光纤激光切割机-全自动激光切管机- 开卷校平切割下料卷料激光切割机生产线_武汉华宇诚数控科技有限公司
  • 小型圆管相贯线切割机-便携式管道相贯线数控切割机-厂家价格
  • 发布时间:2020/5/29 15:36:46   修改时间:2020/5/29 15:36:46 浏览次数:1285
  •  小型圆管相贯线切割机-便携式相贯线数控切割机-小型便携式数控相贯线切割机-钢管相贯线切割机厂家-小型管道相贯线切割机-便携式相贯线切割机价格-咨询热线:I89 8629 OO37
    ?发财
    产品介绍 Product introduction
    • 10余年厂家直销小型相贯线切割机价格优惠 全国免费服务
      10 years manufacturers direct small intersecting line cutting machine price preferential national free service
      ----YC-XG1530/YC-XG1560便携式钢管切割机 管径250mm以内的小型钢管切割优选解决方案
    • -- YC-XG1530/YC-XG1560 portable steel tube cutting machine with a diameter of less than 250mm
      一、YC-XG1530/YC-XG1560便携式相贯线切割机产品参数
    • 1. Technical parameters of YC-XG1530/YC-XG1560portable intersecting line cutting machine
    • 15-1
      相贯线切割技术参数 Technical parameters of intersecting line cutting
         1、管径范围:Φ30-Φ250;
    •    pipe diameter range: 30 - Φ Φ 250;
         2、管长标配3米,可加长到6米;
    •    The pipe length is 3 meters, which can be extended to 6 meters;
         3、钢管重量:≤500kg;
    •    Weight of steel tube: ≤500kg;
         4、钢管旋转轴选用伺服驱动,稳定性好;
    •    The rotating shaft of the steel tube is driven by servo, with good stability;
         5、标配:火焰,可选配火焰与等离子两用。
    •    Standard configuration: flame, optional for both flame and plasma.
         6、可以选配钢管和平板两用切割。
    •    can be seleced with steel pipe and plate dual cutting.
    •    7、轴向转动卡盘箱采用1KW伺服驱动,稳定性好,精度高。
    •    the axial rotation chuck box using 1KW servo drive, good stability, high precision.
    •    8、武汉华宇诚数控自主开发的相贯线编程软件,提供多种管子相贯节点的参数化编程,从而能很好解决其它厂家2联动相贯线设备无法解决的管子壁厚干涉问题。
    •    The intersecting line programming software independently developed by hua yu cheng provides parametric programming of various pipe intersecting nodes, which can well solve the interference problem of pipe wall thickness that cannot be solved by other manufacturers' 2 interconnected intersecting line equipment.
    •    9、便携式相贯线切割机数控系统,操作简单,免费升级。
    •    independent research and development of the numerical control system, simple operation, free upgrade.
    1-1
    二、专用数控相贯线编程软件功能: Ii. Special numerical control intersecting line programming software functions:
       武汉华宇诚公司针对三轴两联动切割工艺,开发的三轴两联动相贯线参数化编程软件,充分的考虑管件壁厚对相贯断面的影响,所采用的编程算法可以较好的解决过渡处内外壁的数据处理问题,保证相贯口的正常搭接。
       wu han hua yu chengco., ltd. has developed a parametric programming software for the intersecting line of three axes and two linkage based on the three-axis two-linkage cutting process, which fully considers the influence of the wall thickness of pipe fittings on the intersecting section. The programming algorithm adopted can better solve the data processing problem of the inner and outer walls at the transition point and ensure the normal lapping of the intersecting hole.
     11205720312_1862261349
       软件中涵盖了工程中常见的7个大类21种不同类型的相贯节点类型,而且可以将这些节点进行任意的组合,可满足油气管道、简单管桁架、压力容器等行业的需求。
    The software covers 7 categories and 21 different types of intersecting node types that are common in engineering, and these nodes can be arbitrarily combined to meet the needs of oil and gas pipelines, simple tube trusses, pressure vessels and other industries.
      1、能在主管上切割多个不同方向、不同直径的圆柱相贯线孔,满足支管轴线与主管轴线偏心和非偏心的正交及斜交的条件。
        It can cut a number of cylindrical intersecting line holes with different directions and diameters on the main pipe, which can meet the conditions of eccentric and non-eccentric orthogonality and skew between the axis of the branch pipe and the axis of the main pipe.
