC (glass-fiber-reinforced Makrolon)
    ML7-6/59/103/115
    Retroreflective sensor for standard applications, miniature design, front optical face, 3.5 m detection range, red light, dark on, PNP output, fixed cable, Reliable sensor for standard applications, Miniature design with versatile mounting options, Automatic adjustment of sensitivity via TEACH-IN, Resistant against noise: reliable operation under all conditions, Certified by ECOLAB, Construction type(S2): Miniature housing, Housing: PC (glass-fiber-reinforced Makrolon)
    ML7-6/59/103/143
    Retroreflective sensor for standard applications, miniature design, front optical face, 3.5 m detection range, red light, dark on, PNP output, M8 plug, Reliable sensor for standard applications, Miniature design with versatile mounting options, Automatic adjustment of sensitivity via TEACH-IN, Resistant against noise: reliable operation under all conditions, Certified by ECOLAB, Construction type(S2): Miniature housing, Housing: PC (glass-fiber-reinforced Makrolon)
    ML7-6/59/82b/103/115
    Retroreflective sensor for standard applications, miniature design, front optical face, 3.5 m detection range, red light, dark on, PNP output, weak signal output, fixed cable, Reliable sensor for standard applications, Miniature design with versatile mounting options, Automatic adjustment of sensitivity via TEACH-IN, Resistant against noise: reliable operation under all conditions, Certified by ECOLAB, Construction type(S2): Miniature housing, Housing: PC (glass-fiber-reinforced Makrolon)
    ML71-6/59/102/143
    Retroreflective sensor for standard applications, miniature design, side optical face, 3.5 m detection range, red light, dark on, NPN output, M8 plug, Reliable sensor for standard applications, Miniature design with front optical face, Automatic adjustment of sensitivity via TEACH-IN, Resistant against noise: reliable operation under all conditions, Certified by ECOLAB, Construction type(S2): Miniature housing, Housing: PC (glass-fiber-reinforced Makrolon), Light type: modulated visible red light
上海创弗实业有限公司,坐落于拥有深厚近代城市文化底蕴的国际金融中心上海。公司业务范围涉及自动化产品销售、技术咨询、技术服务,承接过程仪表控制项目等。公司以诚信为宗旨,以服务为主导、努力为客户提供完善的技术支持、售后服务,并承接…  更多>>
上海创弗实业有限公司
联系人:杨阳
地址:上海市松江区路888号
邮编:201615
电话:021-67742215
公司网址:http://www.chuangfushiye.com
  • 蒋女士 在2022/8/17 14:32:00留言
  • 详细留言:AB8E10+LE50.1/WHZ 定制连接支架,OPEN/CLOSE:37KNm,直行程、调节型,400VAC,IP67 2台
  • 梁先生 在2020/12/11 16:11:00留言
  • 详细留言:讯价,SCHIEBELA-1230电动执行机构的价格,力矩2580N.M的。
  • 朱建军 在2020/1/26 8:52:00留言
  • 详细留言:SCHIEBEL A1230Wien电机过热故障 技术咨询
  • 陈工 在2019/4/4 18:26:00留言
  • 详细留言:西贝 SCHIEBEL A-1230 执行机构
  • 严丽 在2018/8/24 10:12:00留言
  • 详细留言:你好 可以加我微信联系我
