32933 FL SWITCH SF 6TX/2FX
2832577 FL SWITCH SF 7TX/FX ST
2832603 FL SWITCH SF 4TX/3FX ST
2832674 FL SWITCH SF 6TX/2FX ST
2.模块化控制开关
2832328 FL SWITCH MM HS
2832331 FL MXT
2832522 FL SWITCH MM HS/M
2832535 FL MXT/M
2832344 FL IF 2TX VS-RJ-F
2832357 FL IF 2TX VS-RJ-D
2832742 FL IF 2HCS 100-D
2832852 FL IF 2POF 10/100-D
2832412 FL IF 2FX SC-F
2832425 FL IF 2FX SC-D
2832205 FL IF 2FX SM SC-D
2884033 FL IF 2FX ST-D
2832739 FL IF TX/HCS 100-D
2832807 FL IF TX/POF 10/100-D
2832470 FL CB IF
2832483 FL IF MEM 2TX-D
2832904 FL IF 2PSE-F
Order No. Type Description
3.控制转换开关
2832700 FL SWITCH MCS 16TX
2832713 FL SWITCH MCS 14TX/2FX
4.PROFINET INTERBUS 代理服务器
2832111 FL PN/IBS
5.网关
2744490 FL COM SERVER RS232
2708740 FL COM SERVER RS485
2313041 FL COM SERVER RS232 PRO
2313054 FL COM SERVER RS485 PRO
2831060 FL IBS SC/I-T
2862327 FL IL 24 BK-B-PAC
2862314 FL IL 24 BK-PAC
2878816 FL IL 24 BK-PN-PAC
2863986 FL IL 24 BK ETH/IP-PAC
6.控制软件
2831044 FL SWT
2832166 FL SNMP OPC SERVER
2832179 FL OPC SNMP AGENT
7.媒体转换器
2708193 FL MC 10/100BASE-T/FO-660
2744513 FL MC 10BASE-T/FO POF
2744788 FL MC 10BASE-T/FO G850
2708164 FL MC 10/100BASE-T/FO G1300
2708986 FL MC 10/100 BASE-T/FO G1300ST
2708177 FL MC 10/100BASE-T/FO G1300 SM
8.SFN开关
2891851 FL SWITCH SFN 4TX/FX
2891453 FL SWITCH SFN 4TX/FX ST
2891152 FL SWITCH SFN 5TX
2891929 FL SWITCH SFN 8TX
9.电缆及附件
