欢迎咨询:联系人:金春生 电话:021-34620029 手机:13482184966 传真:021-34273211 商务QQ:2506759730 商务MSN:jchuns@msn.cn
邮件:13482184966@163.com 公司网址:http://www.sh-jjzdh.com
上海积进自动化设备有限公司:专业经营德国菲尼克斯(PHOENIX)电气产品:菲尼克斯开关电源,菲尼克斯隔离器,
菲尼克斯变送器,菲尼克斯交换机,菲尼克斯继电器,菲尼克斯安全继电器,菲尼克斯模块,菲尼克斯转换器,菲尼克斯端子,
菲尼克斯防雷器,。。。。。。
LC-RSC-24DC/1/ACT
PSI-MOS-RS485W2/FO 850 E
IB IL MUX-CAB PSI
PLC-BSC-230UC/21
PLC-BSC- 48DC/21
PLC-RSC- 48DC/21
PLC-BSC-24DC/21
EMG17-REL/KSR-W230/21-21-LC
SUBCON 9/M-SH
REL-KSR-G 24/21
PLC-OSC-120UC/48DC/100
CM 90-ELR-W3/5-R
VAL-MS 500 ST
PLC-RSP-230UC/21
UMSTBHK 2,5/10-G
PLC-RSP-24DC/21
VAL-MS-320
PSR-SCP- 24UC/ESAM4/8X1/1X2
EMG 17-OV- 24DC/ 60DC/3
ST-REL4-KG230/21-21
PLC-OSP-24DC/24DC/2
FBST 500-PLC BU
FBST 500-PLC RD 500MM
TRIO-PS/1AC/24DC/10
MCR-SL-D-U-I
VAL-MS BE/FM
MCR-FL-T-LP-I-EX
EMG 17-REL/KSR- 24/21-21-LC
EMG 10-REL/KSR-G 24/21-LC
OPT-24DC/24DC/2
PLC-OSC-24DC/24DC/2
MCR-PT100-I
MCR-SL-S-1-5-I-DCI-230
EMG 17-OV- 24DC/ 24DC/2
PSR-SCP-24UC/ESD/4X1/1X2/600
PSR-SCP-24DC/ESD/5X1/1X2/300
MCR-I-UI-E
QUINT-DIODE/40
EMG 45-DIO14M
EMD-SL-3V-400-N
D-UFB-V24/S-DSUB 9/SB-B
MCR-C-U-U-DC
PLC-BSC- 24DC/21-21
PSR-SCP- 24UC/URM/5X1/2X2
PLC-BSC-120UC/21
UM-HOZ 462/1-1-1-2/G24
PLC-RSC-230UC/21
PSM-ME-RS232/RS485-P
UMK- F48M-VR/VS
FLKM 10
UM72-R-24DC/21
MCR-F-UI-DC
PLC-RSC-220UC/21-21-SO46
MCR-C-I/I-40-DC
PLC-BSC-220UC/21-21-SO46
MCR-SLP-1-5-UI-0
EMD-SL-3V-400-N
EMD-SL-V-UV-300
ETR-U-18-230UC/21
PI-EX-ME-ID-I/I
PI-EX-ME-RPS-I/I
FLKMS 64
REL-MR-24DC/21
PSR-SCP-24UC/ESA4/3X1/1X2/B
UMK-16 OM-R/MF/MKDS
MINI MCR-SL-UI-2I
DEK-OE- 24DC/24DC/100KHZ
FLT-CP-2C-350
EMG 22-DIO 4E-1N5408
EMG 22-DIO 4E
EMG 45-DIO14P
EMG 45-DIO14M
SAC-3P-M12FR-2L/PUR-20
VAL MS320-1+1
VAL-MS 320/3+1
VAL-MS230IT/3+1
PT 2-PE/S-230AC-ST
PT 1X2-24DC-ST
CT 10-2PE/FS-24
CT-TERMIBLOCK 10 DA
EMG17-0V-24VDC/240VAC/3
MCR-FL-C-UI-2UI-DCI
REL-MR- 60DC/21AU
VAL-MS230/3+1
FLT-CP-3C-350
PLC-BSC- 24DC/21-21
FLT-CP-3S-350
BC/3+1/FM
VAL-MS 230 ST
VAL-MS BE
F-MS 12
CT 10-18FS+F/PE-24
CT-TERMIBLOCK 10 DA
PT-BE/FM
VAL-MS 230/3+1 FM
PT 2X2-BE
PT 2X2-HF- 5 DC-ST
IL DN BK3-PAC
PLC-RSC- 24DC/1/SEN
PLC-RSP- 24DC/1/ACT
MCR-C-UI-UI-DCI-NC
PLC-RSP- 24DC/1AU/SEN
PT 2X2-24AC-ST
PT2*2-BE
SUBCON-PLUS-PROFIB/SC2
MCR-1CLP-I-I-00
IBS RBC METER-T
MCR-C-I-I-00-DC
MCR-S-1-5-UI-DCI-NC
MCR-S-1-5-UI-DCI
FBST 500-PLC BU
FBST 500-PLC RD
FBST 6-PLC BU
FBST 6-PLC RD
PLC-RSC-120UC/21
PLC-ATP BK
PSR-SCP- 24UC/ESA4/2X1/1X2
MCR-R-I-4-V-DC
DEK-REL- 24/I/1
EMG 45-SD-D/LA/SI YE
DEK-OE- 5DC/24DC/100KHZ
