上海创弗实业有限公司
  • 倍加福RLK28-8-H-2000-IR-Z/31/116
  • 发布时间:2016/12/2 11:27:09   修改时间:2016/12/2 11:27:09 浏览次数:1867
  • RLK28-8-H-2000-IR-Z/31/116
    背景抑制传感器
    背景抑制传感器,通用系列具有高度通用的使用领域,抗噪声:在所有条件下可靠运行,通过红外传输LED最小的黑白差异,可编程时间功能GAN,GAB,IAB和GAN-IAB作为双重功能, 通用电压型号,结构类型(S2):矩形类型,外壳:塑料ABS,光类型:调制红外光,880 nm工作电压:12 ... 240 V AC / DC,信号输出:继电器,
    RL28-8-H-2000-IR/105/110
    RL28-8-H-2000-IR/47/105
    Background suppression sensor
    Background suppression sensor, Ultra bright LEDs for power on and switching state, Minimal black-white difference through the infrared transmission LED, Not sensitive to ambient light, even with energy saving lamps, Waterproof, degree of protection IP67, Protection class II, Construction type(S2): Rectangular type, Housing: Plastic ABS, Light type: modulated infrared light , 880 nm, Operating voltage: 10 ... 30 V DC
    RL39-8-2000/32/40a/82a/116
    Diffuse mode sensor
    Diffuse mode sensor, Infrared light, Light/dark ON, switchable, Degree of protection IP67, Construction type(S2): Rectangular type, Housing: PBT, Light type: modulated infrared light, Operating voltage: 10 ... 30 V DC, Signal output: 1 PNP output, short-circuit protected, reverse polarity protected, open collector, Connection: terminal compartment PG9, ≤ 2.5 mm2, Degree of protection: IP67
    GLV30-LL-1227/40a/53/92
    Diffuse mode sensor
    Diffuse mode sensor, M30 nickel plated brass threaded housing, Light/dark switching, For glass fibre light guide, Extensive fiber optic product selection as accessories, Construction type(S2): Threading M30, Housing: brass, nickel-plated, Light type: modulated infrared light, Operating voltage: 10 ... 30 V DC, Signal output: 1 PNP, not short-circuit protected, Connection: 4-pin, M12 metal connector
    RL23-8-H-2000-IR/104/116/125
    Background suppression sensor, Adjustable background suppression, Infrared light, Timer function, Sturdy plastic housing, Optical surface made of scratch-resistant glass, Construction type(S2): Rectangular type, Housing: Terluran? GV15, Light type: modulated infrared light, Operating voltage: 10 ... 30 V DC, Signal output: 2 PNP, complementary, 1 NPN short-circuit protected, reverse polarity protected, Connection: terminal compartment, Degree of protection: IP65
    RL23-8-H-2000-IR/116/125
    RL23-8-H-2000-IR/47/74a
    Background suppression sensor, Adjustable background suppression, Infrared light, Timer function, Sturdy plastic housing, Optical surface made of scratch-resistant glass, Construction type(S2): Rectangular type, Housing: Terluran? GV15, Light type: modulated infrared light, Operating voltage: 10 ... 30 V DC, Signal output: 2 PNP, complementary, short-circuit protected, reverse polarity protected, Connection: Connector M18 x 1, 4-pin with unwired angled cable socket
    RL23-8-H-2000-IR/47/92
    Background suppression sensor, Adjustable background suppression, Infrared light, Timer function, Sturdy plastic housing, Optical surface made of scratch-resistant glass, Construction type(S2): Rectangular type, Housing: Terluran? GV15, Light type: modulated infrared light, Operating voltage: 10 ... 30 V DC, Signal output: 2 PNP, complementary, short-circuit protected, reverse polarity protected, Connection: 4-pin, M12 x 1 connector, Degree of protection: IP65
    RL23-8-H-2000-IR/47/92/104
    RL23-8-H-2000-IR/49/92
    RL28-8-H-1500-LAS-4301/47/105
    Background suppression sensor, Universal series with highly versatile fields of use, Resistant against noise: reliable operation under all conditions, Laser version for long ranges, Small light beam diameter for detection of small parts, Construction type(S2): Rectangular type, Housing: Plastic ABS, Light type: modulated visible red light, Operating voltage: 10 ... 30 V DC, Signal output: 2 PNP outputs, complementary, short-circuit protected, reverse polarity protected, open collector
    RL28-8-H-1500-LAS/105/110
