上海御林信息科技有限公司
  • MHM-6200-CBNS-0000
  • 发布时间:2018/8/8 10:25:39   修改时间:2014/3/12 10:12:24 浏览次数:2378
  • 9500-8608
    9500-8608WE
    9500-8609 Quantum
    9500-8609WE Extends
    9500-8610WE Extends
    9500-8611 Quantum III
    9500-8611WE Extends
    9500-8615
    9500-8615WE
    9500-8616
    9500-8616WE
    9500-8617
    9500-8617WE
    9500-8618
    9500-8618WE
    9500-8619
    9500-8619WE
    9500-8620
    9500-8620WE
    9500-9032 50 Amp Field Regulator
    9500-9033 90 Amp Field Regulator
    9500-9035 20 Amp Field Regulator (FXM-5)
    9500-9100 Modbus Plus interface card (Mentor II, Quantum III)
    95DSA300CAAAA
    95DSA300HAAAA
    95DSA301CAAAA
    95DSA301HAAAA
    95DSB300CAAAA
    95DSB300HAAAA
    95DSB301CAAAA
    95DSB301HAAAA
    95DSC300CAAAA
    95DSC300HAAAA
    95DSC301CAAAA
    95DSC301HAAAA
    95DSD300CAAAA
    95DSD300HAAAA
    95DSD301CAAAA
    95DSD301HAAAA
    95DSE300CAAAA
    95DSE300HAAAA
    95DSE301CAAAA
    95DSE301HAAAA
    95EZB300CACAA
    95EZB301CACAA
    95EZD300CACAA
    95EZD301CACAA
    95UMB300CACAA
    95UMB301CACAA
    95UMD300CACAA
    95UMD301CACAA
    960304-01 AC
    960305-01 AC
    960307-01
    9650-8268
    9650-8348
    9729-9000
    9729-9001  l
    9729-9003 MD29 with Spindle orientation
    9729-9004 MD29 with CTCW - Constant tension, center wind
    9729-9005 MD29 with PID control for load cell tension or dancer position
    9729-9006 MD29 with Power calculator
    9729-9008 MD29 with Dual Mode Winder
    9729-9501 MD29AN-RevD with S-ramp accel/decel profiling
    9729-9502 MD29AN-RevD with Digital lock with adjustable ratio control
    9729-9503 MD29AN-RevD with Spindle orientation
    9729-9504 MD29AN-RevD with CTCW - Constant tension, center wind
    9729-9505 MD29AN-RevD with PID control for load cell tension or dancer position
    9729-9506 MD29AN-RevD with Power calculator
    9729-9508 MD29AN-RevD with Dual Mode Winder
    ALP-130 30 watt auxiliary logic backup power supply, supports one EN Drive
    ALP-430 4x20 watt auxiliary logic backup power supply, supports four EN Drives
    AX-2000-00-00-00C Axima 2000, 2 axis controller w/ 2 auxiliary encoder inputs
    AX-4000-00-00-00C
    AX4-CEN-002 C
    AX4-CEN-004
    AX4-CEN-010
    AX4-CEN-A-xxx
    AX4-ED-005
    AX4-ED-010
    AX4-ED-015
    AX4-ED-xxx
    AX4-ENC-015
    AX4-ENC-025
    AX4-ENC-050
    AX4-ENC-xxx
    AX4-GP-005
    AX4-GP-010
    AX4-GP-015
    AX4-GP-xxx
    AX4-MX-005
    AX4-MX-010
    AX4-MX-015
    AX4-MX-xxx
    AX4-XIOC-000.5
    AX4-XIOC-001.5
    AXIMA
    AXIMA-00-00-0-X0 (X=1)
    AXIMA-00-00-1-00 (X=1)
    AXIMA-00-XX-0-00 (XX=0D)
    AXIMA-00-XX-0-00 (XX=0M)
