上海纽沃柯电子科技有限公司
  • ZMD-TSic温度传感器-上海纽沃柯
  • 发布时间:2007/6/29 14:58:06   修改时间:2007/6/29 14:58:06 浏览次数:3575
  • ZMD America公司推出的TSic温度传感器经过全面测试和校准,具有绝对测量精度,无需校准,使用方便,且具有长期稳定性。
    该传感器具有高精度带隙基准的PTAT输出、低功耗精密ADC,及片上带有E2PROM的DSP核,可用来精密计算输出温度信号。TSic温度传感器由ZMD America和IST AG联合开发。其它同类产品精度小于±0.5,且具有更高的成本和功耗。
    TSic具有快速响应时间(63%温度范围内为0.8s,采用SOP-8或e-line封装),3s之内可精确测出水温。用户定制的TSic COF器件测试周期仅为4ms。
    1286235
    TSIC101WST
    IC, SM T-SENSOR VOUT SOP8; Temp, op. min:-50°C; Temp, op. max:150°C; Pins, number of:8; Case style:SOP; Base number:101; Voltage, supply max:6V
    1286348
    TSIC101WEB
    IC, T-SENSOR VOUT E-LINE; Temp, op. min:-50°C; Temp, op. max:150°C; Pins, number of:3; Case style:E-Line; Base number:101; Voltage, supply max:6V
    1286349
    TSIC201WST
    IC, SM T-SENSOR VOUT SOP8; Temp, op. min:-50°C; Temp, op. max:150°C; Pins, number of:8; Case style:SOP; Base number:201; Voltage, supply max:6V
    1286350
    TSIC201WEB
    IC, T-SENSOR VOUT E-LINE; Temp, op. min:-50°C; Temp, op. max:150°C; Pins, number of:3; Case style:E-Line; Base number:201; Voltage, supply max:6V
    1286351
    TSIC301WST
    IC, SM T-SENSOR VOUT SOP8; Temp, op. min:-50°C; Temp, op. max:150°C; Pins, number of:8; Case style:SOP; Base number:301; Voltage, supply max:6V
    1286352
    TSIC301WEB
    IC, T-SENSOR VOUT E-LINE; Temp, op. min:-50°C; Temp, op. max:150°C; Pins, number of:3; Case style:E-Line; Base number:301; Voltage, supply max:6V
    1286354
    TSIC106WST
    IC, SM T-SENSOR DOUT SOP8; Temp, op. min:-50°C; Temp, op. max:150°C; Pins, number of:8; Case style:SOP; Base number:106; Voltage, supply max:6V
    1286355
    TSIC106WEB
    IC, T-SENSOR DOUT E-LINE; Temp, op. min:-50°C; Temp, op. max:150°C; Pins, number of:3; Case style:E-Line; Base number:106; Voltage, supply max:6V
    1286356
    TSIC206WST
    IC, SM T-SENSOR DOUT SOP8; Temp, op. min:-50°C; Temp, op. max:150°C; Pins, number of:8; Case style:SOP; Base number:206; Voltage, supply max:6V
    1286357
    TSIC206WEB
    IC, T-SENSOR DOUT E-LINE; Temp, op. min:-50°C; Temp, op. max:150°C; Pins, number of:3; Case style:E-Line; Base number:206; Voltage, supply max:6V
    1286358
    TSIC306WST
    IC, SM T-SENSOR DOUT SOP8; Temp, op. min:-50°C; Temp, op. max:150°C; Pins, number of:8; Case style:SOP; Base number:306; Voltage, supply max:6V
    1286359
    TSIC306WEB
    IC, T-SENSOR DOUT E-LINE; Temp, op. min:-50°C; Temp, op. max:150°C; Pins, number of:3; Case style:E-Line; Base number:306; Voltage, supply max:6V
    1286360
    TSIC506FST
    IC, SM T-SENSOR DOUT SOP8; Temp, op. min:-10°C; Temp, op. max:60°C; Pins, number of:8; Case style:SOP; Base number:506; Voltage, supply max:6V
    1286361
    TSIC506FEB
    IC, T-SENSOR DOUT E-LINE; Temp, op. min:-10°C; Temp, op. max:60°C; Pins, number of:3; Case style:E-Line; Base number:506; Voltage, supply max:6V
    1286362
    TSIC LABKIT
    TSIC EVALUATION KIT
    1286363
    ZMD31010AAG1-T
    IC, SM SENSOR SIGNAL CONDITIONING SOP8; Temp, op. min:-50°C; Temp, op. max:150°C; Pins, number of:8; Case style:SOP; Base number:31010; Voltage, supply max:6V
    1286364
    ZMD31010KIT
    SSC EVALUATION KIT
    1286367
    ZMD31050DIG1-T
    IC, SM SENSOR SIGNAL CONDITIONING SOP16; Temp, op. min:-25°C; Temp, op. max:85°C; Pins, number of:16; Case style:SSOP; Base number:31050; Voltage, supply max:6.5V
    1286370
    ZMD31050KIT
    SSC EVALUATION KIT
    详细技术资料下载
    欢迎点击查询订购更多ZMD产品
    产品目录链接如下,敬请点击查看:
    http://www.newark.com/jsp/content/printCatalog.jsp?cat=cat124&page=1&display=single
    TYCO产品专辑目录链接如下,请点击查看:
    http://www.newark.com/jsp/content/printCatalog.jsp?cat=tyco&page=1&display=single
    Farnell-Newark部分产品特价回馈客户,全新产品,上海现货库存,欢迎查询订购。
    具体特价产品链接如下:http://www.vanking.cn/cp.php?nowmenuid=101411
    请登陆我司网站的"产品查询"栏,进入"NEWARK INONE电子产品世界"和"FARNELL INONE电子产品世界"搜索您需要的产品。
    通过我们的服务,您将轻松购买超过25万种世界知名品牌的电子元器件
    我们的服务特点:
    不设最小订购数量 不设最低订货金额  上海库存2-3日送达 国外库存7-10日送达
上海纽沃柯电子科技有限公司
联系人:魏先生
地址:万源路788弄32号202室
邮编:201103
电话:QQ:1003000751 13501905617
传真:021-34228879
公司网址:http://www.vanking.cn
  • 黎浩 在2023/12/22 8:33:00留言
  • 详细留言:帮客户询价
  • 在2023/7/27 11:11:00留言
  • 详细留言:MHP1400R010F*18PCS
  • 在2023/3/2 17:44:00留言
  • 杨女士 在2022/11/8 16:08:00留言
  • 伍余华 在2022/2/11 22:05:00留言
  • 详细留言:TYCO FLHTCO311-14-2
