S232蓝牙适配器,直接连接9针串行端口
·通过单独的可插拔电源或适配器为内置天线提供5V DC电源
·点对点连接和点对多点连接(最多可连接3台从属设备)
·范围:10-30m
型号:PSI-WL-PLUG-USB/BT
·USB蓝牙适配器
·直接插在A型USB端口上并用于USB接口的无线传输
·点对点连接
·范围:80-150m
型号:PSI-WL-PROFIB/BT-SET
·预组态、不可见、具有密码保护的点对点Profibus套装
·传输速率187.5kbps
·包括2个配对的PSI蓝牙转换器和2根OMNI全向天线
·范围:80-150m
型号:PSI-WL-MPI/BT-SET
·PSI Line Bluetooth MPI-SET,预组态为38.4 kbps/s
·用于对Siemens MPI接口的受密码保护的编程访问
·供货范围:1x蓝牙转换器,1x全向天线,1xPSI-MPI/RS232适配器,1xRS-232电缆
·范围:80-150m
SWITCH SF 4TX/3FX ST
2832632 FL SWITCH LM 8TX
2832658 FL SWITCH LM 4TX/2FX
2832661 FL SWITCH SF 15TX/FX
2832674 FL SWITCH SF 6TX/2FX ST
2832700 FL SWITCH MCS 16TX
2832713 FL SWITCH MCS 14TX/2FX
2832726 FL SWITCH SF 7TX/FX
2832771 FL SWITCH SF 8TX
2832849 FL SWITCH SF 16TX
2832894 FL SWITCH 5TX-ZF
2832933 FL SWITCH SF 6TX/2FX
2891001 FL SWITCH SFNB 5TX
2891002 FL SWITCH SFNB 8TX
2891003 FL SWITCH SFNT 5TX
2891004 FL SWITCH SFNT 4TX/FX
2891005 FL SWITCH SFNT 8TX
2891006 FL SWITCH SFNT 7TX/FX
2891007 FL SWITCH SFNT 7TX/FX ST
2891020 FL SWITCH SFN 8TX-24VAC
2891021 FL SWITCH SFN 5TX-24VAC
2891022 FL SWITCH SFN 8TX-NF
2891023 FL SWITCH SFN 7TX/FX-NF
2891024 FL SWITCH SFN 6TX/2FX-NF
2891025 FL SWITCH SFNT 6TX/2FX
2891026 FL SWITCH SFNT 6TX/2FX ST
2891027 FL SWITCH SFNB 4TX/FX
2891028 FL SWITCH SFNB 4TX/FX ST
2891029 FL SWITCH SFNB 4TX/FX SM20
2891041 FL SWITCH 1824
2891043 FL SWITCH SFNT 5TX-C
2891044 FL SWITCH SFNT 4TX/FX-C
2891045 FL SWITCH SFNT 8TX-C
2891046 FL SWITCH SFNT 7TX/FX-C
2891047 FL SWITCH SFNT 7TX/FX ST-C
2891048 FL SWITCH SFNT 6TX/2FX-C
2891049 FL SWITCH SFNT 6TX/2FX ST-C
2891097 FL SWITCH SFN 7TX/FX