    AXIMA-02-00
    AXIMA-04-00
    AXIMA-06-00 Axima Classic Base Controller, 6 Axis
    AXIMA-08-00 Axima Classic Base Controller, 8 Axis
    DSC-006 Connector on both ends, 6 ft Length
    DSC-010 Connector on both ends, 10 ft Length
    DXE-208C
    DXE-208C-090
    DXE-208CB
    DXE-208CB-090
    DXE-316C DX 3"
    DXE-316CB DX 3"
    DXE-316W DX 3"
    DXE-316WB DX 3
    DXE-4120C DX 4"
    DXE-4120CB DX 4"
    DXE-4120W DX 4"
    DXE-4120WB DX
    DXE-455C DX 4"
    DXE-455CB DX
    DXE-455W DX 4"
    DXE-455WB DX
    DXE-490C DX 4"
    DXE-490CB DX 4"
    DXE-490W DX 4"
    DXE-490WB DX 4"
    DXM-208C DX 2"
    DXM-208C-090 DX 2
    DXM-208CB-090 DX 2
    DXM-316C DX 3"
    DXM-316CB DX 3"
    DXM-316W DX 3"
    DXM-316WB DX 3"
    DXM-340C DX 3"
    DXM-340CB DX 3"
    DXM-340W DX 3"
    DXM-340WB DX 3"
    DXM-4120C DX 4"
    DXM-4120CB DX 4"
    DXM-4120W DX 4"
    DXM-4120WB DX 4"
    DXM-455C DX 4"
    DXM-455CB DX 4"
    DXM-455W DX 4"
    DXM-455WB DX 4"
    DXM-490C DX 4"
    DXM-490CB DX 4"
    DXM-490W DX 4"
    DXM-490WB DX 4"
    DXM-6120W DX 6"
    DXM-6120WB DX 6"
    F3ACT AC Tachometer Input Board
    F3DB0524 Dynamic Braking Kit, 0.5hp @ 240V
    F3DB112 Dynamic Braking Kit, 0.75 to 1hp @ 120V
    F3DB124 Dynamic Braking Kit, 0.75 to 1hp @ 240V
    F3DB1524 Dynamic Braking Kit, 0.25 to 0.33hp @ 120V & 1.5hp @ 240V
    F3DB224 Dynamic Braking Kit, 0.5hp @ 120V & 2hp @ 240V
    F3DB324 Dynamic Braking Kit, 3hp @ 240V
    F3DB524 Dynamic Braking Kit, 5hp @ 240V
    F3LE Large (5hp), NEMA 4/12 enclosure kit
    F3M112 "M" Contactor Kit, 0.25 to 1hp @ 120V
    F3M224 "M" Contactor Kit, 0.50 to 2hp @ 240V
    F3M524 "M" Contactor Kit, 3 to 5hp @ 240V
    F3N2C Focus 3, 1/4 to 2hp, 120/240V-1? input, Open Chassis, Non-Regen
    F3N2E Focus 3, 1/4 to 2hp, 120/240V-1? input, NEMA 4/12, Non-Regen
    F3N5C Focus 3, 3 to 5hp, 240V-1? input, Open Chassis, Non-Regen
    F3N5E Focus 3, 3 to 5hp, 120/240V-1? input, NEMA 4/12, Non-Regen
    F3NSBD Signal Isolation Board
    F3R2C Focus 3, 1/4 to 2hp, 120/240V-1? input, Open Chassis, Regen
    F3R2E Focus 3, 1/4 to 2hp, 120/240V-1? input, NEMA 4/12, Regen
    F3R5C Focus 3, 3 to 5hp, 240V-1? input, Open Chassis, Regen
    F3R5E Focus 3, 3 to 5hp, 120/240V-1? input, NEMA 4/12, Regen
    F3SE Small (2hp), NEMA 4/12 enclosure kit
    F3TS Contains 1 each of the following Toggle Switches: Run / Jog, Forward / Reverse (regen only) and Auto / Manual
    FK6S-120 BL and DX 6xxx Series, 6" motor
    FK8K-120 BL and DX 8xxx Series, 8" motor
    FM-2 FM-2, Indexing Module
    FM-3 FM-3, Programming Module
    FM-3DN FM-3DN, Programming Module with DeviceNet
