宝鸡华水自动化工程有限责任公司
  • 指针式压力变送器,PB-DA-2Y压力变送器
  • 发布时间:2019/5/13 17:09:21   修改时间:2019/6/8 15:59:13 浏览次数:1769
  • PB-DA-2Y列产品利用专利技术与德国Analog Microectcsco.,Ltd公司合作开发的新型压力变送器,采用精密光刻箔式电阻应变计及德国AMG公司生产的专用变送器用集成电路。它设计新颖独特,工艺先进,信号输出稳定,优良的性能价格比,是远传压力表的理想替代产品。它可广泛应用于冶金、电力、自来水、化工和石油等工业现场,实现远程监控和控制。
    With the patented technology and developed in cooperation with German Analog Microectcsco., Ltd, PB-DA-2Y Series products as new pressure transmitters adopt precision lithography foil resistance strain gauge, and dedicated transmitter-use integrated circuits from AMG. They are featured with unique design, advanced manufacturing technology, stable output signals and cost-effective figures. It is a kind of ideal alternative for transmissible pressure gauge and can be widely used in metallurgy, electronics, tap-water, chemical and oil industries, which can realize remote monitoring and network control.
    1. 技术参数
      II Technical Parameters
    1. 信号输出精度:1.0 级
      The accuracy of signal outputs: 1.0 degree
    2. 表面指示精度:1.6 级
      2. The accuracy of surface indicator: 16 degree
      3.量程:-0.1—0.3Mpa 0~0.4Mpa 00.6Mpa  01.0Mpa
      01.6Mpa 02.5Mpa 04.0Mpa  06.0Mpa
           3. Measuring Range:
       4.信号输出:4-20mA / 0-20mA / 0-10mA / 0-5V/1-5V
           4. Signal Outputs:
      5.工作电压:24V DC    负载电阻:1.2KΩ(标准24V/DC电源)
      5. Operating Voltage:24V DC  Load Resistance: 1.2KΩ(Standard 24V/DC Power Outlet)
      6.传输方式:二线制数字化智能       三线制
      6. Transmission Mode: two-wire digital intelligence   three-wire system
      7.接头螺纹:ZG1/2       M20x1.5
      7. Connection Thread
      8.使用温度:-20~45℃
      8. Operating Temperature
      9.防护等级:IP30
      9. Protection Grade
    3. 360元
国家级高新技术产业开发区的民营股份制企业,专业生产HP31D压力、TT31A温度、HP31B液位变送器,RTU无线计算机测控系统。PB-2Y系列产品利用专利技术与德国Analog Microectcsco.,Ltd公司合作开发的新型压力变送器,采用精密光刻箔式电阻应变计及德…  更多>>
宝鸡华水自动化工程有限责任公司
联系人:李礼元
地址:宝鸡华水自动化工程有限责任公司
邮编:721000
电话:0917-2811180/13991722188/15353016717
传真:0917-2811180
公司网址:http://www.hsa.cn
  • 孟晓龙 在2016/7/1 17:16:00留言
  • 详细留言:想和贵公司合作
