上海纽沃柯电子科技有限公司
  • 电源管理IC-AVS1ACP08 -上海纽沃柯
  • 发布时间:2007/6/29 14:08:44   修改时间:2007/6/29 14:08:44 浏览次数:4152
    制造商 产品描述 型号 订货号
    ST Automatic Voltage Switch Controller AVS1ACP08 562-531
    ST Driver IC, complements the Switch (EFS11ACD=163-077, part of Starlight-kit 2-chip set) EFS1ACD 163-090
    ST Autorange Triac Switch AVS10CBI 975-6477
    ST Bi-directional Power Switch for flourescent lamp ignition, 36 to 58W range, complements the driver (EFS1ACD=163-090, part of Starlight 2-chip set) EFS11-T5 163-077
    ST SMPS Primary IC, a PWM circuit with high voltage Power MOSFET. VIPER12ADIP 415-5830
    ST SMPS Primary IC, a PWM circuit with high voltage Power MOSFET. VIPER12ADIP-E 988-2901
    ST SMPS Primary IC, a PWM circuit with high voltage Power MOSFET. VIPER12AS-E 988-2910
    ST SMPS Primary IC, a PWM circuit with Vertical Power MOSFET (600V, 0.5A) VIPER20-E 109-4430
    ST SMPS Primary IC, a PWM circuit with Vertical Power MOSFET (600V, 0.5A) VIPER20. 162-875
    ST Bi-directional Power Switch for flourescent lamp ignition, 18 to 70W range, complements the driver (EFS2ACD=163-107, part of Starlight 2-chip set) EFS21-T5 163-089
    TI BiCMOS Current Mode PWM Controller UCC28C43D 110-6067
    TEL Ultra Low Power, CMOS Output, 2.7V Voltage Detector TC54VC2702EZB 633-276
    TEL Ultra Low Power, Open-drain Output, 2.7V Voltage Detector TC54VN2702EZB 633-288
    TEL Ultra Low Power, Open-drain Output, 4.3V Voltage Detector TC54VN4302EZB 633-264
    TOR 2.0V CMOS Standard Voltage Detector XC61CC2002MRN 105-7787
    TOR 2.0V CMOS Standard Voltage Detector XC61CC2002NRN 105-7788
    TOR 3.0V N-channel, Open-Drain Output, Standard Voltage Detector XC61CN3002MRN 105-7793
    TOR 3.0V N-channel, Open-Drain Output, Standard Voltage Detector XC61CN3002NRN 105-7794
    TOR 4.5V CMOS Standard Voltage Detector XC61CC4502MRN 105-7791
    TOR 4.5V CMOS Standard Voltage Detector XC61CC4502NRN 105-7792
    NSC Switching Regulator Sub-System. +2.5V to 40V, 1.5A LM78S40CN. 407-951
    NSC Switching Regulator Sub-System. +2.5V to 40V, 1.5A LM78S40CN 948-8049
    ZET Single-Cell DC/DC Converter ZXSC100N8TA 113-2759
    ST Dual, Op-Amp with Ored output, Voltage Reference and Current generator TSM101CN. 101-527
    BB Precision Voltage-to-Current Converter/Transmitter. Can convert standard 0V to +10V or 0V to +5V inputs into 4mA to 20mA or 5mA to 25mA outputs. XTR110KP. 407-963
    BB Precision Voltage-to-Current Converter/Transmitter. Can convert standard 0V to +10V or 0V to +5V inputs into 4mA to 20mA or 5mA to 25mA outputs. XTR110KP 109-7543
    MAX Oscillator/Power Driver for Isolated RS485/RS422 MAX253CSA 305-2205
    TI Regulator Linear Fast LDO UC282TDKTTT-ADJ 442-0111
    TI Regulator, LDO Fast Transient Response UC285TD-ADJ 442-0123
    ST 4A Switching Regulator. Voltage range 5.1V to 40V L296. 407-987
    ST 4A Switching Regulator. Voltage range 5.1V to 40V L296 109-4207
    ST 4A Switching Regulator with external programmable limiting current. Voltage range 5.1V to 40V L296/P 787-267
    NSC 3 Terminal Adjustable Current Source - Programmable from 1µA to 10mA. 1V to 40V operation LM334H 407-999
    NSC 3 Terminal Adjustable Current Source - Programmable from 1µA to 10mA. 1V to 40V operation LM334M 948-8057
    NSC 3 Terminal Adjustable Current Source - Programmable from 1µA to 10mA. 1V to 40V operation LM334Z 948-8065
    ST 3 Terminal Adjustable Current Source LM334Z. 408-025
    ST 3 Terminal Adjustable Current Source LM334Z 109-4249
    TI Low voltage Adjustable precision shunt regulator - Vref tol 1% TLV431AID 110-3114
    TI Low voltage Adjustable precision shunt regulator - Vref tol 1.5% TLV431CDBV 110-6062
    MAX High-Side Current-Sense Amplifier MAX472CPA 361-6010
    MAX High-Side Current-Sense Amplifier MAX472ESA 490-4928
    TI Switched Mode Controller (Pulse Width Modulator) Push-Pull. On-chip oscillator, error amplifier and 5V reference TL494CN.. 408-037
    TI 500mA Switching Regulator TL497ACN.. 408-062
