DELIKON Protective overBraided Flexible Conduit Systems protect cables from damage by welding sparkBraided Flexible Conduit Systems offer protection against hot chips; High tensile strength; Highly compression resistance; Flexible; For heavy mechanical stress. Application includes: Mechanical engineering, Plant engineering and construction, Outdoors application, Everywhere where cables and wires could be damaged by welding sparkles or hot chips.
Braided Flexible Steel Conduit,Aluminum Connector for rolling mill cables protectionOver Braided Flexible Conduit system specially designed for cables protections in steel mills, glass works and electric furnaces, resists hot metal splashes.MODEL: SM-70001Overbraided Flexible Steel Conduit For High Temperature WiringInherently low fire hazard (ILFH), Braided Flexible Metal Conduit is widely used to counter mechanical stress and is highly flexible, and it is resistant against tensile stresses and transverse pressure. This conduit also offers excellent protection to cables against hot metal particles, and immunity from electromagnetic interference. Most suitable for use in Hazardous Locations, industrial environments and high temperatures.MODEL: YF-704Clean data transmission in a noisy environment is an ever increasing requirement on todays crowded factory floors. Braided flexible steel conduit systems provide excellent EMI and RFI shielding, as well as mechanical protection, resulting in improved data transmission for factory automations.
=======================http://www.delikon.comhttp://users4.nofeehost.com/delikon=======================<p align="center"><a href="http://www.delikon.com/smill.htm"><img border="0" src="http://www.delikon.com/images/ironml1.jpg" alt="Braided Flexible Steel Conduit,Aluminum Connector for steel mill cables protection">
联系人:delikon
地址:http://www.delikon.com
邮编:216000
电话:21_000000000
传真:_
公司网址:http://www.delikon.com
