PLC-BSC-120UC/21-21/SO46 PLC-BSC-230UC/21/SO46 PLC-BSC-230UC/1/SEN
PLC-BSC-230UC/21-21 PLC-BSC-230UC/21-21/SO46 PLC-BSC-230UC/21HC/SO46
PSR-SCP-24UC/URM4/5X1/2X2 PSR-SPP-24UC/ESA4/3X1/1X2/B PSM-EG-RS232/RS485-P/2D
PSM-LWL-KDHEAVY-980/1000 PSM-ME-RS232/RS485-P PSM-ME-RS485/RS485-P PS-MT
PLC-RSC-24DC/21HC PLC-RSC-24UC/21 PLC-RSC-24UC/21-21 PLC-RSP-230UC/21
PLC-RSC-230UC/21-21/SO46 PLC-RSC-230UC/21HC PLC-RSP-24DC/1/ACT REL-MR-24DC/1IC
MCR-PS-24DC-10DC MCR-PT100-I MCR-PT100/I/DC MCR-PT100-U MCR-R-I-4-V-DC
PLC-BSC-24UC/21 PLC-BSC-24UC/21-21 DEK-OE-230AC/48DC/100 REL-IRG 24
PLC-BSP-24DC/21-21 PLC-BSP-48DC/21 PLC-BSP-48DC/21-21 PLC-RSC-12DC/21
PLC-RSC-230UC/21HC PLC-RSP-24DC/1/ACT PLC-RSP-230UC/1/SEN REL-IRW230
PLC-V8/FLK14/IN PLC-V8/FLK14/OUT PSI-MOS-DNETCAN/FO850/BM REL-MR-110DC/21HC
PLC-BSC-48DC/21-21 PLC-BSC-48DC/21HC PLC-BSC-120UC/21-21/SO46 REL-SG24/F104
PLC-OSP-24DC/24DC/2/ACT PLC-RSC-12DC/21 PLC-RSC-12DC/21-21 REL-SW230/B110
PLC-BSP-24DC/1/ACT PLC-BSP-24DC/21 PLC-BSP-24DC/21-21 DFK-MSTB 2,5/3-GF-5,08
PSR-SCF-24UC/URM/2X21 PSR-SCP-24DC/ESD/5X1/1X2/300 PSM-EG-RS232/RS422-P/4K
PSR-SCP-24UC/ESA4/3X1/1X2/B PSR-SCP-24UC/ESAM4/8X1/1X2 PSM-EG-RS232/TTY-P/2K
ST-OE3-5DC/48DC/100 ST-OV2-12DC/60DC/1 ST-OV2-24DC/24DC/5 ST-OV2-220DC/60DC/1
ST-OV3-5DC/24DC/2 ST-REL2-KG24/1 ST-REL2-KG220DC/1 ST-REL3-KG230/21/SO46
ST-REL3-HW230/21 ST-REL3-KG 24/21AU ST-REL3-KG230/21 ST-REL4-KG230/1-1/AU
ST-REL4-KG230/21-21 ST-REL7-HG24/4X21 ST-REL7-HG48/4X21 ST-REL7-KG24/21-21
SUBCON9/F-SH SUBCON 9/M-SH SUBCON-PLUS-PROFIB SUBCON-PLUS-PROFIB/AX/SC
菲尼克斯连接器
SACC-M12FS-4CON-PG7-M SACC-M12FS-4SCSH SACC-M12FS-5SCSH SACC-M12FSB-5CON-PG9SHAU
SACC-M12FSB-5SCSH SACC-M12MR-4CON-PG7-M SACC-M12MR-5CON-PG7-M SACC-M12MS-4CON-PG7
SACC-M12MS-4CON-PG7 SACC-M12MS-4CON-PG7-M SACC-M12MS-4CON-PG7-VA SACC-M12MS-4SCSH
SACC-M12MS-4CON-PG11-DUO-M SACC-M12MS-4QO-0,34 SACC-M12MS-5CON-PG11-DUO-M IBSPWR/5
SACC-M12MS-5SCSH SACC-M12MSB-5SCSH SAC-M12T/2XM12PBDP IBST24AI4/SF IBST24AI4/SF4
SAC-3P-3,0-PUR/M12FR SAC-3P-5,0-PUR/M8FR SAC-3P-5,0-PUR/M8FS SACB-6/12-SC
SAC-3P-M8MS/1,5-PUR SAC-3P-M12Y/2XM12FSBPE SAC-4P-3,0-PUR/M8FS SACB-8/8-L-C
SAC-4P-5,0-PUR/M12FR SAC-4P-5,0-PUR/M12FS SAC-4P-10,0-PUR/M12FR SACB-8/8-L-C
