上海御林信息科技有限公司
  • 10105/2/1
  • 发布时间:2019/1/14 10:25:17   修改时间:2019/1/14 10:25:17 浏览次数:3335
  • 10001/R/1 Vertical Bus Driver
    10005/1/1 Watchdog Module
    10006/2/1  Diagnostic and battery module (DBM)
    10018/E/1  FSC PlantScapeconnectionModule
    10018/E/E FSC PlantScape connection Module
    10020/1/2 CPU Module
    10024/H/F Enhanced COMModule,CentralPart/RS232
    10024/I/F Enhanced COM Module,RS485/RS232
    10024/I/I 3400307Enhanced communicationmodule(ECM)
    10100/2/1 Horizontal Bus Driver
    10101/2/1 DI Module
    10105/2/1 AI  Module
    10201/2/1 DO Module
    10205/2/1 Fail-safe analog output module
    10208/2/1 3400118 Relay output module
    10300/1/1 Converter 24V to 5V
    10302/2/1 Watchdog Repeater
    10303/1/1 Power supply distributionmodule(PSD)
    10313/1/1 5 Vdc + Watchdog distributionmodule
    30754661-011 Fuse, Subminiature, .25 Amp
    30754661-014 Fuse, .5 Amp
    30754661-021 Fuse, 2 Amp
    30754661-022 Fuse, 3 Amp
    51109612-100 Torque Wrench for Tap
    51190582-125 Fuse, .25 Amp
    51190582-210 Fuse, 1 Amp
    51190584-150 Fuse, .5 Amp Slo-Blow
    51190728-105 Tee Connector, LCN Coax
    51190782-200 Terminator, UCN CarrierBandwo/chain
    51191561-100 SPC Firmware Upgrade Kit
    51192060-100 Battery, Ni Cad
    51192337-101 Battery Pack NI-CAD
    51192418-100 Connector, 75 Ohm
    51195153-001 Drop Cable Set, 1M RG6
    51195153-002 Drop Cable Set, 2M RG6
    51195153-005 Drop Cable Set, 5M RG6
    51195153-010 Drop Cable Set, 10M RG6
    51195199-002 Cable Set, UCN Trunk RG-11, 2.5M
    51195199-005 Cable Set, UCN Trunk RG-11, 5M
    51195199-010 Cable Set, UCN Trunk RG-11, 10M
    51195199-020 Cable Set, UCN Trunk RG-11, 20M
    51195479-200 Cable Set, I/O Link, 3 Drop
    51196094-100 FTA Mtg Channel, Narrow Rittal w/ShGrndBar
    51196094-200 FTA Mtg Channel, Wide Rittal w/ShGrndBar
    51196653-100 Pwr Supply, 5 Slot File, EC
    51196654-100 Pwr Supply, 10 Slot File, EC
    51196655-100 P/S DUAL NODE EC
    51196694-200 Kybd, IKB w/Trackball, Desktop
    51196694-300 Kybd, IKB w/Trackball, PS/2,Desktop
    51196694-350 Kybd, IKB w/Trackball, ZConsole,GUS
    51196694-901 Trackball, IKB
    51196694-909 Function Key Panel, IKB forZConsole
    51196929-135 Drive, 3.5in Zip
    51197593-100 Lithium Battery (TC-BATT01)
    51198947-100 Pwr Supply, PM
    51201394-100 Tap Assy, 2-Drop
    51201395-100 Tap Assy, 4-Drop (Qty 2 in Set)
    51201420-003 Cable, FTA I/O Phone/Phone,3M,non-CE
    51201420-004 Cable, FTA I/O Phone/Phone,4M,non-CE
    51201420-005 Cable, FTA I/O Phone/Phone,5M,non-CE
    51201420-008 Cable, FTA I/O Phone/Phone,8M,non-CE
    51201420-010 Cabl1e, FTA I/O Phone/Phone,10M,non-EC
    51201420-012 Cable, FTA I/O Phone/Phone,12M,non-CE
    51201420-015 Cable, FTA I/O Phone/Phone,15M,non-CE
    51201420-020 Cable, FTA I/O Phone/Phone,20M,non-CE
    51201557-150 I/O Link Module, Single, CC
