上海渠纳机电设备有限公司
  • AARONIA产品REVERSING
  • 发布时间:2018/7/24 16:35:17   修改时间:2018/7/24 16:35:17 浏览次数:1079
  • AARONIA产品特价。AARONIA公司至今成立了80多年AARONIA产品信息咨询中心上海渠纳机电设备有限公司。AARONIA批发采购。AARONIA产品坏了哪里可以买配件替换?AARONIA型号齐全。AARONIA规格书、中文文档免费提供。AARONIA分销。AARONIA高清图,细节图,标准型号。AARONIA空压机,AARONIA电磁阀,AARONIA软管,AARONIA张力仪,AARONIA接头,AARONIA控制器,AARONIA分析仪,AARONIA
    上海渠纳机电设备有限公司 021-64199362 138-1802-2904
    WOODWARD 8904-359
    67063 16.592.01 DICHTSATZ CNOMO M.MAGNETKOLBEN
    SAIET CN025GZ32RT6 3POLE 2POS CMLTV W/OFF 25A
    SAIET MZPA0024710 DPDT 2 FORM C
    BAKS LDC500H50 N
    WOODWARD 8526-160
    ETIELB 3801863  NS4-100 – 0300-04030 IT – 2 WIRE, 4" DETECTOR BASE, 24 VDC*
    74508 19.044.015
    H233-41411-750N1 S?LZER LS SUVA 41411 06p E/A  90° 12h0   40A Griff
    ETIELB 2115512
    521548 RI36-O/ 720ER.31KB-K0 31301
    ETIELB 2921140
    SAIET GSX20 SIDE MNT AUX 2NO
    ETIELB 4265008
    WOODWARD 8239-076
    75-13526-A2 SPDT,CSA/FM C1D2,36"LEADS
    45489 28.291.200
    ELGO EC-WC0009-33
    76626 19.009.08
    63368 76.440.01.04 ANSCHLU?LEISTE 4 FACH G1/4
    CARLO GA VAZZI LDI35A V2C0XXIX 3.5 DIGIT PANEL METER 48X96 115VAC IP65
    7H-23528-B3 DPDT,UL GP,72"SO CABLE
    11-31228-A4 SPDT,UL GP,144"LEADS S.S.
    ETIELB 4750115
    CARLO GA VAZZI CS30A200240 DPST NO 30A PCB MNT 240VAC
    GS045300N
    SAIET ATVC-060050 ARETA CABLE ENTRY BOX 600X500
    OMH315 151H1024 OMH400 151H1025
    46802004 整体硬质合金圆锯片/铣刀细齿A型20×0.4×5mm
    CARLO GA VAZZI RJ2A22D18E SSR H/S ZS 2-POLE 2X18A 220V 4-32VDC E
    ETIELB HM66C2
    ELGO PR-P14M00-15
    SAIET IA18ALC05AH-K IND PROX BL M18 PNP ANALOG 0
    ETIELB 2471416
    WOODWARD 8253-004
    ETIELB ETIMAT11-QC 3P 10kA B 6A
    11-51543-A3 DMDB,UL C1D1,72"LEADS S.
    WE-M 2,0 x 6 - 0 or WE-M 2.0 x 6 - 0  E36000
    51036 SP765.0440 24V DC 4,5 W NW2,0 2/2NC
    WOODWARD 8915-761
    422501400 手用长刃1:50锥度销子铰刀螺旋齿D40mm
    ETIELB CEC09.10-110V-50/60Hz
    ETIELB HH182005
    SAIET ARETA-031606 CABLE ENTRY MOD 300X1600X600
    27070 28.29.120
    ETIELB 2125727
    21-11518-A2 SPDT,UL GP,36"LEADS BRSS primary
    ETIELB ETIMAT11-QC 3P +N 10kA B 20A
    i-Mega-Line
    WOODWARD 8915-512
    448320 Hochiki America ASWP2475CFR
    P220-61060-026N2 S?LZER NS P220-61060-026N2
    GEL BOY C220
    ELGO PF-ATLA00-75
    SAIET MZPA0024810 DPDT 2 FORM C
    61578 39.272.025
    ETIELB 2062534
    ELGO PD-P30KG0-10
    ETIELB 4373626
    SAIET WM14DINA V53LO2XXAX WM14-DIN ADV., 3-PH, 380/660VLL, 18-60VAC/DC, 2 OPEN COLL.
