Delikon Electrical Flexible Conduit & Fittings Co., Ltd.
  • Liquidtight Flexible Steel Conduit
  • 发布时间:2007/6/11 19:05:16   修改时间:2007/6/11 19:05:16 浏览次数:1533
    Liquid Tight Flexible PVC Coated Galvanised steel Conduit
    Color Liquid-Tight Connectors
    for more professional cable managements.
    Machine grey LIQUIDTIGHT Flexible metallic conduits
    Liquidtight Flexible Conduits and NEW ALUMINUM connectors
    Liquid-Tight Flexible Metal Conduit (LFMC)
    ( Protecting wiring in wet locations )
    Liquid-tight conduit is ideal when used with liquid-tight fittings for applications where a high degree of liquid tightness is required.  This product is suitable for a number of general purpose wiring applications and ideal for environments with lots of water, coolant, and vibrations such as machine tool workshops.
    Aluminum Liquid-tight Connectors
     This new line of connectors are made of high-quality forged aluminum for superior strength and durability. These unique configurations work perfectly with our whole range of flexible conduits and hoses. All forged connectors feature:
    * All aluminum construction
    * Totally re-useable
    * Unique taper design for simple assembly and superior water tightness.
    * Fixed or swivel type.
    http://www.delikon.com
    Flexible, sleek, with increased IP ratings, Liquid-tight flexible metallic conduit (LFMC) is suitable for use in a variety of environments and applications from general purpose wiring in wet or damp locations, to direct burial and in concrete embedment, to raised computer room floors and site lighting jobs.
我司专业制造电线保护软管及接头: 1)金属软管 2)防水金属软管,接头,包塑金属软管 3)防爆电线保护软管:防水,防爆,耐磨损,抗干扰 主要用于: 机械设备电线保护; 仪器仪表电线保护; 汽车轮船电线保护. 工厂商业电线保护. ======================= http://www.del…  更多>>
联系人:delikon
地址:http://www.delikon.com
邮编:216000
电话:21_000000000
传真:_
公司网址:http://www.delikon.com
  • Craig PAN 在2023/7/3 16:12:00留言
  • 详细留言:关于贵司 YF-90604 Delikon 1/2" Reel 样品信息