        2、能在支管端部切割相贯线端头,满足支管轴线与主管轴线偏心和非偏心的垂直相交、倾斜相交的条件。
        The end of intersecting line can be cut at the end of the branch pipe to meet the condition of eccentric and non-eccentric vertical and oblique intersection between the branch pipe axis and the main axis.
      3、能在圆管端部切割斜截端面。
        It can cut the bevel end face at the end of the pipe.
      4、能在圆管上切割焊接弯头,“虾米节”两端斜截断面。
        It can cut and weld elbows on the round tube and the oblique cutting surfaces at both ends of the "shrimp" section.
      5、能切割与环形主管相交的支管相贯线端头。
        It can cut the end of the intersecting line of branch pipe that intersects with the ring main pipe.
      6、能在圆管中部上切割方孔、腰形孔、椭圆孔(方孔及腰形孔可带圆角)。
        It can cut square holes, waist-shaped holes and oval holes in the middle of the round pipe (the square holes and waist-shaped holes can have rounded corners).
      7、能进行钢管截断。
        Capable of cutting the steel pipe.
      8、能对管端部开槽。
        Can slot the end of the pipe.
      9、能制作二通、三通等管道接头。
        can make two, three and other pipe joints.
       5-1
    • u=400947651,1546854219&fm=199&app=68&f=JPEG
    武汉华宇诚数控科技有限公司专业从事数控切割机的研发、销售和生产10余年,技术实力强,规格品种全的专业生产企业;24小时售前、售中、售后服务热线:189 8629 0037华总
    Wuhan huayucheng technology co., ltd. is a professional manufacturer with strong technical strength and complete specifications and varieties, specializing in the development, sales and production of CNC cutting machines for more than 10 years. 24-hour pre-sale, in-sale and after-sales service hotline: 189 8629 0037  Mr. hua
    武汉华宇诚数控科技有限公司服务承诺 : Wuhan huayucheng technology co., LTD. Service commitment:
    售前服务 : Pre-sale service:
    根据用户设备使用环境、有效切割范围,切割材料和厚度等参数,为用户提供经济实用的数控切割技术解决方案; According to the user equipment use environment, effective cutting range, cutting material and thickness and other parameters, to provide users with economic and practical CNC cutting technical solutions;
    售中服务 : On-sale service:
    合同签定生效后,免费提供基础制作安装图,割台图纸。货到后即刻派售后人员上门协助安装、调试,且按甲方提供的图纸试割2~3件制品,制品的切割质量作为切割机验收依据。
    After the contract is signed and becomes effective, we will provide the basic installation drawing and cutting table drawing free of charge. Immediately after the arrival of the goods, after-sales personnel will be sent to assist in the installation and commissioning, and 2 to 3 pieces of products will be cut according to the drawings provided by party a. The cutting quality of the products will be used as the basis for the final acceptance of the cutting machine.
    售后服务: After-sales service:
    维修承诺:有故障接到反应即刻作出应答,全年不分任何节假日,1小时内响应并找到问题提出解决方案,如电话指导未能解决,派技术员24-48小时内到达现场,让您不被售后困扰,用到满意设备。
    Maintenance commitment: immediately respond to any trouble, throughout the year regardless of any holiday, within 1 hour response and find a solution to the problem, such as telephone guidance failed to solve, send a technician to the site within 24-48 hours, so that you will not be confused by the after-sales service, use the satisfactory equipment.