    MAX 5V (adjustable), Step-Up DC-DC Controller. Input 1.8V to 16.5V MAX608EPA 787-528
    MAX 5V, Step-Up Charge-Pump DC-DC Converter. Input 2V to 3.6V MAX619CPA 702-614
    TEL Programmable solid state temperature switch with integrated voltage reference. Operating range 4.5V to 18V TC622CPA 789-926
    MAX 28V, Low Power, High Voltage Boost or Inverting DC/DC Converter MAX629ESA 490-5040
    MAX +5V (adjustable) CMOS Step-Up Switching Regulator MAX631ACPA 246-475
    MAX -5V preset output CMOS Inverting Switching Regulator, 5% O/P accuracy. MAX635ACSA 353-4212
    MAX +5V (adjustable) CMOS Step-Down Switching Regulator MAX638ACPA 246-499
    MAX 5.5V to 11.5VIN/5V or adjustable out, Step-Down Switching Regulator MAX639CPA 459-604
    MAX 5.5V to 11.5Vin/5V or adjustable output, Step-down Switching Regulator MAX639CSA 353-4224
    MAX +5V (adjustable) CMOS, 10W Step-Up Switching Regulator MAX641ACPA 246-487
    MAX +5V (adjustable) CMOS, 10W, Step up Switching Regulator, 5% O/P accuracy MAX641ACSA 353-4236
    MAX CMOS Voltage Converter, operates 1.5 to 5.5V (high current ICL7660 upgrade) MAX660CPA 246-440
    MAX CMOS Voltage Converter, operates 1.5 to 5.5V (high current ICL7660 upgrade) MAX660CSA 305-2140
    NSC CMOS, Voltage inverter/doubler, operates 1.5 to 5.5V, high output current MAX660M 948-6291
    MAX 30mA, 12V Output, charge-pump DC/DC Converter, provides output to program byte wide FLASH memories MAX662ACSA 305-1699
    MAX 30mA, 12V Output, charge-pump DC/DC Converter, provides output to program byte wide FLASH memories MAX662ACPA 305-1730
    MAX +5V / programmable low dropout voltage regulator with 250mA output current. MAX667CPA 355-7509
    MAX 5V, Programmable LDO Voltage Regulator (IND TEMP) MAX667ESA 490-5064
    MAX PWM Step-up Controller (IND TEMP) MAX668EUB. 490-5076
    MAX CMOS, Dual Output Voltage Converter, +5V to ±10V MAX680CPA 246-451
    MAX CMOS, Dual Output Voltage Converter, +5V to ±10V MAX680CSA. 490-5088
    MAX CMOS, Dual Output Voltage Converter, +5V to ±10V MAX680ESA 490-5090
    MAX Fast Charge Controller optimised for NiMH batteries that can also be used with NiCd (slight undercharge). Uses zero voltage-slope detection MAX712CPE 459-525
    MAX NiCd/NiMH Battery fast-charge controller MAX713CPE 304-9784
    MAX Fast Charge Controller for NiCd/NiMH battery MAX713CSE 788-960
    MAX 5A, Step-down, Switch mode DC/DC regulator MAX724CCK. 490-5131
    MAX 5V, Step-Down, Current-Mode PWM DC-DC Converter. Input 5.2V to 11V MAX730ACPA 639-163
    MAX CMOS Step-Up Switching Regulator. 4V to 12V boost specifically designed for FLASH memory (recommended by Intel) MAX732CPA 459-501
    MAX 5V, Step-Down, Current-Mode PWM DC-DC Converter. Input 6V to 16V. MAX738ACPA 639-175
    MCHIP Lithium-Ion Battery Charge Controller - one cell application, 4.2V MCP73826-4.2VCHTR. 396-8856
    MCHIP Lithium-Ion Battery Charge Controller - one cell application, 4.2V MCP73826-4.2VCHTR 108-4313
    MAX Low Voltage, Pin-Programmable current-mode switch-mode power supply controller MAX741DCPP 787-693
    MAX Dual-Output, Switch-Mode Regulator (+5V to ±15V or ±12V) MAX743CPE 246-505
    MAX Dual-Output, Switch-Mode Regulator (+5V to ±15V or ±12V) MAX743CWE 490-5143
    MAX LCD Bias Supply, digitally adjustable MAX749CSA 787-700
    MAX -5V / adjustable, negative output, inverting current mde PWM regulator. MAX755CSA 355-7510
    MAX 2VIN/3.3V or 5V out, Step-Up, Switching Regulator MAX756CPA 459-586
    MAX 2VIN/Adjustable Output, Step-Up, Switching Regulator MAX757CPA 459-549
    MAX 12V (adjustable), Step-Up DC-DC Converter. Input2V to 16.5V MAX761CPA 787-711
    MAX 12V (adjustable), Step up DC-DC converter. Input 2V to 16.5V (IND TEMP) MAX761ESA 353-4250
    MAX -5V high effeciency, Inverting Switching Regulator MAX764CSA 353-4261
    FCH Power Switch (SPS). High Voltage power senseFET with integrated current -mode PWM contoller, features extensive overload protection facilities, 650V - 7A continuous drain current KA5M0765RQCTU 360-6740
