Vacuum PVC covered steel flexible conduit for industry wiring installation
It is suitable for use in both static applications where a tight bend diameter is needed and in dynamic use such as machining centers and robotics.
Water-tight Flexible Metal Conduit
Vacuum jacketed steel conduit for high-flex installations.(VJC)
*Galvanized steel strip core (square locked or interlocked) *PVC Covered
*1/4"~4" trade size *Water-tight
A unique vacuum extrusion process allows this product to have a thin PVC jacket which does not restrict the great flexibility characteristics of the inner core.
Flexible metallic conduit with PVC jacket:
*PVC jacket provides water resistant.
*Durable and long life.
*Inner core made from galvanized steel strip.
*Square locked construction for more flexibility or interlocked for more strength.
Applications:
Appliances, automotive wire & cable sleeving, industrial equipments,
medical devices, machineries, wire conduits, air conditioning/heating and ventilation
http://www.delikon.com
http://www.semiconduits.com
http://users4.nofeehost.com/delikon
<p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/YF-707.gif" alt="PVC jacketed flexible steel conduits">