    小蜜蜂数控火焰切割机http://www.hycsk.com/product-46.html
    小蜜蜂数控等离子切割机http://www.hycsk.com/product-47.html
    相贯线切割机http://www.hycsk.com/product-58.html
    便携式相贯线切割机http://www.hycsk.com/product-59.html
    数控相贯线切割机http://www.hycsk.com/category-12.html
    全国供货范围:
    A  鞍山丨安阳丨安庆丨安康丨阿克苏丨安顺丨阿勒泰丨阿坝丨阿里丨阿拉尔丨澳门
    B  北京丨保定丨滨州丨包头丨宝鸡丨本溪丨蚌埠丨北海丨巴彦淖尔丨白城丨白山丨亳州丨巴中丨白银丨百色丨毕节丨巴音郭楞丨保山丨博尔塔拉
    C  成都丨重庆丨长沙丨长春丨常州丨沧州丨赤峰丨承德丨常德丨长治丨郴州丨滁州丨巢湖丨潮州丨昌吉丨池州丨楚雄丨崇左丨昌都丨朝阳丨常熟丨慈溪
    D  大连丨东莞丨德州丨东营丨大庆丨大同丨丹东丨儋州丨德阳丨达州丨大理丨大兴安岭丨定西丨德宏丨迪庆
    E  鄂尔多斯丨恩施丨鄂州
    F  福州丨佛山丨抚顺丨阜阳丨阜新丨抚州丨防城港
    G  广州丨贵阳丨桂林丨赣州丨广元丨广安丨贵港丨固原丨甘南丨甘孜丨果洛
    H  杭州丨惠州丨哈尔滨丨合肥丨呼和浩特丨海口丨邯郸丨菏泽丨衡水丨淮安丨衡阳丨葫芦岛丨淮南丨汉中丨怀化丨淮北丨黄冈丨湖州丨黄石丨呼伦贝尔丨河源丨鹤壁丨鹤岗丨黄山丨红河丨河池丨哈密丨黑河 丨贺州丨海西丨和田丨海北丨海东丨黄南
    J  济南丨济宁丨吉林丨锦州丨金华丨嘉兴丨江门丨荆州丨焦作丨晋中丨佳木斯丨九江丨晋城丨荆门丨鸡西丨吉安丨揭阳丨景德镇丨济源丨酒泉丨金昌丨嘉峪关丨胶州丨即墨
    K  昆明丨开封丨喀什丨克拉玛依丨库尔勒丨克孜勒苏丨昆山
    L  兰州丨拉萨丨廊坊丨临沂丨洛阳丨聊城丨柳州丨连云港丨临汾丨漯河丨辽阳丨乐山丨泸州丨六安丨娄底丨莱芜丨龙岩丨吕梁丨丽水丨凉山丨丽江丨六盘水丨辽源丨来宾丨临沧丨陇南丨临夏丨林芝
    M  绵阳丨牡丹江丨茂名丨梅州 马鞍山 眉山
    N  南京丨宁波丨南宁丨南昌丨南通丨 南阳丨南充丨内江丨南平丨宁德丨怒江丨那曲
    P  平顶山丨濮阳丨盘锦丨莆田丨攀枝花丨萍乡丨平凉丨普洱丨郫县
    Q  青岛丨琼海丨秦皇岛丨泉州丨齐齐哈尔丨清远丨曲靖丨衢州丨庆阳丨七台河丨钦州丨潜江丨黔东南丨黔南丨黔西南
    R  日照丨日喀则
    S  上海丨深圳丨沈阳丨石家庄丨苏州丨汕头丨商丘丨三亚丨宿迁丨绍兴丨十堰丨四平丨三门峡丨邵阳丨上饶丨遂宁丨三明丨绥化丨石河子丨宿州丨韶关丨松原丨随州丨汕尾丨双鸭山丨朔州丨石嘴山丨商洛 丨神农架丨山南丨双流
    T  天津丨太原丨唐山丨泰安丨台州丨泰州丨铁岭丨通辽丨通化丨天水丨铜陵丨铜川丨铜仁丨天门丨塔城丨吐鲁番丨图木舒克
    W  武汉丨无锡丨乌鲁木齐丨威海丨潍坊丨温州丨芜湖丨渭南丨乌海丨梧州丨乌兰察布丨武威丨文山丨吴忠丨五家渠丨五指山
    X  西安丨厦门丨西宁丨徐州丨咸阳丨邢台丨襄阳丨新乡丨湘潭丨许昌丨信阳丨孝感丨忻州丨咸宁丨新余丨宣城丨仙桃丨锡林郭勒丨湘西丨兴安丨西双版纳丨香港
    Y  银川丨宜昌丨烟台丨扬州丨盐城丨营口丨岳阳丨运城丨榆林丨宜宾丨阳泉丨延安丨益阳丨永州丨玉林丨宜春丨阳江丨延边丨玉溪丨伊犁丨云浮丨伊春丨雅安丨鹰潭丨玉树丨义乌
    Z  郑州丨珠海丨淄博丨中山丨枣庄丨张家口丨株洲丨镇江丨周口丨湛江丨驻马店丨肇庆丨自贡丨遵义丨漳州丨舟山丨张掖丨资阳丨张家界丨昭通丨中卫
    简单聊聊数控相贯线切割机的功能 Talk about the function of CNC intersecting line cutting machine
    对于数控 For CNC相贯线切割机 Intersecting line cutting machine的使用范围小编也做过介绍,想必您看后对数控 Small make up the scope of use has also done the introduction, presumably you see after the numerical control相贯线切割机 Intersecting line cutting machine设备有一个更深的了解和认识。如果想操作好一台设备,首先要了解其设备能实现哪些功能,从而才能得心应手的去操作。 The device has a deeper understanding and awareness. If you want to operate a good device, you must first understand what the device can achieve, so that you can operate easily.