    Background suppression sensor, Universal series with highly versatile fields of use, Resistant against noise: reliable operation under all conditions, Laser version for long ranges, Small light beam diameter for detection of small parts, Construction type(S2): Rectangular type, Housing: Plastic ABS, Light type: modulated visible red light, Operating voltage: 10 ... 30 V DC, Signal output: 1 push-pull (4 in 1) output, short-circuit protected, reverse polarity protected
    RL28-8-H-1500-LAS/47/105
    RL28-8-H-2000-IR-3974/47/112
    Background suppression sensor, Ultra bright LEDs for power on and switching state, Minimal black-white difference through the infrared transmission LED, Not sensitive to ambient light, even with energy saving lamps, Waterproof, degree of protection IP67, Extra vibration proof version, Construction type(S2): Rectangular type, Housing: Plastic ABS, Light type: modulated infrared light , 880 nm, Operating voltage: 10 ... 30 V DC
    RL28-8-H-2000-IR-Z/110/116
    Background suppression sensor, Ultra bright LEDs for power on and switching state, Minimal black-white difference through the infrared transmission LED, Programmable time function GAN, GAB, IAB and GAN-IAB as double function, Not sensitive to ambient light, even with energy saving lamps, Waterproof, degree of protection IP67, Construction type(S2): Rectangular type, Housing: Plastic ABS, Light type: modulated infrared light , 880 nm, Operating voltage: 10 ... 30 V DC
    RL28-8-H-2000-IR-Z/49/112
    RL28-8-H-2000-IR/110/115
    RL28-8-H-2000-IR/47/105/106
    Background suppression sensor, Universal series with highly versatile fields of use, Resistant against noise: reliable operation under all conditions, Minimal black-white difference through the infrared transmission LED, Version with heated front panel, Construction type(S2): Rectangular type, Housing: Plastic ABS, Light type: modulated infrared light , 880 nm, Operating voltage: 24 V DC ± 20 %
    RL28-8-H-2000-IR/47/115
    RL28-8-H-2000-IR/49/105
    RL28-8-H-2000-IR/49/115
    RL29-8-2000/115b/136
    Diffuse mode sensor
    Diffuse mode sensor, plastic housing, 2000 mm adjustable detection range, red light, light on, 2 push-pull outputs, fixed cable with M12 plug, Highly visible LED, Good alignability due to red transmission LED, Powerful push-pull output, Optimal price/power ratio, Protection class II, Construction type(S2): Rectangular type, Housing: Plastic ABS, Light type: modulated visible red light , 660 nm, Operating voltage: 10 ... 30 V DC
    RL29-8-2000/59/73c/136
    Diffuse mode sensor
    Diffuse mode sensor, Highly visible LED, Good alignability due to red transmission LED, Powerful push-pull output, Optimal price/power ratio, Protection class II, Construction type(S2): Rectangular type, Housing: Plastic ABS, Light type: modulated visible red light, Operating voltage: 10 ... 30 V DC , class 2, Signal output: 2 push-pull (4 in 1) outputs, short-circuit protected, reverse polarity protected, Connection: Plastic connector M12 x 1, 4-pin, Detection range: 20 ... 2000 mm , adjustable
    RL29-8-2000/73c/136
    Diffuse mode sensor
    Diffuse mode sensor, plastic housing, 2000 mm adjustable detection range, red light, light on, 2 push-pull outputs, M12 plug, Highly visible LED, Good alignability due to red transmission LED, Powerful push-pull output, Optimal price/power ratio, Protection class II, Construction type(S2): Rectangular type, Housing: Plastic ABS, Light type: modulated visible red light , 660 nm, Operating voltage: 10 ... 30 V DC
    RL36-8-2000-Ex/40b/116
    Diffuse mode sensor
    Diffuse mode sensor, NAMUR, large housing design, 2000 mm detection range, infrared light, light/dark on, DC version, NAMUR output, terminal compartment, ATEX approval for zone 1 (Gas), Intrinsically safe, Ex op is ia IIC T4 Gb, Resistant against noise, Diffuse mode sensor for standard applications, Construction type(S2): Rectangular type, Housing: PMMA, Light type: modulated infrared light, Operating voltage: 6 ... 20 V DC (Ri approx. 0 Ohm), Signal output: 1 NAMUR output NC/NO programmable