    MAX High Efficiency, Inverting Switching Regulator MAX765CPA 641-650
    MAX -12V High efficiency, inverting switching regulator. MAX765CSA 355-7522
    MAX 1A, Step up Regulator with 12V or adjustable output MAX771ESA 353-4273
    MAX 1A, Step-Up Regulator with 5/12/15V output or adjustable with two resistors MAX773CPD 794-715
    MAX 1A - 5V Low IQ Inverting DC-DC Switching Regulator MAX774CPA 794-636
    MAX 5A 5V Step-Down, PWM, Voltage Regulator MAX787CCK 787-530
    MAX Switched Capacitor Voltage Inverter MAX828EUK-T 794-624
    MAX CMOS charge-pump switched capacitor voltage inverter. (IND TEMP) MAX829EUK-T 353-4352
    MAX 5v output, 1A ,step-down, PWM Switch mode DC-DC regulator. MAX831CWE 355-7534
    MAX Low Noise, Regulated GaAs FET Bias with fixed -2V or adjustable - 0.5V to -9.4V Output at 4mA, for Cellular Telephone transmitter amplifiers. (IND TEMP) MAX840ISA 788-971
    MAX 100mA, 5V Transformer Driver MAX845ESA 490-5210
    MAX 3.3V/5V pin-selectable output, step-up DC-DC converter MAX856CSA 353-4364
    MAX CMOS Voltage Inverter or Positive Voltage Doubler, High Switching Frequencies, 3 Switching Modes 6, 50 or 130KHz (IND TEMP) MAX860ISA 639-187
    MAX CMOS Voltage Inverter or Positive Voltage Doubler, High Switching Frequencies, 3 Switching Modes 13, 100 or 250KHz (IND TEMP). MAX861ISA 322-8447
    MAX Regulated, Adjustable -2x Inverting Charge Pump MAX868EUB 162-115
    MAX 2.5V 0.5mA Low Drop-out precision voltage reference. MAX872CSA 355-7546
    FCH Power Switch (SPS). High Voltage power senseFET with integrated current-mode PWM controller, features extensive overload protection facilities, 650V - 9A continuous drain current KA5M0965QTU 360-6752
    LT Micropower Regulator and Comparator LT1020CSW 476-7020
    LT Micropower Regulator and Comparator LT1020CSW#PBF 955-9434
    LT CMOS Voltage Converter operates 1.5 to 9V. Provides voltage inversion. Voltage doubling LTC1044CN8 408-086
    LT CMOS Voltage Converter operates 1.5 to 9V. Provides voltage inversion. Voltage doubling LTC1044CN8#PBF 956-0734
    TEL CMOS Voltage Converter operates 1.5 to12V. Provides voltage inversion. TC1044SCPA 703-667
    LT CMOS Voltage Converter, operates 1.5 to 6V LTC1046CN8 638-420
    LT CMOS Voltage Converter, operates 1.5 to 6V LTC1046CN8#PBF 956-0742
    LT Switched Capacitor Voltage Converter, 100mA LT1054CN8 408-098
    LT Switched Capacitor Voltage Converter, 100mA LT1054CN8#PBF 955-9515
    LT Switched Capacitor Voltage Converter with Regulator LT1054CS8 476-7056
    LT Switched Capacitor Voltage Converter with Regulator LT1054CS8#PBF 955-9523
    LT 5A Switching Regulator optimised for use in Step-Up, "boost" and other configurations LT1070CT#PBF 955-9558
    LT 2.5A Switching Regulator as LT1070CT LT1071CT 408-130
    LT 2.5A Switching Regulator as LT1070CT LT1071CT#PBF 955-9566
    LT 1.25A Switching Regulator as LT1070CT LT1072CT 408-141
    LT 1.25A Switching Regulator as LT1070CT LT1072CT#PBF 955-9582
    LT 1.25A High Efficiency Switching Regulator LT1072CN8 476-7081
    LT 1.25A High Efficiency Switching Regulator LT1072CN8#PBF 955-9574
    LT Micropower Switching Regulator with a minimum supply voltage of 1V. Step-Up/Step-Down modes, adjustable output LT1073CN8 295-917
    LT Micropower Switching Regulator with a minimum supply voltage of 1V. Step-Up/Step-Down modes, adjustable output LT1073CN8#PBF 955-9590
    LT 5A Switching Regulator optimised for use in Step-Down, "flyback" and other configurations. Input 5 to 45V LT1074CT 246-608
    LT 5A Switching Regulator optimised for use in Step-Down, "flyback" and other configurations. Input 5 to 45V LT1074CT#PBF 955-9604
    LT Step down Switching Regulator LT1074HVCT 476-7093
    LT Step down Switching Regulator LT1074HVCT#PBF 955-9612
    LT Step down Switching Regulator LT1074IT 476-7100
    LT Step down Switching Regulator LT1074IT#PBF 955-9620