    51201557-350 I/O Link Module, Triple, CC
    51201667-100 Cable, HPM Redundancy
    51202306-915 Cable, I/O LIM Protection, 1.5M
    51204146-003 ControlNet Trunk Cable (3M)
    51204146-010 ControlNet Trunk Cable (10M)
    51204160-175 FTA, D/I 24VDC, Comp Term, CC, CE
    51204162-175 FTA, D/O 24VDC, Comp Term, CC, CE
    51204166-175 HD FTA, D/O Relay, Comp Term, CC,CE
    51204170-250 HD FTA, HLAI/STI, Comp Term, CC
    51204172-175 HD FTA, A/O w/Standby, Comp Term,CC,CE
    51303932-476 FTA, Serial I/F, Modbus RS-232, CC
    51303940-150 Fan Assy w/Alarm, 115V, CC
    51303940-250 Fan Assy w/Alarm, 230V, CC
    51303948-100 Battery Assy, 48V
    51303979-550 APM I/O LINK DRIVER CC
    51304084-175 FTA, Pulse input, Comp Term, CC
    51304335-175 FTA, Redundant A/O, Comp Term, CC
    51304337-250 FTA, Redundant HLAI/STI, ScrewTerm,CC
    51304362-150 IOP, LLAI Mux, CC
    51304362-350 IOP, Serial I/F, CC
    51304386-150 IOP, Pulse Input, CC
    51304419-150 IOP, Fiber Optic, CC
    51304431-175 FTA, 240VAC D/I, Comp Term, CC
    51304437-150 FTA, LLAI, Comp Term, CC
    51304441-175 FTA, 24VDC D/I, Comp Term, CC
    51304453-150 FTA, HLAI/STI, Comp Term, CC
    51304465-100 Cable, Twisted Pair w/Shield, 30cm
    51304465-200 Cable, Twisted Pair w/Shield, 66cm
    51304465-300 Cable, Twisted Pair w/Shield, 100cm
    51304465-500 Cable, Twisted Pair w/Shield, 300cm
    51304476-175 FTA, A/O, Comp Term, CC
    51304481-150 IOP, LLAI, CC
    51304485-150 IOP, DI, CC
    51304487-150 IOP, D/O, CC
    51304493-250 APM MODEM CC, R400
    51304516-250 IOP, STI/MV, CC
    51304518-150 APM ADV CONTROLLER  CC
    51304584-100 I/O Card, EPDGP
    51304648-175 FTA, 120/240VAC SS D/O, Comp Term,CC,CE
    51304650-150 FTA, 3/30VDC D/O, Comp Term, CC
    51304685-150 APM ADV COMM CC
    51304754-150 IOP, HLAI, CC
    51304903-100 I/O Card, WDI, non-EC
    51304907-100 I/O Card, SPC II, non-EC
    51304907-200 I/O Card, SPC II, EC
    51305072-100 I/O Card, CLCN A/B, EC
    51305072-200 I/O Card, CLCNA, EC
    51305072-300 I/O Card, CLCNB, EC
    51305072-500 I/O Card, CLCNA, non-EC
    51305072-600 I/O Card, CLCNB, non-EC
    51305334-100 COVER, MAU
    51305348-100 MAU Assy
    51305378-100 IKBI2 PWA
    51305380-100 Cable, MAU, EC
    51305557-100 Power Cord, 220VAC
    51305776-100 OEP/IKB Module Assy
    51305890-175 FTA, LLMUX TC, Solid State,CC,CE
    51305896-200 PWA, NIM Modem EC
    51305907-175 Top Assembly LLMUX2, RTD, CE, CC
    51308111-002 Cable Set, LCN Coax, 2M
    51308112-003 Cable Set, LCN Coax, 3M
    51308112-008 Cable Set, LCN Coax, 8M
    51308112-015 Cable Set, LCN Coax, 15M
    51309148-125 FTA, 120V D/O Relay, Comp Term, CE
    51309150-175 FTA, 240V D/O Relay, Comp Term,CC,CE
    51309152-175 IOP, A/O, CC
    51309204-175 FTA, LLAI Mux/SDI/SI Pwr Adapter,CC
    51309218-175 FTA, LLMux RTD, Comp Term, CC, CE
    51309241-175 Battery Extension Module(conformalcoated)