    1.设备利用自定心卡盘,夹持钢管,其设备可完成各种规格钢管的相贯线切割的要求。并且可根据用户需求定制相关操作界面。 1. The equipment USES self-centering chucks to clamp steel pipes, and the equipment can meet the requirements of intersecting line cutting of various steel pipes. And can be customized according to user needs related operation interface.
    2.数控 2. CNC相贯线切割机 Intersecting line cutting machine设备床具利用控轴(纵向移动、前后移动、上下移动、工件回转、割炬摆动、割炬调整)。 The machine bed USES the control shaft (longitudinal movement, forward and backward movement, up and down movement, workpiece rotation, cutting torch swinging, cutting torch adjustment).
    3.机床具有上位以及侧位检测功能、可检测到切割位置处钢管的变形(如:钢管的外形圆度误差)以及位置的偏差,系统根据所测量的数值,自动修正补偿割炬的位置。 3. The machine has upper and lateral detection functions, which can detect the deformation of the steel tube at the cutting position (such as the roundness error of the steel tube) and the position deviation. The system automatically corrects and compensates the position of the cutting torch according to the measured values.
    4.具有单独的割炬提升轴,用于在切割过程中对割炬的位置的进行及时的调整,保持割炬与工件的相对位置,提高切割质量。 4. It has a separate lifting shaft for cutting torch, which is used to timely adjust the position of cutting torch in the cutting process, keep the relative position between cutting torch and workpiece, and improve the cutting quality.
    5.机床有卡盘自动夹紧装置,可实现对卡盘的机动夹紧,可有效的减轻工人的劳动强度。 5. The machine is equipped with automatic chuck clamping device, which can realize the automatic chuck clamping and effectively reduce the labor intensity of workers.
    6.机床可配置等离子或火焰切割,并具有三种坡口方式(定角、定点、定角4),可满足工件的切割要求。 6. The machine can be configured with plasma or flame cutting, and has three groove methods (fixed Angle, fixed point, fixed Angle 4), which can meet the cutting requirements of the workpiece.
    7.机床具有托辊可对工件进行支承,托辊采用丝杠升降机,调整方便、可靠。 7. The machine tool is equipped with a supporting roller to support the workpiece. The supporting roller is raised by a lead screw, which is convenient and reliable for adjustment.
    8.机床采用触摸屏的图形化参数输入,具有方便简捷的特点。 8. The machine adopts the graphical parameter input of the touch screen, which is convenient and simple.
    了解了以上几点,您是不是对数控 Understand the above points, you are not on CNC相贯线切割机 Intersecting line cutting machine有了更深的认识呢! Have deeper understanding!
    选择适合的相贯线切割机的五大标准 Five criteria for selecing suitable intersecting line cutting machine
    选择一个合适的相贯线切割机不但可以节约成本,而且还可以提高工作效率,那么该如何选择合适的相贯线切割机厂家呢?下面跟随小编来了解一下吧: Choosing a suitable intersecting line cutting machine can not only save cost, but also improve work efficiency, so how to choose a suitable intersecting line cutting machine manufacturer? Follow the small series below to understand it:
      1、选择机型 1. Choose the model
      帮助用户根据要切割的材质、厚度,以及切割效率和切割质量的要求,首先选择和决定购买相贯线切割机的种类,一定要根据要切割的材质来决定。 Help users according to the material to be cut, thickness, as well as cutting efficiency and cutting quality requirements, first choose and decide to buy the intersecting line cutting machine type, must be decided according to the material to be cut.
      2、选择配置 2. selec configuration
      再根据材质和产品的切割加工要求和工艺,特别是切割厚度和穿孔能力,选择和决定相贯线切割机的具体配置,如等离子的功率,火焰枪配置,坡口切割类型和方式。   Then according to the material and product cutting processing requirements and technology, especially cutting thickness and piercing capacity, selec and decide the specific configuration of intersecting line cutting machine, such as plasma power, flame gun configuration, groove cutting type and way.