    LT Step down Switching Regulator LT1076CQ 476-7111
    LT Step down Switching Regulator LT1076CQ#PBF 955-9639
    LT 2A Adj. Switching Regulator as LT1074CT LT1076CT 295-930
    LT 2A Adj. Switching Regulator as LT1074CT LT1076CT#PBF 955-9647
    LT Step down Switching Regulator LT1076CT-5 476-7123
    LT Step down Switching Regulator LT1076CT-5#PBF 955-9655
    LT Micropower Step-Up Switching Regulator. 5V to 12V boost specifically designed for FLASH memory LT1109ACN8-12 295-905
    LT Micropower DC/DC converter Flash memory VPP Generator LT1109ACS8 476-7196
    LT Micropower DC/DC converter Flash memory VPP Generator LT1109ACS8#PBF 955-9949
    LT 12V Micropower DC/DC converter Flash memory VPP Generator LT1109ACS8-12 476-7202
    LT 12V Micropower DC/DC converter Flash memory VPP Generator LT1109ACS8-12#PBF 955-9957
    LT 12V Micropower DC/DC converter Flash memory VPP Generator LT1109CS8-12 476-7214
    LT 12V Micropower DC/DC converter Flash memory VPP Generator LT1109CS8-12#PBF 955-9965
    LT Micropower DC/DC Coverter LT1111CN8 476-7226
    LT Micropower DC/DC Coverter LT1111CN8#PBF 955-9973
    LT Micropower DC/DC Coverter Adjustable LT1111CS8 476-7238
    LT Micropower DC/DC Coverter Adjustable LT1111CS8#PBF 955-9981
    LT High Efficiency, Synchronous Step-Down Switching Regulator LTC1148HVCN 638-316
    LT High Efficiency, Synchronous Step-Down Switching Regulator LTC1149CN 638-328
    LT 5A, High Efficiency, Switching Regulator optimised for use in Step-Up, "boost" and other configurations (enhanced LT1070CT) LT1170CT 525-870
    LT 5A, High Efficiency, Switching Regulator optimised for use in Step-Up, "boost" and other configurations (enhanced LT1070CT) LT1170CT#PBF 956-0157
    LT High Efficiency Switching Regulators LT1170HVCT 476-7263
    LT High Efficiency Switching Regulators LT1170HVCT#PBF 956-0165
    LT 2.5A High Efficiency Switching Regulators LT1171CT 476-7275
    LT 2.5A High Efficiency Switching Regulators LT1171CT#PBF 956-0173
    LT 1.25A, High Efficiency, Switching Regulator as LT117OCT (enhanced LT1072CT) LT1172CN8 525-881
    LT 1.25A, High Efficiency, Switching Regulator as LT117OCT (enhanced LT1072CT) LT1172CN8#PBF 956-0181
    LT 1.25A High Efficiency Switching Regulators LT1172CS8 476-7287
    LT 1.25A High Efficiency Switching Regulators LT1172CS8#PBF 956-0190
    LT Micropower DC/DC Converter LT1173CN8 476-7299
    LT Micropower DC/DC Converter LT1173CN8#PBF 956-0203
    LT Micropower DC/DC Converter LT1173CS8 476-7305
    LT Micropower DC/DC Converter LT1173CS8#PBF 956-0211
    LT High Efficiency, CMOS Step-Down and Inverting Voltage Converter. LTC1174CN8 569-094
    LT High Efficiency, CMOS Step-Down and Inverting Voltage Converter. LTC1174CN8#PBF 956-0904
    LT Current Mode DC/DC Converter LTC1174CS8 476-7536
    LT Current Mode DC/DC Converter LTC1174CS8#PBF 956-0912
    LT 5V Current Mode DC/DC Converter LTC1174CS8-5 476-7548
    LT 5V Current Mode DC/DC Converter LTC1174CS8-5#PBF 956-0920
    LT 1.2A, High Efficiency, CMOS Step-Down Current Mode Converter LTC1265CS 641-261
    LT Micropower, Step-up Voltage Converter with Low Battery Detector, adjustable output LT1303CN8 569-069
    LT Micropower, Step-up Voltage Converter with Low Battery Detector, adjustable output LT1303CN8#PBF 956-0378
    LT 5V Micropower DC/DC Converter LT1303CN8-5 476-7366
    LT 5V Micropower DC/DC Converter LT1303CN8-5#PBF 956-0386
    LT 600kHz, PWM DC-DC Converter LT1307CN8 796-311
    LT 600kHz, PWM DC-DC Converter LT1307CN8#PBF 956-0394
    LT Single Cell Micropower PWM DC/DC LT1307CS8 476-7378
    LT Single Cell Micropower PWM DC/DC LT1307CS8#PBF 956-0408
    LT 500kHz High Efficiency 1.5A Switching Regulator LT1372CN8 386-2203
    LT Step-down, Adj. Switching Regulator, 1.5A, 500kHz LT1375CN8 386-2239
    LT Step-down, Adj. Switching Regulator, 1.5A, 500kHz LT1375CN8#PBF 956-0491
    LT Step-down, 5.0V, Switching Regulator, 1.5A, 500kHz LT1375CN8-5 386-2240