SAC-4P-M8MS/10,0-PUR SAC-4P-M8MS/10,0-PURSH SAC-4P-M12MS/1,5-PUR SACB-6/12-L-C
SAC-4P-M12MS/1,5-PUR/M12FS SAC-4P-M12MS/3,0-PUR/M12FS SAC-4P-M12MS/15,0-186
SAC-4P-M12MS/3,0-PUR/M12FR SAC-4P-M12MS/A-1L-SD SAC-5P-1,5-PUR/M12FR
SAC-5P-3,0-PUR/M12FR SAC-5P-5,0-PUR/M12FR SACB-4/4-L-SC NPN SACB-4/8-L-M23
SACB-8/8-L-SCNPN SACB-8/16-M23 SACC-M 8FS-4PCON SACC-M 8MS-3PCON IBSRLAP
SACC-M 8MS-4PCON SACC-M12FR-4CON-PG7 SACC-M12FS-4CON-PG7-VA SACC-M12FS-4CON-PG7
SACC-M12MR-5CON-PG7-M SACC-M12MS-4CON-PG7 SACB-8/16-M23 SAC-4P-10,0-PUR/M12FR
TMC1M11001,0A TMC1M11002,0A TMC1M11003,0A TMC1M11004,0A TMC1M110010.0A TMC2F11203,0A
TMC42-011.0A TMC42-0110A TP22ES/108032 SACC-M12MS-4CON-PG7-VA SACC-M12MS-4SCSH
菲尼克斯耦合模块
IBST24AO4/BP IBSTME24DI32/2 IBSTME24DO32/2 IBS24BK-LWL-K IBSCT24DIO24/16-LK
IBSCT24IOGT-LK-OPC IBSIL24BKRB-LK-PAC IBSIL24BK-DSUB-PAC IBSIL24BK-T/U
IBSIL24BK-T/U-PAC IBSIL24RB-T-PAC IBSIPCBK1/24-F IBSMCFLASH2MB IBSRL24DO16/8-R-LK
IBSOPTOSUB-MA/M/L-LK-OPC IBSOPTOSUB-MA/M/R-LK-OPC IBSSTME24BKRB-LKDIO8/8/3LK
IBSPCISC/I-T IBSRL24DI16/8-LK IBSRL24DIO8/8/8-LK IBSRL24DIO8/8/8-R-LK IBSUTH-K
IBSRL24OC-LK IBSRLPLUG-LK/POF IBSS7300DSC-T IBSST24BK-T IBS-PBCT24IOGT-T
IBSSTME24BKDIO8/8/3-LK IBSSTME24BKDIO8/8/3-T IBSSTME24BKRB-T IBSSTME24BKRB-TDIO8/8/3LK
IBSSTME24BK-T IBSST24BK-T IBSSTME24BKRB-LKDIO8/8/3LK IBSOPTOSUB-MA/M/L-LK-OPC
菲尼克斯接口转换器
PSM-EG-RS232/RS422-P/4K PSM-EG-RS232/RS485-P/2D PSM-EG-RS232/TTY-P/2K MCR-PS-24DC/2X24DC
PSM-LWL-KDHEAVY-980/1000 PSM-ME-RS232/RS485-P PSM-ME-RS485/RS485-P PSM-SET-FSMA/4-KT
菲尼克斯无源隔离器
MCR-SL-1CLP-I-I-00-4KV MCR-SL-D-U-I MCR-SL-PT100-I-DC-24 MCR-SL-PT100-SP MCR-T-UI-E
MCR-1CLP-I-I-00 MCR-2CLP-I-I-00 MCR-4CLP-I-I-00 MCR-C-I-I-00-DC MCR-C-I-I-04-DC
MCR-C-I-I-40-DC MCR-C-I-U-0-DC MCR-C-I-U-4-DC MCR-CLP-UI-I-4 MCR-CPS-I-I-44-E
MCR-CPSS-I-I-44-E MCR-C-UI/UI-DCI MCR-C-U-I-0-DC MCR-C-U-I-10B-0B-DCI MCR-C-U-I-4-DC
MCR-C-UI-UI-DCI-NC MCR-C-U-U-DC MCR-FL-C-UI-2UI-DCI MCR-FL-C-UI-2UI-DCI-NC MCR-SWS-U
MCR-FL-C-UI-UI-DCI-24/230 MCR-F-UI-DC MCR-PS- 24DC/24DC/200 MCR-PS- 24DC/2X24DC
MCR-PS-24DC-10DC MCR-PT100-I MCR-PT100/I/DC MCR-PT100-U MCR-R-I-4-V-DC MCR-S-1/5-UI-DCI
MCR-S-10/50-UI-DCI MCR-S10-50-UI-DCI-NC MCR-S-1-5-UI-SW-DCI-NC MCR-SL-1CLP-I-I-0