    51309276-150 PWA, HPM I/O Link, CC
    51309288-375 PWA, RED MODULE CC
    51309512-175 FTE Bridge Module, CC
    51309516-175 SI Pwr Adapter, AC
    51309540-175 AO GI/IS FTA (16),  HART CC
    51400646-100 Fan Assy, 5 Slot
    51401052-100 PWA, SPCI
    51401135-350 PWA, Redundant Pwr Sply, 230VAC, CC
    51401140-450 Pwr System, AC Only,240VAC,16A,Redundant,CC
    51401140-850 Pwr System, AC Only, 240VAC,8A,Redundant,CC
    51401496-100 FAN ASSM, 2 NODE
    51401560-100 Kybd, QWERTY Membrane
    51401577-100 QWERTY KYBD KIT
    51401583-100 PWA EPNI
    51402089-100 PWA, EPDG2
    51402184-100 Pwr Supply Replacement Kit, DualNodeFile
    51402184-200 Pwr Supply Replacement Kit, 5SlotFile
    51402497-200 QWY KYBD W/BEEPER EC
    51402573-250 UCNIF Module Assembly CC
    51403165-400 OEP Assy, EC
    51403299-200 LCNP4 GPS Assy w/Card Guide
    51403422-150 PWA, HPM Comm/Controller, CC
    51403427-175 LIM Module CC
    51403427-275 LIM Module CC
    51403519-160 K4SDR 16 MW
    51403645-400 SBHM Single Drive Assy
    51403698-100 SBHM Motherboard Assy
    51403776-100 PWA, LCNP4M
    51403988-150 PWA, HPM COMM CONTROL CC
    51404127-250 HPM File, 15 Slot, CC
    51404172-175 Baclpanel, PM Pwr System
    51404174-275 PM Pwr System Assy, 20AmpRedundant,CC,
    51404305-375 PCM Assembly, CE, CC
    51404391-125 P/S SER INT ASSY EC
    620-0024 24K Memory Module
    620-0036 Processor Power Supply
    620-0054 620-35 System Control Module
    620-0056 Register Module -- 4K x 4K
    620-0080 620-35 Processor Module
    620-0085 2048 I/O Control Module
    621-0021RC Enhanced Diagnostics Module
    621-1250RC 240Vac Input, 16 point
    621-2201RC 230Vac Isolated Output, 6 point
    621-3560RC 24Vdc Input, 16 point
    621-3580RC 24Vdc Input, 32 point
    621-6550RC 24Vdc  Source Output, 16 point
    621-9938RC Redundant Serial I/O Module
    621-9939C Serial Link Module
    621-9940C Serial I/O Module
    80363969-150 HD IOP, HPM A/O, CC
    80363972-150 HD IOP, HPM D/I, CC
    80363975-150 HD IOP, HPM D/O, CC
    80366177-250 HD FTA, A/O Redn, Comp Term, CC
    80366198-100 Cable, Bridge 1M
    83957061-002 FUSE 0.5 AMP
    83957061-003 FUSE 1.0 AMP
    83957061-004 FUSE, 1.6 AMP
    9904-TPR ControlNet T Tap right angle
    9904-TPS ControlNet T Tap straight angle
    FS-TPSU-2430 24 Vdc to 30 Vdc/1 A converter
    FS-TSAI-1620m Fail-safe 0(4)-20 mA analoginputFTA
    FS-TSDI-16UNI DI FTA Moudle
    FS-TSDO-0824 DO FTA Moudle
    FS-TSGAS-1624 3410748  Fail-safe Gas -Flame detectorinputFTA
    FTA-T-02 3410706 Fail-safe digital outputFTA
    FTA-T-21 3410724 Fail-safe digital input FTA
    MC-HPMR01 HPMM BOARD SET - REDUNDANT
    MC-HPMS01 HPMM BOARD SET - SINGLE
    MP-ZHMU18-100 HM Upgrade Kit,Dual 1.8GB Drivesw/oTray
    MP-ZHMU19-100 HM Upgrade Kit, Dual 1.8GBDrivesw/Tray
    MP-ZIP100-100 Upgrade Kit, Single Bernoulli to SingleZipDr
    MP-ZMSE01-100 MOUSE UPGRADE KIT