    LT Step-down Adj. Switching Regulator 1.5A, 500kHz LT1376CN8 386-2276
    LT Step-down 5.0V Switching Regulator 1.5A, 500kHz LT1376CN8-5 386-2288
    LT Step-down 5.0V Switching Regulator 1.5A, 500kHz LT1376CN8-5#PBF 956-0505
    LT Step-down Adj. Switching Regulator 1.5A, 500kHz (IND TEMP) LT1376IN8 386-2290
    LT Step-down Adj. Switching Regulator 1.5A, 500kHz (IND TEMP) LT1376IN8#PBF 956-0513
    LT Micropower Temperature, Power Supply and Differential Voltage Monitor LTC1392CN8 641-297
    LT Hot Swap Controller LTC1422CN8 386-2537
    TI Dual PWM power control circuit TL1451ACD 110-3110
    TI Dual PWM power control circuit TL1451ACN 238-8510
    LT Monolithic Buck Switching Regulator LT1507CS8 476-7380
    LT Monolithic Buck Switching Regulator LT1507CS8#PBF 956-0564
    LT SEPIC Constant Current/Voltage Battaery Charger LT1512CS8 476-7391
    LT SEPIC Constant Current/Voltage Battaery Charger LT1512CS8#PBF 956-0572
    LT SEPIC Constant/Programmable Current Battery Charger LT1513CR 476-7408
    LT SEPIC Constant/Programmable Current Battery Charger LT1513CR#PBF 956-0580
    PS Switched Mode Power Supply (SMPS) Converter TEA1521P/N2.112 880-0499
    PS Switched Mode Power Supply (SMPS) Converter TEA1522P/N2.112 880-0502
    PS Switched Mode Power Supply (SMPS) Converter TEA1523P/N2.112 880-0510
    LT High Efficiency, CMOS Step-Down Current Mode Converter LTC1574CS 641-250
    LT High Efficiency, CMOS Step-Down Current Mode Converter LTC1574CS#PBF 956-1285
    LT LDO Positive Regulator LT1585CM 476-7433
    LT LDO Positive Regulator LT1585CM#PBF 956-0637
    LT LDO Positive Regulator LT1587CT 476-7445
    LT LDO Positive Regulator LT1587CT#PBF 956-0645
    LT 3.3V LDO Positive Regulator LT1587CT-3.3 476-7457
    LT 3.3V LDO Positive Regulator LT1587CT-3.3#PBF 956-0653
    MAX CardBus and PCMIA Power Switch with Serial Interface MAX1601EA 794-703
    MCHIP Single 1A 1.4 MHz Synchronous Buck Regulator MCP1612-ADJI/MS 875-2915
    MAX High-voltage, Low-power, Linear Regulator for RAM and Microcontroller power (IND TEMP) MAX1615EUKT 301-2645
    MAX 3.3V/5V output step-down DC/DC controller with 100% duty cycle. (IND TEMP) MAX1626ESA 490-4667
    MCHIP High-Speed, Microcontroller-Adaptable, Pulse Width Modulator MCP1630-E/MS 921-8432
    MAX Adjustable output, switch-mode current sources with synchronous rectifier MAX1640EEE 493-958
    MAX 2A low voltage step-down regulator with synchronoue rectification and internal switches . MAX1644EAE 490-4679
    LT Wide Input Range, High Efficiency stepdown Switching Regulator LT1676CN8 386-2392
    LT Wide Input Range, High Efficiency stepdown Switching Regulator LT1676CN8#PBF 956-0661
    LT Wide Input Range, High Efficiency stepdown Switching Regulator (IND TEMP) LT1676IN8 386-2409
    MAX High Efficiency, Low-Supply Current, step-up DC/DC converter MAX1676EUB 301-2657
    MAX 125mA frequency-selectable switched capacitor voltage converter. MAX1680ESA 490-4680
    MAX 5.5V input, PWM, DC/DC step-down Regulator MAX1692EUB 301-2669
    LT Dual, 550kHz Synchronous 2-Phase Switching Regulator Controller LTC1702CGN 386-2598
    LT Dual, 550kHz Synchronous 2-Phase Switching Regulator Controller (IND TEMP) LTC1702IGN 386-2604
    LT Dual, 550kHz Synchronous 2-Phase Switching Regulator Controller (IND TEMP) LTC1702IGN#PBF 956-1315
    MAX 5V/adjustable, high efficiency, low noise Step-up DC-DC convertor. MAX1703ESE 355-7558
    MAX High Efficiency, High-Current, step-up DC/DC converter with Linear Regulator output. (QSOP, IND TEMP) MAX1705EEE 301-2670
    MAX High efficiency, high current, step up DC/DC converter with linear regulator output and internal 0.5A N-channel MOSFET switch MAX1706EEE 353-4030
    ST Intelligent Power Switch, 0.5Amp, 6 to 48V, High or Low side configuration TDE1707BFP 323-6420
    LT High Efficiency Synchronous Step-down Switching Regulator LTC1735CGN 386-2616
    MAX High voltage (36V) step-down DC/DC controller MAX1745EUB 490-4692