    FM-3E FM-3E, Programming Module with Ethernet
    FM-3PB FM-3PB, Programming Module with Profibus
    FM-4 FM-4, Advanced Programming Module
    FM-4DN FM-4DN, Advanced Programming Module with DeviceNet
    FM-4E FM-4E, Advanced Programming Module with Ethernet
    FM-4PB FM-4PB, Advanced Programming Module with Profibus
    FS 6376-16-07 IP66 RFI filter, Commander SX Series
    FX-208
    FX-208CE
    FX-316
    FX-316CE
    FX-340 FX
    FX-340CE FX
    FX-4120 FX S
    FX-4120CE
    FX-455 FX
    FX-455CE
    FX-490
    FX-490CE
    FX-6120
    FX-6120CE k
    FX-6210
    FX-6310
    FX-81000
    FX-8500
    FX-8800
    FXM5-UG 9500-9035
    GP1WE Extends
    GP2WE Extends
    GP3WE Extends
    GPD1203LV
    GPD1204LV
    GPD1205LV
    GPD1401  1
    GPD1402
    GPD1403
    GPD1404
    GPD1405
    GPD2201LV
    GPD2202LV
    GPD2203LV
    GPD2401
    GPD2402
    GPD2403 C
    GPD3201LV
    GPD3202LV
    GPD3203LV
    GPD3204LV
    GPD3401
    GPD3402
    GPD3403 C
    GPD3404
    GPD3405
    GPD4401
    GPD4402 C
    GPD4403
    GPD4404
    GPD4405
    IAC-24-G4 A
    IBC-006
    IBC-010
    IBC-ECE-xxx External IBS to IBS
    IBC-ICE-xxx Internal IBS to IBS
    IBC-xxx Connector at both ends, Custom Length - 1 ft increments
    IBS-11 InterBus-S Motion Controller
    IBS-15 InterBus-S Ratio Controller w/ Analog I/O
    IDC-24-G4 DC input module for use w/ XIOR-32 (10-32 VDC)
    IM/0022/KI Spare incremental encoder feedback mating connector: for 75-190 frame motors
    IM/0023/KI Spare sincos or resolver feedback mating connector: for 75-190 frame motors
    IM/0039/KI Spare power mating connector: for 75-142 frame motors
    IM/0053/KI Spare power mating connector: for 190A&B frame motors, rated at 54 Amps
    IM/0054/KI
    IOM-1 Input / Output Expander Module
    JMP-12 I/O Jumper Strip (Qty 10)
    LDR2-L-004-C
    LDR2-L-006-C
    LDR2-L-010-C
    LDR2-L-015-C
    LDR2-L-022-C
    LDR2-L-028-C  s
    LDR2-L-042-C s
    LDR2-L-054-C
    LDR2-L-068-C O
    LDR2-L-080-C
    LDR2-L-104-C  s
    LDR2-L-130-C
    LDR2-L-154-C
    LDR2-L-192-C
    LDR2-L-248-C
    LDR2-L-312-C
    LDR2-L-360-C
    LDR2-L-480-C
    LDR4-L-003-C
    LDR4-L-005-C
    LDR4-L-008-C
    LDR4-L-011-C
    LDR4-L-014-C
    LDR4-L-021-C
    LDR4-L-027-C
    LDR4-L-034-C
    LDR4-L-040-C
    LDR4-L-052-C
    LDR4-L-065-C
    LDR4-L-077-C
    LDR4-L-096-C
    LDR4-L-124-C
    LDR4-L-156-C
    LDR4-L-180-C
    LDR4-L-240-C
    LDR4-L-302-C
    LDR5-L-006-C
    LDR5-L-009-C
    LDR5-L-011-C
    LDR5-L-017-C
    LDR5-L-022-C
    LDR5-L-027-C
    LR2-L-010-C
    LR2-L-015-C
    LR2-L-022-C
    LR2-L-028-C
    LR2-L-042-C
    LR2-L-054-C
