Delikon Electrical Flexible Conduit & Fittings Co., Ltd.
  • Liquid tight conduit LIQUID TIGHT fittings liquid tight connector for ship and train
  • 发布时间:2012/11/8 19:29:28   修改时间:2012/11/8 19:29:28 浏览次数:1653
    Liquid tight conduit LIQUID TIGHT fittings liquid tight connector for ship and train buildig industry wiring
    electric liquidtight flexible metal conduit for transformer wirings
    Liquid-tight Conduit with smooth PVC jacket
    swivel Aluminum liquid tight connector for liquid tight flexible conduit,liquid tight conduit fittings
    LIQUID TIGHT Flexible Metal Conduit
    Flexible Metal Conduit, Liquid-tight
    Electric liquidtight flexible metallic conduit,connector,fittings
    electric Liquid Tight Flexible metal Conduit,LT metal conduit
    Liquidtight conduit and connector
    Liquidtight Flexible metal Conduit,connectors
    Liquid Tight Flexible PVC Coated metal Conduit
    Color Liquid-Tight Connectors
    for more professional cable managements.
    Machine grey LIQUIDTIGHT Flexible steel conduits
    DELIKON NEW PRODUCT release: Aluminum Liquid-tight Connector with higher IP rating for easy installation
    Liquidtight Flexible steel Conduits and NEW ALUMINUM connectors
    LiquidTight Flexible Metal Conduit LFMC CONDUITs
    ( Protecting wiring in wet locations )
    Liquid-tight conduit is ideal when used with liquid-tight fittings for applications where a high degree of liquid tightness is required.  This product is suitable for a number of general purpose wiring applications and ideal for environments with lots of water, coolant, and vibrations such as machine tool workshops.
    Aluminum Liquid-tight Connectors
     This new line of connectors are made of high-quality forged aluminum for superior strength and durability. These unique configurations work perfectly with our whole range of flexible conduits and hoses. All forged connectors feature:
    * All aluminum construction
    * Totally re-useable
    * Unique taper design for simple assembly and superior water tightness.
    * Fixed or swivel type.
    http://www.delikon.com
    http://users4.nofeehost.com/delikon
    Flexible, sleek, with increased IP ratings, Liquid-tight flexible metallic conduit (LFMC) is suitable for use in a variety of environments and applications from general purpose wiring in wet or damp locations, to direct burial and in concrete embedment, to raised computer room floors and site lighting jobs.
    <p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/liquid6.jpg" alt="Electric liquidtight flexible metallic conduits">
    <p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/greysys.jpg" alt="Electric liquidtight flexible metallic conduits">
    <p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/YF-706.gif" alt="Electric liquidtight flexible metallic conduits">
    <p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/al-cat.gif" alt="Aluminum Liquid-tight Connectors">
    <p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/ancon2.jpg" alt="Aluminum Liquid-tight Connectors">
    <p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/lt3.jpg" alt="Aluminum Liquid-tight Connectors">
    <p align="center"><a href="http://www.delikon.com/braids.htm"><img border="0" src="http://www.delikon.com/images/ship1.jpg" alt="For Ship building">
    <p align="center"><a href="http://www.delikon.com/greyliq.html"><img border="0" src="http://www.delikon.com/images/grey706l.jpg" alt="metal liquid tight conduit">
    PG METRIC NPT liquid tight metal connector,liquid tight conduit fittings,LT connector,LT fittings,LIQUID TIGHT CONDUIT
    conector recto hermetico,curvo 90
    Liquid-tight zinc die cast connectors
    Model: DMA,DMB
    Available in 3/8 inch to 4 inch trade size
    Zinc Die-cast construction
    For use with both Metallic Liquid tight Conduit and Nonmetallic Liquid tight Type B
    Resistant to outdoor weather conditions
    Liquidtight/Raintight/OilTight
    Suitable for wet locations
    Suitable for grounding (through 1-1/4")
    Locknut included
    <p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/dmb.gif" alt="Liquid-tight zinc die cast connectors">
我司专业制造电线保护软管及接头: 1)金属软管 2)防水金属软管,接头,包塑金属软管 3)防爆电线保护软管:防水,防爆,耐磨损,抗干扰 主要用于: 机械设备电线保护; 仪器仪表电线保护; 汽车轮船电线保护. 工厂商业电线保护. ======================= http://www.del…  更多>>
联系人:delikon
地址:http://www.delikon.com
邮编:216000
电话:21_000000000
传真:_
公司网址:http://www.delikon.com
  • Craig PAN 在2023/7/3 16:12:00留言
  • 详细留言:关于贵司 YF-90604 Delikon 1/2" Reel 样品信息