    LT High Voltage, Stepdown Switching Regulator, 200kHz, 1.5A LT1766EGN 386-2410
    LT High Voltage, Stepdown Switching Regulator, 200kHz, 1.5A LT1766EGN#PBF 956-0670
    LT High Voltage, Stepdown Switching Regulator, 200kHz, 1.5A (IND TEMP) LT1766IGN 386-2422
    LT High Voltage, Stepdown Switching Regulator, 200kHz, 1.5A (IND TEMP) LT1766IGN#PBF 956-0688
    NSC Injector Drive Controller for external power Darlington transistor driving high current solenoid LM1949N 704-507
    B'MARQ Programmable multi-chemistry fast charge management IC with Peak Voltage Detection (PVD) BQ2000PN. 352-8212
    B'MARQ Programmable multi-chemistry fast charge management IC with temperature rate of change detection BQ2000SN-B5 110-1394
    B'MARQ Programmable multi-chemistry fast charge management IC with temperature rate of change detection BQ2000TSN. 352-8248
    B'MARQ NiCd/NiMH Fast charge Management IC with Peak Voltage Detection (PVD) BQ2002PN 352-8250
    B'MARQ NiCd/NiMH Fast charge Management IC with Peak Voltage Detection (PVD) BQ2002SN 352-8261
    B'MARQ Fast NiCd/NiMH Battery Charger BQ2003PN 110-1405
    B'MARQ NiCd/NiMH fast charge management IC with temperature rate of change detection BQ2003SN. 352-8285
    B'MARQ NiCd/NiMH fast charge management IC with Peak Voltage Detection (PVD) and volume detector BQ2004PN 110-1397
    B'MARQ NiCd/NiMH fast charge management IC with Peak Voltage (PVD) and volume detection) BQ2004SN 110-1398
    B'MARQ Fast charge management IC for dual NiCd/NiMH battery packs BQ2005PN 352-8315
    B'MARQ POWER MINDER TM low cost charge/discharge counter peripheral with 1Kb NVRAM BQ2018SN. 352-8339
    B'MARQ Lead acid battery fast charge management controller BQ2031PN. 352-8340
    B'MARQ Lead acid battery fast charge management controller BQ2031SN-A5 110-1401
    B'MARQ Gas gauge battery charge recorder with SMBus interface BQ2040SN. 352-8364
    B'MARQ Li-Ion & Li-Pol linear charge management controller 4.1V charge regulation BQ2057SN 110-1403
    B'MARQ Li-Ion & Li-Pol linear charge management controller 4.2V charge regulation BQ2057CSN 110-1404
    B'MARQ Li-Ion & Li-Pol linear charge management controller 8.4V charge regulation BQ2057WTS 501-1700
    B'MARQ SBSv1.1-compliant Gas-gauge IC BQ2060SS-E411 501-1711
    TI LI-ION and LI-POL Gas Gauge BQ2083DBT 441-9923
    TI Power Interface Switch for Power Over Ethernet PoE powered devices TPS2370D 441-9984
    TI Power Interface, IEEE802.3AF TPS2375D 845-6860
    TI Power Interface, IEEE802.3AF TPS2377D 845-6887
    TI Octal Power Sourcing Equipment Power Manager for Power over Ethernet Switch applications TPS2383APMRG4 959-4035
    TI Hot swap Controller TPS2390DGK 441-9947
    TI Hot Swap Controller TPS2391DGK 441-9959
    TI 48V Hot Swap Power Manager, Full-Featured TPS2392PW 441-9960
    TI 48V Hot Swap Power Manager TPS2393PW 441-9972
    TI LI-ION Charger with Autonomous USB Port ad AC Adapter Supply Management BQ24020DRCR 441-9900
    MAX Smart Battery Monitor with unique 64-bit serial number, 10-bit A/D, temperature sensor, RTC, 40bytes of non-volatile EEPROM (IND TEMP) DS2437S 119-568
    ON 500mA Switching Regulator, 3.3V Output, 5 to 40V Supply LM2574N-3.3 334-3571
    NSC 1A Step-down voltage regulator, adjustable output. LM2590HVT-ADJ. 412-4868
    NSC 1A Step-down voltage regulator, adjustable output. LM2590HVT-ADJ 948-9517
    NSC 1A Step-down voltage regulator. LM2590HVT-3.3. 412-4844
    NSC 1A Step-down voltage regulator. LM2590HVT-3.3 948-9495
    NSC 1A Step-down voltage regulator LM2590HVT-5.0. 412-4856
    NSC 1A Step-down voltage regulator LM2590HVT-5.0 948-9509
    NSC 1A Step-down voltage regulator, adjustable output LM2591HVT-ADJ. 412-4893
    NSC 1A Step-down voltage regulator, adjustable output LM2591HVT-ADJ 948-9541
    NSC 1A Step-down voltage regulator LM2591HVT-3.3. 412-4870
    NSC 1A Step-down voltage regulator LM2591HVT-3.3 948-9525