    LR2-L-068-C
    LR2-L-080-C
    LR2-L-104-C
    LR2-L-130-C
    LR2-L-154-C
    LR2-L-192-C
    LR2-L-248-C
    LR2-L-312-C
    LR2-L-360-C
    LR2-L-480-C
    LR4-L-005-C
    LR4-L-008-C
    LR4-L-011-C
    LR4-L-014-C
    LR4-L-021-C
    LR4-L-027-C
    LR4-L-034-C
    LR4-L-040-C
    LR4-L-052-C
    LR4-L-065-C
    LR4-L-077-C
    LR4-L-096-C
    LR4-L-124-C
    LR4-L-156-C
    LR4-L-240-C
    LR4-L-302-C I is
    LR4-L-361-C
    LR4-L-414-C
    LR4-L-477-C
    LR5-L-009-C
    LR5-L-011-C
    LR5-L-017-C
    LR5-L-022-C  s
    LR5-L-027-C
    M105-14M
    M105R-14M c
    M105WE
    M1200-14M c
    M1200-14M660 c
    M1200R-14M c
    M1200R-14M660 c
    M1200WE c
    M155-14M c
    M155R-14M
    M155WE
    M1850-14M
    M1850-14M660
    M1850R-14M660
    M1850WE
    M210-14M
    M210R-14M
    M210WE Extends
    M25-14M Mentor I n
    M25R-14M Mentor
    M25WE
    M350-14M Mentor
    M350-14M660
    M350R-14M
    M350R-14M660
    M420-14M660
    M420R-14M
    M420R-14M660
    M420WE
    M45-14M
    M45R-14M
    M45WE
    M550-14M
    M550-14M660
    M550R-14M
    M550R-14M660
    M550WE
    M700-14M
    M700-14M660
    M700R-14M
    M700R-14M660
    M700WE
    M75-14M
    M75R-14M
    M75WE
    M825-14M
    M825-14M660
    M825R-14M
    M825R-14M660 uired)
    M825WE
    M900-14M
    M900-14M660
    M900R-14M
    M900R-14M660
    M900WE
    MC202-00-000
    MC206-00-000
    MC224-00-000
    MD02R-04
    MD03R-02.
    MD-24
    MD24-UG MD-24
    MD-25
    MD25-UG MD-25
    MD-29AN MD29
    MD-29AN-RevD MD29
    MD-404-00-000
    MD-407-00-000 ses
    MD-410-00-000
    MD-420-00-000
    MDIBS
    MDIBS-UG
    MentorSoft
    MENTOR-UG
    MF-1250-20
    MF-2500-35
    MF-5000-65
    MFG-1
    MGE-205-CBNS-0000
    MGE-205-CONS-0000
    MGE-208-CBNS-0000
    MGE-208-CONS-0000
    MGE-316-CBNS-0000
    MGE-316-CONS-0000
    MGE-340-CBNS-0000
    MGE-340-CONS-0000
    MGE-4120-CBNS-0000
    MGE-4120-CONS-0000
    MGE-455-CBNS-0000
    MGE-455-CONS-0000
    MGE-490-CBNS-0000
    MGE-490-CONS-0000
    MGM-205-CBNS-0000
    MGM-205-CONS-0000
    MGM-208-CBNS-0000
    MGM-208-CONS-0000
    MGM-316-CBNS-0000
    MGM-316-CONS-0000
    MGM-340-CBNS-0000
    MGM-340-CONS-0000
    MGM-4120-CBNS-0000
    MGM-4120-CONS-0000
    MGM-455-CBNS-0000
    MGM-455-CONS-0000
    MGM-490-CBNS-0000
    MGM-490-CONS-0000
    MHE-316-CBNS-0000
    MHE-316-CONS-0000
    MHE-340-CBNS-0000
    MHE-340-CONS-0000
    MHE-455-CBNS-0000
    MHE-455-CONS-0000
    MHE-490-CBNS-0000
    MHE-490-CONS-0000
    MHM-316-CBNS-0000
    MHM-316-CONS-0000
    MHM-340-CBNS-0000
    MHM-340-CONS-0000
    MHM-6200-CBNS-0000
    MHM-6200-CONS-0000