    ETIELB 4665050
    WOODWARD 8523-455
    SAIET RA4850H12PCS SSR SENSE ZS 480V 50A PNP,NC
    GS061310N
    ELGO LB-HR0600-50
    SAIET PMD8PIT PHOTO DIFFUS 800MM PNP NPT TMR
    SAIET RMIA45005DC 4PDT 5A MINI 5VDC
    TXP-L20GNMM (2) SPDT GO SW., I.S., NAMUR
    84475 201040100 ISO Zylinder mit Magnet, Durc
    WS-M 0,2 - 4 - VA  S20640VA
    DXS-0H0GSES NO SW,HART,IS,STD SHAFT,SILICONE
    oriental_motor FPW425A2-30U
    SAIET RN1S48L50PO SSR SOLI SENSE 480V 50A PNP,NO
    ETIELB 3801894
    ETIELB 4184428
    ETIELB M1UQ2/160A/690V-K
    19854 27.15.010
    AK2 M 8x5  S14119-AK2
    ELGO LO-THAL32-00
    SAIET WM14-96A V63CX WM14-BASIC 96x96 100/208V 5AAC 115VAC?
    WOODWARD 9905-300
    ELGO SK-2U2704-13  2
    BAKS PLZWC50
    GEL AD993040
    WENGLOR ZAA12NN01
    ETIELB NV2 C gL-gG KOMBI 690V 224A
    SAIET CN025M013RT6 1POLE 3POS 25A
    DXP-L20GNEB162A (2)GO SW,IS,NAMUR,BUNA (1)24VDC FAIL O/C,316SST VALVE
    ELGO YB-WO0040-54
    WOODWARD 9905-931
    WALK-IN
    BAKS LUMJ300H80
    EVS9331-ERV100 EVS9331-EKK100
    ELGO KS-LUM086-72
    74556 19.504.025
    WOODWARD 8272-054
    12658 07.155 VERSCHLEISSTEILSATZ F.KR 6  GUC232A – 0100-04570 – USB TO SERIAL ADAPTER CABLE
    ETIELB G3MUQ01/900A/690V
    GS025100N
    SAIET CN0160029RT4 CHANGE OVER W/SPRNG RTN 16A
    ETIELB PCF 8 3p
    ETIELB 631301103
    ETIELB 3901780
    R06F3-5.5N
    ELGO OM-ARB214-10
    SAIET RS422-MI3 CABLE FOR MITS MASTER
    17053 SP 736.0178
    M KV
    PERRY 1REES15/4N
    31-17546-F2 30 SERIES GO SWITCH
    SAIET LDI35A V2C1XXXT 3.5 DIGIT PANEL METER 48X96 115VAC TROPICALIZATION
    KIDDE 324641
    36051 26.316.200 EFTA-URSPRUNGSWARE
    SAIET CLH3 PROBE
    52937 37.290.065
    SAIET RCP800212DC 8PIN DPDT 12VDC
    BAKS TRJ150H110
    346848 Hochiki America HSC221L
    DXP-E2CGSEB (2)P&F SW,IIC,STD SHAFT,BUNA
    CARLO GA VAZZI E10200FM/50 ADJ LVR 50MM 1NO+1NC SNAP NPT
    7FD323658DCA SPST,UL GP,3PIN MINI N/O
    13354 84.240.02 24VAC
    E82ZAFCC010
    ETIELB 2100017
    ETIELB ETIMAT11 1p +N 10kA K 2A
    ETIELB KZS-4M 3p+N B16/003-AC
    ETIELB 702031108
    BAKS RKLBP200/150H50
    M220-641038-003M1 S?LZER NS 61110+ 03k Grup 60° 09h0 1-2-3   20A
    422501160 手用长刃1:50锥度销子铰刀螺旋齿D16mm
    WOODWARD 8272-733
    ETIELB 4723116
    CARLO GA VAZZI RR2I4030HDP SSR 2PH REVERSING 400V 3KW
    151F2303 151F2304 151F2305 151F2306
    ETIELB HSR10
    SAIET CN0160008RT4 3 POLE REVERSING SW 16A
    E2B055Z90NMK3
    BAKS UAF12
上海渠纳机电设备有限公司专业从事国外中高端的工控自动化产品及机电设备的进口贸易与工程服务。公司主营人员从事低压电气产品及工控机柜的选型,销售与服务已近10年,并且深入了解及研究各产业界需求、市场潜力及相关设备系统整合。为了解决客…  更多>>
上海渠纳机电设备有限公司
联系人:刘玲
地址:上海市闵行区恒南路688弄5号702室
邮编:-
电话:--
公司网址:http://www.shquna.com
  • 夏女士 在2023/10/8 10:03:00留言
  • 详细留言:SIT询价