    NSC 1A Step-down voltage regulator LM2591HVT-5.0. 412-4881
    NSC 1A Step-down voltage regulator LM2591HVT-5.0 948-9533
    NSC High Efficiency, Synchronous Step-Down DC-DC Converter LM2650M-ADJ. 791-805
    NSC High Efficiency, Synchronous Step-Down DC-DC Converter LM2650M-ADJ 949-4200
    NSC 2A Step-down voltage regulator, adjustable output LM2592HVT-ADJ. 412-4923
    NSC 2A Step-down voltage regulator, adjustable output LM2592HVT-ADJ 948-9584
    NSC 2A Step-down voltage regulator, 3.3V output LM2592HVT-3.3. 412-4900
    NSC 2A Step-down voltage regulator, 3.3V output LM2592HVT-3.3 948-9550
    NSC 2A Step-down voltage regulator, 5V output. LM2592HVT-5.0. 412-4911
    NSC 2A Step-down voltage regulator, 5V output. LM2592HVT-5.0 948-9576
    NSC 2A Step-down voltage regulator, adjustable output LM2593HVT-ADJ. 412-4959
    NSC 2A Step-down voltage regulator, adjustable output LM2593HVT-ADJ 948-9606
    NSC 2A Step-down voltage regulator, 5V output. LM2593HVT-5.0. 412-4947
    NSC 2A Step-down voltage regulator, 5V output. LM2593HVT-5.0 948-9592
    NSC Current mode PWM inverting switching regulator. (IND TEMP) LM2611AMF 977-9094
    NSC Step-up DC/DC converter for low input voltage systems. LM2621MM 977-9248
    NSC Two-phase synchronous triple regulator. LM2633MTD 412-5071
    NSC 5-Bit Programmable Synchronous Buck regulator Controller, O/P +1.3V to +3.5V LM2636MTC 332-6640
    NSC 1.5A high efficiency synchronous regulator. LM2651MTC-ADJ 977-8900
    NSC Switched Capacitor Voltage Converter, inverts voltage in the range 1.5V to 5.5V, with selectable frequency control pin for oscillator frequency of 10kHz or 80kHz LM2660M. 688-060
    NSC Switched Capacitor Voltage Converter, inverts voltage in the range 1.5V to 5.5V, with selectable frequency control pin for oscillator frequency of 10kHz or 80kHz LM2660M 949-3816
    NSC Switched Capacitor Voltage Converter, inverts voltage in the range 1.5V to 5.5V, with oscillator frequency of 80kHz and external shutdown pin LM2661M 688-071
    NSC Switched Capacitor Voltage Converter, inverts or doubles inputvoltage in the range 1.5V to 5.5V, with selectable oscillator frequency of 20kHz or 150kHz- LM2662M 930-6803
    NSC Switched Capacitor Voltage Converter, inverts voltage in the range 1.8V to 5.5V. Operates at 160kHz oscillator frequency. 1µA shutdown current LM2664M6 977-9671
    NSC Switched capacitor voltage doubling inverter, 10mA o/p current LM2682M. 360-6417
    NSC Switched capacitor voltage doubling inverter, 10mA o/p current LM2682M 948-6550
    NSC Dual O/P, Switched capacitor Voltage Converter I/P +2.85V to +6.5V, O/P +5V 50mA & -5V 15mA LM2685MTC 977-8691
    NSC CMOS Voltage Converter, I/P +2.85V to +6.5V, O/P +5V 50mA LM2686MTC 977-8616
    NSC Low Noise Switched Cap. Voltage Inverter, I/P +2.7V to +5.5V, O/P -1.5V to -5.2V 10mA LM2687MM 977-8624
    NSC 2.5A Step-Up PWM DC/DC Converter, adjustable output. LM2700MT-ADJ 977-8993
    NSC Switched Capacitor Voltage Converter, inverts voltage in the range 1.8V to 5.5V LM2767M5 360-6430
    ST High Performance Pulse Width Modulation Controller E-UC2842BD1 988-2499
    ON Enhanced Current Mode PWM Controller. Operating range 11V to 30V, 1A. (IND TEMP) UC2842AD 300-4545
    ST High Performance Pulse Width Modulation Controller UC2842AD1 323-6330
    ON Enhanced Current Mode PWM Controller (IND TEMP) UC2842AN 701-956
    ST High Performance Pulse Width Modulation Controller E-UC2843BD1 988-2502
    ON Enhanced Current Mode PWM Controller UC2843AN 701-968
    ON Enhanced Current Mode PWM Controller. Operating range 8.2V to 30V, 1A. UC2843BD1 300-4569
    ST High Performance Pulse Width Modulation Controller UC2844AD1 323-6353
    ST High Performance Pulse Width Modulation Controller E-UC2845BD1 988-2510
    ON Current Mode PWM Controller (IND TEMP) UC2844N 701-970
    ON Current Mode PWM Controller (IND TEMP) UC2845N 701-981
    TI LI-ION or LI-POL Battery Protection BQ29311PW 441-9935
