Delikon Electrical Flexible Conduit & Fittings Co., Ltd.
  • Optical Fiber Protection Flexible metal conduit
  • 发布时间:2007/6/11 1:56:40   修改时间:2007/6/11 1:56:40 浏览次数:1303
     Flexible stainless steel conduit,for protection of instrument wirings
    Flexible Metallic Conduit ( AT ) *Stainless steel strip (square locked or interlocked), very flexible *Corrosion Resistant *EMI Shielding *Most suitable for instrument wiring protections.
    Flexible Stainless Steel Conduit: Type AT is an ultra-flexible, stainless steel conduit designed primarily for OEM applications. A typical application would be armouring in specialty sensing devices, or medical equipment, including fiber-optics.
    SMALL BORE HOSE,Instrumentation tubing,Flexible stainless steel conduit
    Delikon manufactures unique tubing that is relied on in numerous industries. The tubing is produced by helical coiling of a cold-rolled metal strip onto a spindle, with the helical coils being linked with each other by means of a special type of strip profile. Basic materials for the strip are stainless steel or galvanized steel strip. However, other metals are also available.
    Applications:
    Instrumentation tubing is used by manufacturers of various industries, such as Process & Control Instrumentation, Measuring & Controlling Devices, Analytical Instruments, Medical Instruments and many others with specific applications including temperature measuring, wiring conduit or armor cable and protective casing.
    Instrumentation tubing is made in two configurations, or constructions, commonly called SquareLok and InterLok, and is often abbreviated as SL and FI.
    http://www.delikon.com
我司专业制造电线保护软管及接头: 1)金属软管 2)防水金属软管,接头,包塑金属软管 3)防爆电线保护软管:防水,防爆,耐磨损,抗干扰 主要用于: 机械设备电线保护; 仪器仪表电线保护; 汽车轮船电线保护. 工厂商业电线保护. ======================= http://www.del…  更多>>
联系人:delikon
地址:http://www.delikon.com
邮编:216000
电话:21_000000000
传真:_
公司网址:http://www.delikon.com
  • Craig PAN 在2023/7/3 16:12:00留言
  • 详细留言:关于贵司 YF-90604 Delikon 1/2" Reel 样品信息