    MHM-6300-CBNS-0000
    MHM-6300-CONS-0000
    MHM-8250-CBNS-0000
    MHM-8250-CONS-0000
    MHM-8500-CBNS-0000
    MLP-010-00
    MLR-2580-00
    MNT2N100HP-N1
    MNT2N100HP-N12
    MNT2N10HP-N1
    MNT2N10HP-N12
    MNT2N125HP-N1
    MP-1250-00-000
    MP-2500-00-000
    MP-5000-00-000
    MPF-002-00
    MPF-003-00
    NTE-207-CBNS-0000
    NTE-207-CONS-0000
    NTE-207-LBNS-0000
    NTE-207-LONS-0000
    NTE-207-TBNS-0000
    NTE-207-TONS-0000
    NTE-212-CBNS-0000
    NTE-212-CONS-0000
    NTE-212-LBNS-0000
    NTE-212-LONS-0000
    NTE-212-TBNS-0000
    NTE-212-TONS-0000
    NTE-320-CBNS-0000
    NTE-320-CONS-0000
    NTE-320-LBNS-0000
    NTE-320-LONS-0000
    NTE-320-TBNS-0000
    NTE-320-TONS-0000
    NTE-330-CBNS-0000
    NTE-330-CONS-0000
    NTE-330-LBNS-0000
    NTE-330-LONS-0000
    NTE-330-TBNS-0000
    NTE-330-TONS-0000
    NTE-345-CBNS-0000
    NTE-345-CONS-0000
    NTE-345-LBNS-0000
    NTE-345-LONS-0000
    NTE-345-TBNS-0000
    NTE-345-TONS-0000
    NTE-355-CBNS-0000
    NTE-355-CONS-0000
    NTE-355-LBNS-0000
    NTE-355-LONS-0000
    NTE-355-TONS-0000
    NTM-207-CBNS-0000
    NTM-207-CONS-0000
    NTM-207-LBNS-0000
    NTM-207-LONS-0000
    NTM-207-TBNS-0000
    NTM-207-TONS-0000
    NTM-212-CBNS-0000
    NTM-212-CONS-0000
    NTM-212-LBNS-0000  e
    NTM-212-LONS-0000
    NTM-212-TBNS-0000
    NTM-212-TONS-0000
    NTM-320-CBNS-0000
    NTM-320-CONS-0000
    NTM-320-LBNS-0000
    NTM-320-LONS-0000
    NTM-320-TBNS-0000
    NTM-320-TONS-0000
    NTM-330-CONS-0000
    NTM-330-LBNS-0000
    NTM-330-LONS-0000
    NTM-330-TONS-0000
    NTM-345-CBNS-0000
    NTM-345-CONS-0000
    NTM-345-LBNS-0000 N
    NTM-345-LONS-0000
    NTM-345-TBNS-0000
    NTM-345-TONS-0000
    NTM-355-CBNS-0000
    NTM-355-CONS-0000
    NTM-355-LBNS-0000
    NTM-355-LONS-0000
    NTM-355-TBNS-0000
    NTM-355-TONS-0000
上海御林信息科技有限公司 公司主要从事PLC&DCS,仪器仪表,传动电气设备,机电产品的销售以及工业自动化产品系统集成方案。公司与国内外众多知名品牌供应商建立有极其良好的合作关系,在欧美,东南亚,中东,非洲,大洋洲等地形成了稳定、高效的…  更多>>
上海御林信息科技有限公司
联系人:魏洋涛
地址:上海市浦东周康路26号万达E座1505
邮编:201318
电话:021-33891086
传真:021-33891530
公司网址:
  • 陈慧 在2023/12/15 10:50:00留言
  • 详细留言:ACS141-2K7-1询价
  • 李勇 在2023/8/9 15:09:00留言
  • 详细留言:60SR3B05 数量100
  • Mohammed 在2020/12/3 17:14:00留言
  • 详细留言:Hi 1- TSGASH-1624 Fail-safe Gas/Flame detector input FTA with HART interface. 2- SAI-1620M 3- SPD(SD32T3) 3 WIRE AI ANALOGE SIGNAL. 4- TERMINAL BLOCKA
  • amr saeed 在2019/1/8 19:28:00留言
  • 详细留言:greetings this is amr saeed from power egypt corporation specialized at manufacturing ac units we require the following: johnson control a36aha-8c 10-90f , 4 stage thermostat please quote us technically and prices
  • 神华机电 在2016/10/12 11:10:00留言
  • 详细留言:询价