    B'MARQ Lithium-ion charge Management IC with Intergrated Switching Controller BQ2954PN 352-8406
    B'MARQ Lithium-ion charge Management IC with Intergrated Switch Controller BQ2954SN 352-8418
    IR PWM 400 KHz Sync Controller IRU3037ACSPBF 102-3270
    IR PWM 200 KHz Sync Controller IRU3037CSPBF 102-3271
    IR X-PHASE VRD10 Control IC with VccVid and Overtemp Detect IR3080MPBF 102-3258
    IR X-PHASE VR 10.0 Control IC IR3081AMPBF 102-3259
    IR X-PHASE Opteron or Athlon 64 Control IC IR3082MPBF 102-3261
    IR X-PHASE Phase IC with OVP with fault overtemp detect IR3086AMPBF 102-3262
    IR X-PHASE IC with Fault and Overtemp Detect IR3088AMPBF 102-3264
    AD Micropower Step Up/Down adjustable high frequency Switching Regulator ADP3000AN 314-6443
    MICR 1.25A Switching Regulator, Voltage range 3V to 40V. (IND TEMP)... MIC3172BN 790-333
    NSC 200mA Buck-Boost switched capacitor DC/DC converter, 3.3V output. (TSSOP) LM3352MTC-3.3 977-8470
    NSC Lithium-Ion Battery Charge Controller - one cell application LM3420M5-4.2 977-9663
    ON Overvoltage Crowbar Protection IC MC3423P1 526-502
    NSC High-side N-channel controller for switching regulator. LM3477MM 977-9191
    NSC High efficiency, low side N-channel controller for switching regulators. LM3488MM 977-8888
    NSC Switched Mode Power Supply Circuit. (Improved version of the Industry Standard 3524) LM3524DN. 408-300
    NSC Switched Mode Power Supply Circuit. (Improved version of the Industry Standard 3524) LM3524DN 948-8162
    ST Switched Mode Power Supply Circuit SG3524N. 408-323
    ST Switched Mode Power Supply Circuit SG3524N 109-4322
    TI Switched Mode Power Supply Circuit SG3524D 110-3188
    TI Switched Mode Power Supply Circuit SG3524N.. 559-192
    ST Switched Mode Power Supply Circuit SG3524P. 559-155
    UNI Enhanced Switched Mode Power Supply Circuit UC3524AN 110-1413
    ST PWM Controller up to 500kHz operation with dual source/sink output drivers for power MOS. NOR logic output SG3525AN. 408-359
    UNI PWM Controller up to 400kHz operation with dual source/sink output drivers for power MOS. NOR logic output. UC3526AN 110-1440
    UNI PWM Controller up to 600kHz operation with dual source/sink output drivers for power MOS. NOR logic output. UC3526DW 110-1441
    UNI Low Power PWM Controller up to 500KHz operation with single, Totem-Pole output UCC3570N 110-1448
    UNI Buck PWM Step-Down Voltage Regulator UC3573N 700-502
    NSC Switched Mode Regulator LM3578AM 953-775
    NSC Switched Mode Regulator LM3578AN. 408-384
    NSC Switched Mode Regulator LM3578AN 948-8170
    UNI Switch Mode Secondary Side Post Regulator UCC3583N 113-451
    UNI Dual Schottky Diode Bridge UC3610N 110-1452
    UNI Switched Mode Controller for DC Motor Drive UC3637N 110-1443
    NSC Universal Battery Charger for Li-Ion, NiMH and Ni-Cd batteries. LM3647IM. 412-5319
    NSC Universal Battery Charger for Li-Ion, NiMH and Ni-Cd batteries. LM3647IM 948-9690
    IR 1% Accurate Synchronous PWM Controller IR3637SPBF 101-6067
    TS Current Mode PWM Controller TS3842BCD 726-1314
    TS Current Mode PWM Controller TS3842BCS 726-1322
    产品目录链接如下,敬请点击查看:
    http://www.newark.com/jsp/content/printCatalog.jsp?cat=cat124&page=1&display=single
    TYCO产品专辑目录链接如下,请点击查看:
    http://www.newark.com/jsp/content/printCatalog.jsp?cat=tyco&page=1&display=single
    Farnell-Newark部分产品特价回馈客户,全新产品,上海现货库存,欢迎查询订购。
    具体特价产品链接如下:http://www.vanking.cn/cp.php?nowmenuid=101411
    请登陆我司网站的"产品查询"栏,进入"NEWARK INONE电子产品世界"和"FARNELL INONE电子产品世界"搜索您需要的产品。
    通过我们的服务,您将轻松购买超过25万种世界知名品牌的电子元器件
    我们的服务特点:
    不设最小订购数量 不设最低订货金额  上海库存2-3日送达 国外库存7-10日送达
上海纽沃柯电子科技有限公司
联系人:魏先生
地址:万源路788弄32号202室
邮编:201103
电话:QQ:1003000751 13501905617
传真:021-34228879
公司网址:http://www.vanking.cn
  • 黎浩 在2023/12/22 8:33:00留言
  • 详细留言:帮客户询价
  • 在2023/7/27 11:11:00留言
  • 详细留言:MHP1400R010F*18PCS
  • 在2023/3/2 17:44:00留言
  • 杨女士 在2022/11/8 16:08:00留言
  • 伍余华 在2022/2/11 22:05:00留言
  • 详细留言:TYCO FLHTCO311-14-2