VAL-CP-1S-175
FL WLAN 24 DAP 802-11
MINI MCR-SL-2CP-I-I
MCR-FL-C-UI-UI-DCI-24/230
REL-KSR-G 24/21-21
MACX MCR-SL-CAC-5-I-UP
REL-MR-110DC/21-21
MCR-S-1-5-UI-DCI
FLKM 26
PLC-OSC-230UC/48DC/100
FLKM 40
EMG 22-REL/KSR- 24/21
EMG 10-REL/KSR-G 24/1-LC
PSR-SPP- 24UC/ESA4/3X1/1X2/B
UMK- F48M-VR/VS
MCR-FL-C-UI-2UI-DCI-NC
PLC-OSC-230UC/48DC/100/SEN
PLC-OSC- 24DC/230AC/1/ACT
PSM-CABLE-PROFIB/FC
SUBCON-PLUS-PROFIB/AX/SC
PLC-BSC- 24UC/21-21
REL-MR- 24DC/21-21AU
MCR-TTL-RS232
MCR-TTL-RS232-E
PLC-BSC- 5DC/21
REL-MR- 4,5DC/21
mcr-sl-s-1-1/5-i-dci-24
MCR-4CLP-I-I-00
EMG17-0V-12VDC/240VAC/3
MCR-FL-TS-LP-I-EX
MCR-FL-T-LP-I-EX
MINI MCR-SL-RPS-I-I
EMG 17-OE-24DC/24DC/50
PLC-RSC-24UC/21
PSM-EG-RS-232/TTY-P/2K
PSM-SET-FSMA/4-HCS
PSM-HCS-KONFT00L
EMG22-REL/KSR-G24/TRN35
PSM-LWL-HCSO-200/230
PLC-RSC-24DC/1IC/ACT
PLC-RSC-24UC/21-21AU
PLC-RSC-24UC/21AU
SST-IBS-CLX-RLL
MCR-R-I-4-V
UM 72-R-24DC/21
PR2-RSC3-LDP-24DC/2X21
SAC-3P-M12MS/0,6-PUR/M12FS
SAC-3P-M12MS/1,5-PUR/M12FS
ETR-U-18-230UC/21
OPT-24DC/48DC/100
ETD-SL-1T-DTF
EMG 45-B8
FLK 26
MCR-1CLP-I-I-00
UM 72-R-24 DC/21-21
PSR-SCP- 24UC/ESM4/3X1/1X2/B
MCR-SL-PT100-SP
UM72-R-24DC/21
MCR-T-UI-NC
MCR-T-UI-E-NC
DEK-OE-125DC/48DC/100/T
PR2-RSP3-LDP-24DC/2*21
SACC-DSI-MS-4CON-M12/0,5 SCO
SACC-DSI-MS-4CON-M12-SCO SH
MCR-PS- 24DC-10DC
PR3-BSC1/3X21
REL-OR- 24DC/3X21
MCR-C-U-I-10B-4-DCI
MINI MCR-SL-PTB
PLC-BSP-24DC/21
PLC-BSC-24DC/1/ACT
PLC-RSC-230UC/21-21
EMG 10-OV- 24DC/24DC/1
EMUG 45- 4REL/KSR-G 24/21
MCR-C-I-U-4-DC
IBS IP 400 ME-VFD 1-3A DI4
PSM-ME-RS232/TTY-P
PRG CAB MINI DIN
FBST 500-PLC BU
PLC-RSC-24DC/1-1/ACT
DEK-OV- 5DC/24DC/3
DEK-OV- 24DC/24DC/3
PSI-MOS-PROFIB/FO 660 E
EMG 22-REL/KSR- 24/21-21
PLC-RSC-230UC/21-21/S046
REL-MR-60DC/21
PSM-ME-RS485/RS485-P
DEK-DE-12DC/48DC/100
EMG 10-REL/KSR-G 24/21-LC AU
DEK-OE-230AC/48DC/100
EMG 10-REL/KSR- 24/21-LC
EMG 45-RELS/IR1-G 24
PLC-BSC-230UC/21-21
PLC-BSC- 24DC/21-21
MINI MCR-SL-RPS-I-I
MCR-CLP-UI-I-4
FLK 50/EZ-DR/ 200/KONFEK
FLKM 50-PA-S300
PLC-V8/FLK14/IN
PLC-V8/FLK14/OUT
PLC-V8/FLK14/OUT/M
PLC-V8/FLK14/IN/M
MCR-VDC-UI-B-DC
FLKM 50/LA/PLC
UMK-32 RM/MR-G24/1/PLC
REL-MR- 24DC/21AU
REL-MR- 12DC/21AU
MCR-VAC-UI-O-DC
PLC-BSC-120UC/21-21/SO46
FLK-D37 SUB/B
CPC 5015 PM CO
PSI-MOS-DNET CAN/FO 850/EM
PSM-ME-RS232/RS232-P
PLC-RSC-230UC/21/S046
REL-MR-24DC/21-21
PSR-SCP- 24DC/RSM4/4X1
PSR-SPP-24UC/ESA2/4X1/1X2/B
PSR-SCP-24UC/ESA2/4X1/1X2/B
ST-REL2-KG 24/1 AU
ST-REL2-KG 24/2 AU
ST-REL2-KG 24/2
EMG 17-REL/KSR-120/21-21-LC AU