      3、考察机床质量和精度 3. Inspect the quality and accuracy of machine tools
      机型和配置选定后,介绍本企业切割机的制造质量和切割精度。相贯线切割机的机床结构,齿轮齿条质量,导轨和减速箱质量,机床安装接地与屏蔽,以及切割精度的校验,都关系到或决定了相贯线切割机的切割质量。 After selecting the machine type and configuration, the manufacturing quality and cutting precision of the cutting machine are introduced. The machine tool structure of intersecting line cutting machine, the quality of gear and rack, the quality of guide rail and reduction box, the machine tool installation grounding and shielding, as well as the calibration of cutting precision, all relate to or determine the cutting quality of intersecting line cutting machine.
      4、考察数控系统的稳定性 4. Investigate the stability of the numerical control system
      数控系统的稳定性至关重要,如果系统不稳定,比如夏天由于数控系统内部发热,或是由于风扇或硬盘损坏,导致数控系统无法工作,企业需要停产一周时间等待更换或修复系统,这对企业和切割机厂家都是严重的损失。 The stability of the CNC system is very important, if the system is not stable, such as summer due to the internal heat of the CNC system, or due to fan or hard disk damage, the CNC system can not work, enterprises need to stop production for a week waiting for the replacement or repair of the system, which is a serious loss to enterprises and cutting machine manufacturers.
      5、切割效率与切割质量 5. Cutting efficiency and cutting quality
      相贯线切割机厂家的切割效率和切割质量是用户最为关注的,不仅是用户验收相贯线切割机的重点,而且是用户评价切割机好坏的标准。特别要指出的是在现在相贯线切割机硬件基本相同或类似情况下,相贯线切割机的切割效率和切割质量主要是有软件决定的,不是切割机硬件。 The cutting efficiency and cutting quality of intersecting line cutting machine manufacturers are the most concerned by users, which is not only the key point for users to check and accept intersecting line cutting machine, but also the standard for users to evaluate the quality of the cutting machine. In particular, it is pointed out that the cutting efficiency and cutting quality of the intersecting line cutting machine are mainly determined by the software, not the cutting machine hardware, under the condition that the hardware of the intersecting line cutting machine is basically the same or similar.
    相关产品推荐地址:
    数控切割机 http://www.hycsk.com
    数控火焰切割机 http://www.hycsk.com
    数控等离子切割机 http://www.hycsk.com
    数控切割机价格 http://www.hycsk.com/category-7.html
    数控火焰切割机价格 http://www.hycsk.com/category-14.html
    数控等离子切割机价格 http://www.hycsk.com/category-15.html
    龙门式数控切割机 http://www.hycsk.com/category-7.html
    龙门式数控火焰切割机 http://www.hycsk.com/product-17.html
    龙门式数控等离子切割机 http://www.hycsk.com/product-16.html
    龙门式数控火焰等离子切割机 http://www.hycsk.com/product-61.html
    便携式数控切割机 http://www.hycsk.com/category-10.html
    便携式数控火焰切割机 http://www.hycsk.com/product-34.html
    便携式数控等离子切割机 http://www.hycsk.com/product-38.html
    台式数控等离子切割机 http://www.hycsk.com/product-22.html
    台式等离子切割机 http://www.hycsk.com/product-44.html
    风管等离子切割机 http://www.hycsk.com/category-5.html
    通风管道等离子切割机 http://www.hycsk.com/product-43.html
    风管等离子切割机价格 http://www.hycsk.com/product-12.html
    精细等离子切割机 http://www.hycsk.com/product-49.html
    数控精细等离子切割机 http://www.hycsk.com/product-57.html
    小蜜蜂数控火焰切割机 http://www.hycsk.com/product-46.html
    小蜜蜂数控等离子切割机 http://www.hycsk.com/product-47.html
    相贯线切割机 http://www.hycsk.com/product-58.html
    便携式相贯线切割机 http://www.hycsk.com/product-59.html
    数控相贯线切割机 http://www.hycsk.com/category-12.html
主营:1500w光纤激光切割机、3000w光纤激光切割机,6000w光纤激光切割机、12000w光纤激光切割机、激光切管机,全自动激光切管机,管材激光切割机,管板一体激光切割机,全自动卷料激光校平生产线、全自动上下料风管激光切割机、高速数控精细…  更多>>
联系人:华宇诚
地址:武汉市江夏区庙山工业园特1号
邮编:http://www.158cnc.com
电话:18986290037
传真:189-8629-0037
公司网址:http://www.hycsk.com