    TC-CCN013 CNI Module, Single Media
    TC-CCR013 CNI Module, Redundant Media
    TC-CCR014 CNI Module, RedundantMedia(TC-CCR013)
    TC-CEN021 Ethernet Interface Module, 10/100MB
    TC-FPCXX2 120/240vac Pwr Supply
    TC-FPDXX2 24Vvdc Pwr Supply
    TC-FXX102 10 Slot Chassis, 13 Amp
    TC-FXX132 13 Slot Chassis, 13 Amp
    TC-FXX172 17 slot chassis, 13 amp
    TC-IAH061 Analog Input 6pt Module, CIOM-A
    TC-IAH161 AI 16 Module (single or 8diff.),CIOM-A
    TC-IDD321 DC Input Module 24vdc 32pt, CIOM-A
    TC-IDJ161 DC Input Module 24vdc 16pt(isoltd.),CIOM-A
    TC-IDW161 AC Input Module 220vac 16pt, CIOM-A
    TC-IXL061 Thermocouple Input Module6pt,CIOM-A
    TC-IXL062 Thermocouple Input Module6pt,CIOM-A
    TC-IXR061 RTD Input Module 6pt, CIOM-A
    TC-OAH061 Analog Ouput 6pt Mod (4-20MA)CIOM-A
    TC-OAV061 Analog Output Module 6 pt(10V),CIOM-A
    TC-OAV081 AO Module 8pt (4-20ma &10V),CIOM-A
    TC-ODA161 AC Output Module 120/220vac16pt,CIOM-A
    TC-ODD321 DC Output Module 24vdc 32 pt,CIOM-A
    TC-ODJ161 DC Output Module 24vdc 16pt, CIOM-A
    TC-ODK161 AC Output Module 120/220vac16pt,CIOM-A
    TC-PCIC01 ControlNet Interface Card (PCI Bus)
    TC-PCIC02 ControlNet Interface Module, PCIbus
    TC-RPCXX1 120/240 VAC Redundant Power Supply
    TC-TBCH Field Wiring Connector 36 pos
    TC-TBNH Field Wiring Connector 20 pos
    TK-CCR014 CNI, Redundant Media,Coated(TK-CCR013)
    TK-FPDXX2 Conformal coated 24VDC Pwr Supply
    TK-FXX132 13 slot chassis, coated, 13 amp
    TK-IAH161 AI 16 Module, CIOM-A, Coated
    TK-IDD321 DC Input 24vdc 32pt, CIOM-A, Coated
    TK-IXL061 Thermocouple Input 6pt,CIOM-A,Coated
    TK-IXR061 RTD Input 6pt, Coated
    TK-OAV081 Analog Output 8pt, CIOM-A, Coated
    TK-ODD321 DC Output 24vdc 32 pt, Coated
    TP-DIKBTA-100 IKB Keyboard w/Trackball, Desktop
    TP-DOKBNA-100 OEP KYBD DESKSIDE GUS
    TP-LCNECM-100 XLCN EXTENDER SET CE MULTIMODE
    TP-LCNP02-100 LCNP4M Interface Card, Mid-siz
    TP-OPADP1-200 OEP Adapter, 240V, Deskside IKB
    TP-OPADP1-201 OEP ADAPTER FOR DESK, WKS2, 24
    TP-ZSBHM2-100 UPG KIT, HM TO SBHMW/TWODRIVES
上海御林信息科技有限公司 公司主要从事PLC&DCS,仪器仪表,传动电气设备,机电产品的销售以及工业自动化产品系统集成方案。公司与国内外众多知名品牌供应商建立有极其良好的合作关系,在欧美,东南亚,中东,非洲,大洋洲等地形成了稳定、高效的…  更多>>
上海御林信息科技有限公司
联系人:魏洋涛
地址:上海市浦东周康路26号万达E座1505
邮编:201318
电话:021-33891086
传真:021-33891530
公司网址:
  • 陈慧 在2023/12/15 10:50:00留言
  • 详细留言:ACS141-2K7-1询价
  • 李勇 在2023/8/9 15:09:00留言
  • 详细留言:60SR3B05 数量100
  • Mohammed 在2020/12/3 17:14:00留言
  • 详细留言:Hi 1- TSGASH-1624 Fail-safe Gas/Flame detector input FTA with HART interface. 2- SAI-1620M 3- SPD(SD32T3) 3 WIRE AI ANALOGE SIGNAL. 4- TERMINAL BLOCKA
  • amr saeed 在2019/1/8 19:28:00留言
  • 详细留言:greetings this is amr saeed from power egypt corporation specialized at manufacturing ac units we require the following: johnson control a36aha-8c 10-90f , 4 stage thermostat please quote us technically and prices
  • 神华机电 在2016/10/12 11:10:00留言
  • 详细留言:询价
