Delikon Electrical Flexible Conduit & Fittings Co., Ltd.
  • LIQUIDTIGHT STEEL FLEXIBLE CONDUIT PVC covering LTFC,liquidtight connector,LIQUID TIGHT CONDUIT
  • 发布时间:2011/8/12 11:15:45   修改时间:2011/8/12 11:15:45 浏览次数:1424
         Electro-galvanized galvanized steel strip which is then profiled and helically wound into a flexible conduit. It is then coated with heavy duty P.V.C. with a smooth surface enabling the fitting to seal completely when assembled. The grade of P.V.C. selected allows greater resistance to a wide range of oils and greases. The product are Smooth P.V.C. coverd, Good crush resistance,  Water resistant etc.
    APPLICATION :
    * A liquid tight system developed for higher temperature applications such as machine tools and/or  where the conduit will be required to operate in environments where oils and greases are predominant.
    * Used in package lines, conveyors, assembly line, machine tools, material handling equipments, outdoor light fitting welders, pumps, blowers, grinders, heating equipment and automated lines for forging, plating, molding, blasting, rolling, die casting, processing, extruding, etc.
    * It is used for wiring circuits located in extremely wet or damp areas and for machines and equipment where ruggedness is required.
    * Suitable for inside cold storage areas and is suitable for wiring most types of industrial equipment, which are subjected to moisture from coolant, and other wiring hazards.
    http://www.delikon.com
我司专业制造电线保护软管及接头: 1)金属软管 2)防水金属软管,接头,包塑金属软管 3)防爆电线保护软管:防水,防爆,耐磨损,抗干扰 主要用于: 机械设备电线保护; 仪器仪表电线保护; 汽车轮船电线保护. 工厂商业电线保护. ======================= http://www.del…  更多>>
联系人:delikon
地址:http://www.delikon.com
邮编:216000
电话:21_000000000
传真:_
公司网址:http://www.delikon.com
  • Craig PAN 在2023/7/3 16:12:00留言
  • 详细留言:关于贵司 YF-90604 Delikon 1/2" Reel 样品信息