    RL39-8-2000/30/40a/116/126a
    Diffuse mode sensor
    Diffuse mode sensor, Infrared light, Light/dark ON, switchable, Degree of protection IP67, Construction type(S2): Rectangular type, Housing: PBT, Light type: modulated infrared light, Operating voltage: 10 ... 30 V DC, Signal output: 1 NPN output, short-circuit protected, reverse polarity protected, open collector, Connection: terminal compartment PG9, ≤ 2.5 mm2, Degree of protection: IP67
    RL39-8-2000/32/40a/73c/82a
    Diffuse mode sensor
    Diffuse mode sensor, Infrared light, Light/dark ON, switchable, Degree of protection IP67, Construction type(S2): Rectangular type, Housing: PBT, Light type: modulated infrared light, Operating voltage: 10 ... 30 V DC, Signal output: 1 PNP output, short-circuit protected, reverse polarity protected, open collector, Connection: 4-pin, M12 x 1 connector, Degree of protection: IP67
    RL61-8-H-2000-IR-Z/115/136
    Background suppression sensor, Cost-optimized series for standard tasks in a special design, Compact design, Wide range of mounting options thanks to cubic housing design with M30 thread, 360° high visibility LEDs, Programmable ON-delay, OFF-delay, and One-shot timers, Construction type(S2): Rectangular type, Housing: PC (Polycarbonate), Light type: modulated infrared light , 850 nm, Operating voltage: 10 ... 30 V DC
    RLK23-8-H-2000-IR/31/104/116
    Background suppression sensor, Adjustable background suppression, Infrared light, Timer function, Sturdy plastic housing, Optical surface made of scratch-resistant glass, Construction type(S2): Rectangular type, Housing: Terluran? GV15, Light type: modulated infrared light, Operating voltage: 12 ... 240 V AC , 10 ... 30 V DC (automatic adaption to +UB), Signal output: 1 relay output, 1 alternator, Connection: terminal compartment, Degree of protection: IP65
    RLK23-8-H-2000-IR/31/116
    RLK39-8-2000-Z/31/40a/116
    Diffuse mode sensor
    Diffuse mode sensor, Infrared light, Light/dark ON, switchable, Timer function, Degree of protection IP67, Construction type(S2): Rectangular type, Housing: PBT, Light type: modulated infrared light, Operating voltage: 12 ... 240 V DC
    24 ... 240 V AC (50 ... 60 Hz), Signal output: 1 relay output, Connection: terminal compartment PG9, ≤ 2.5 mm2, Degree of protection: IP67
    RLK39-8-2000/31/40a/116
    Diffuse mode sensor
    Diffuse mode sensor, Infrared light, Light/dark ON, switchable, Degree of protection IP67, Construction type(S2): Rectangular type, Housing: PBT, Light type: modulated infrared light, Operating voltage: 12 ... 240 V DC
    RLK61-8-H-2000-IR-Z/31/115
    RL23-8-H-2000-IR/47/74a/104
    RL23-8-H-2000-IR/49/92/104
    RL28-8-H-1500-LAS/47/115b
    RL28-8-H-2000-IR-3019/47/115b
    Background suppression sensor, Ultra bright LEDs for power on and switching state, Minimal black-white difference through the infrared transmission LED, Not sensitive to ambient light, even with switched energy saving lamps, Waterproof, degree of protection IP67, Protection class II, Construction type(S2): Rectangular type, Housing: Plastic ABS, Light type: modulated infrared light , 880 nm, Operating voltage: 10 ... 30 V DC
    RL28-8-H-2000-IR-Z/47/112
    RL28-8-H-2000-IR-Z/47/116
    RL28-8-H-2000-IR-Z/49/116
    RL28-8-H-2000-IR/47/73c
    RL28-8-H-2000-IR/47/74
    RL28-8-H-2000-IR/49/74
    RL61-8-H-2000-IR-Z/92/136
    RLK23-1482
    RLK61-8-H-2000-IR-Z/31/135
上海创弗实业有限公司,坐落于拥有深厚近代城市文化底蕴的国际金融中心上海。公司业务范围涉及自动化产品销售、技术咨询、技术服务,承接过程仪表控制项目等。公司以诚信为宗旨,以服务为主导、努力为客户提供完善的技术支持、售后服务,并承接…  更多>>
上海创弗实业有限公司
联系人:杨阳
地址:上海市松江区路888号
邮编:201615
电话:021-67742215
公司网址:http://www.chuangfushiye.com
  • 蒋女士 在2022/8/17 14:32:00留言
  • 详细留言:AB8E10+LE50.1/WHZ 定制连接支架,OPEN/CLOSE:37KNm,直行程、调节型,400VAC,IP67 2台
  • 梁先生 在2020/12/11 16:11:00留言
  • 详细留言:讯价,SCHIEBELA-1230电动执行机构的价格,力矩2580N.M的。
  • 朱建军 在2020/1/26 8:52:00留言
  • 详细留言:SCHIEBEL A1230Wien电机过热故障 技术咨询
  • 陈工 在2019/4/4 18:26:00留言
  • 详细留言:西贝 SCHIEBEL A-1230 执行机构
  • 严丽 在2018/8/24 10:12:00留言
  • 详细留言:你好 可以加我微信联系我
