603330 SST-IBS-CLX-RLL SST-IBS-CLX-RLL
3201181 AI16-12IV AI 16 -12 IV
3200904 AI1- 8RD-1000 AI 1 - 8 RD -1000
3200438 AI4-12OG AI 4 -12 OG
3031432 STTB4BU STTB 4 BU
3031160 STTB1,5BU STTB 1,5 BU
2766821 MCR-PS-24DC/24DC/200 MCR-PS- 24DC/24DC/200
3201288 AI0,75-10GY AI 0,75-10 GY
1645480 HC-B16-AMLD-AL HC-B 16-AMLD-AL
1771464 HC-B16-EBUS HC-B 16-EBUS
1771480 HC-B16-ESTS HC-B 16-ESTS
1771011 HC-B6-EBUS HC-B 6-EBUS
1771037 HC-B6-ESTS HC-B 6-ESTS
2816881 FLT35/3 FLT 35/3
2884279 FLWLAN24DAP802-11 FL WLAN 24 DAP 802-11
2864655 MINIMCR-SL-2CP-I-I MINI MCR-SL-2CP-I-I
1604732 HC-B6-TFL-43/O1M20S HC-B 6-TFL-43/O1M20S
1771147 HC-B6-AMLD HC-B 6-AMLD
1771613 HC-B16-AMLD HC-B 16-AMLD
1204504 SZF0-0,4X2,5 SZF 0-0,4X2,5
1204520 SZF2-0,8X4,0 SZF 2-0,8X4,0
1205037 SZS0,4X2,5 SZS 0,4X2,5
1205066 SZS1,0X4,0 SZS 1,0X4,0
5772168 VAL-MS320 VAL-MS 320
0311236 SB2-RTK/S SB 2-RTK/S
3025529 D-MT1,5BU D-MT 1,5 BU
1413036 MBK3/E-Z MBK 3/E-Z
1413117 MBK3/E-Z-PE MBK 3/E-Z-PE
3003363 MT1,5BU MT 1,5 BU
2810612 MACXMCR-SL-CAC-5-I MACX MCR-SL-CAC-5-I
2859181 VAL-MS320/3+1/FM VAL-MS 320/3+1/FM
3200072 AI2,5-18GY AI 2,5 -18 GY
1205451 CRIMPFOXUD10-4 CRIMPFOX UD 10-4
1805615 KGS-MSTB2,5/20 KGS-MSTB 2,5/20
2858577 VAL-MS320/3+1-FM VAL-MS 320 /3+1-FM
2941154 DEK-REL-24/O/1 DEK-REL- 24/O/1
3011067 VIOK1,5-D/TG/D/PE VIOK 1,5-D/TG/D/PE
0921011 ST-SI-UK4 ST-SI-UK 4
1766990 GMSTB2,5/2-ST-7,62 GMSTB 2,5/ 2-ST-7,62
1604796 HC-B16-TFL-60/O1M25S HC-B 16-TFL-60/O1M25S
2744416 PSM-ME-RS232/RS485-P PSM-ME-RS232/RS485-P
1881354 FK-MC0,5/5-ST-2,5 FK-MC 0,5/ 5-ST-2,5
1881464 MC0,5/4-G-2,5 MC 0,5/ 4-G-2,5
1881477 MC0,5/5-G-2,5 MC 0,5/ 5-G-2,5
1881341 FK-MC0,5/4-ST-2,5 FK-MC 0,5/ 4-ST-2,5
2869728 ME6,2TBUS-21,5/5-ST-3,81GN ME 6,2 TBUS-2 1,5/5-ST-3,81 GN
5774768 E/UKCN E/UK CN
2826198 ST-REL4-KG230/1-1/AU ST-REL4-KG230/1-1/AU
5100219 UM72-R-230UC/21-21 UM 72-R-230 UC/21-21
2966595 OPT-24DC/24DC/2 OPT-24DC/24DC/2
2708083 PSI-MOS-DNETCAN/FO850/BM PSI-MOS-DNET CAN/FO 850/BM
2744788 FLMC10BASE-T/FOG850 FL MC 10BASE-T/FO G850
2963941 PSR-SPP-24UC/ESA4/3X1/1X2/B PSR-SPP- 24UC/ESA4/3X1/1X2/B
1507777 SACC-M12FSB-5CON-PG9SHAU SACC-M12FSB-5CON-PG9 SH AU
1681088 SACC-M12MS-4CON-PG 7 SACC-M12MS-4CON-PG 7
3040397 SP2,5/15 SP 2,5/15
1786226 IC2,5/7-ST-5,08 IC 2,5/ 7-ST-5,08
3200195 AI1,5-10BK AI 1,5 -10 BK
3200205 AI2,5-12GY AI 2,5 -12 GY
2708274 PSI-MOS-PROFIB/FO 850E PSI-MOS-PROFIB/FO 850 E
2708261 PSI-MOS-PROFIB/FO 850T PSI-MOS-PROFIB/FO 850 T
2839347 PT2-PE/S-230AC-ST PT 2-PE/S-230AC-ST
2905064 ST-OV2-220DC/ 60DC/1 ST-OV2-220DC/ 60DC/1
2823625 ST-REL2-KG24/1 ST-REL2-KG 24/1
3200522 AI 2,5- 8BU AI 2,5 - 8 BU
2295554 PLC-V8/FLK14/OUT PLC-V8/FLK14/OUT
2296553 PLC-V8/FLK14/IN PLC-V8/FLK14/IN
3022276 CLIPFIX35-5 CLIPFIX 35-5
2980377 PLC-BSP-230UC/21/SO46 PLC-BSP-230UC/21/SO46
2954947 EMG45-SI8E EMG 45-SI8E
2810984 MCR-C-U-I-10B-0B-DCI MCR-C-U-I-10B-0B-DCI
3040274 SP2,5/ 3 SP 2,5/ 3
2952185 EMG45-REL/IR-W230/HWR EMG 45-REL/IR-W230/HWR
2775184 UDK4-PE UDK 4-PE
2858506 POWERSETBC/3/FM/PLUS POWERSET BC/3/FM/PLUS
5774564 UM72-R-24DC/4*21 UM72-R-24DC/4*21
2771007 UKKB10/2,5 UKKB 10/2,5
2940430 EMG17-REL/KSR-W230/21-21-LC EMG 17-REL/KSR-W230/21-21-LC
2810625 MACX MCR-SL-CAC-5-I-UP MACX MCR-SL-CAC-5-I-UP
2943259 EMG 17-OV-TTL/ 24DC/2 EMG 17-OV-TTL/ 24DC/2
2938976 QUINT-PS-100-240AC/48DC/20 QUINT-PS-100-240AC/48DC/20
1663129 SACC-M12MR-5CON-PG 7-M SACC-M12MR-5CON-PG 7-M
2950734 EMG 45-RELS/K2-G220 EMG 45-RELS/K2-G220
2960106 REL-SG220/B110 REL-SG220/B110
1004348 KLM-A KLM-A
2950501 EMG 22-RELS/K1-W230 EMG 22-RELS/K1-W230
2950666 EMG 45-RELS/K2 EMG 45-RELS/K2
2950967 EMG 45-RELS/IR1 EMG 45-RELS/IR1
2951034 EMG 45-RELS/IR1-G220 EMG 45-RELS/IR1-G220
2960054 REL-SW230/B104 REL-SW230/B104
2960122 REL-SW230/B110 REL-SW230/B110
2960193 REL-SW230/F104 REL-SW230/F104
2940061 EMG 22-REL/KSR-230/21/AU/SO46 EMG 22-REL/KSR-230/21/AU/SO46
2949295 EMG 22-REL/KSR-230/21/AU EMG 22-REL/KSR-230/21/AU
2952855 EMG 22-REL/KSR-230/21 EMG 22-REL/KSR-230/21
2771010 UKKB 3 UKKB 3
2770859 DG-UKKB 3/ 5 DG-UKKB 3/ 5
2864736 MINI MCR-SL-PT100-UI-SP MINI MCR-SL-PT100-UI-SP
2864422 MINI MCR-SL-RPS-I-I MINI MCR-SL-RPS-I-I
0800501:0000 PMH 2:ZAHLEN 0 PMH 2:ZAHLEN 0
0800501:0001 PMH 2:ZAHLEN 1 PMH 2:ZAHLEN 1
0800420:0000 PMH 0:ZAHLEN 0 PMH 0:ZAHLEN 0
0800420:0001 PMH 0:ZAHLEN 1 PMH 0:ZAHLEN 1
0800433:U PMH 0:GROSSBUCHSTABEN U PMH 0:GROSSBUCHSTABEN U
1862674 IMC 1,5/12-G-3,81 IMC 1,5/12-G-3,81
1875522 IMCV 1,5/12-G-3,81 IMCV 1,5/12-G-3,81
1803358 MC1.5/10-G-3.81 MC1.5/10-G-3.81
1803374 MC1.5/12-G-3.81 MC1.5/12-G-3.81
1803675 MC 1.5/12-ST-3.81 MC 1.5/12-ST-3.81
1201099 BG/SH BG/SH
2963718 PSR-SCP- 24UC/ESM4/2X1/1X2 PSR-SCP- 24UC/ESM4/2X1/1X2
2967772 PLC-BSC- 24DC/21HC PLC-BSC- 24DC/21HC
2981428 PSR-SCP- 24DC/ESD/5X1/1X2/300 PSR-SCP- 24DC/ESD/5X1/1X2/300
2963912 PSR-SCP- 24UC/ESAM4/8X1/1X2 PSR-SCP- 24UC/ESAM4/8X1/1X2
2963734 PSR-SCP- 24UC/URM4/5X1/2X2 PSR-SCP- 24UC/URM4/5X1/2X2
2967044 PLC-BSC-230UC/21-21 PLC-BSC-230UC/21-21
2980416 PLC-BSC-120UC/21-21/SO46 PLC-BSC-120UC/21-21/SO46
3006823 FBRI 40-5 N FBRI 40-5 N
1685505 RC/TGGM/KVD/LBL 16+3 RC/TGGM/KVD/LBL 16+3
1778014 MSTB 2,5/ 5-STF-5,08 MSTB 2,5/ 5-STF-5,08
1778056 MSTB 2.5/9-STF-5.08 MSTB 2.5/9-STF-5.08
3101016 MTK MTK
3003240 ZFK 4 ZFK 4
3002791 D-ZFK 4 D-ZFK 4
2864419 MINI MCR-SL-1CP-I-I MINI MCR-SL-1CP-I-I
3200551 AI 10 -12 RD AI 10 -12 RD
2802316 ST-BE ST-BE
2810913 MCR-C-UI/UI-DCI MCR-C-UI/UI-DCI
2839282 PT-BE/FM PT-BE/FM
2839318 PT 2-PE/S- 24AC-ST PT 2-PE/S- 24AC-ST
3007042 UKK 5-TG UKK 5-TG
1206612 SZF 3-1,0X5,5 SZF 3-1,0X5,5
