Delikon Electrical Flexible Conduit & Fittings Co., Ltd.
  • Liquid tight steel Conduit WITH INTEGRAL COPPER BONDING WIRE
  • 发布时间:2013/2/18 21:14:32   修改时间:2013/2/18 21:14:32 浏览次数:1595
  • Computer Blue Liquid tight steel Conduit WITH INTEGRAL COPPER BONDING WIRE
    ( YF-604 )
    Computer Blue is a liquid-tight flexible steel conduit commonly used for computer room installations. The blue jacket color easily identifies circuitry for computer power wiring. It has a flexible inner core made from a spiral wound strip of heavy gauge, electro-galvanized steel. It contains an integral copper bonding wire.
    Applications:
    Liquid-tight flexible conduit provides protection for wiring circuits located in extremely wet or damp areas. This computer BLUE is especially suitable for wirings in computer rooms.
    This conduit is intended for:
        -For use in exposed or concealed locations.
        -Installations under raised floors in Data Processing Areas.
        -Direct burial and in poured concrete.
    http://www.delikon.com
    <p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/blue-1.gif" alt="Liquidtight flexible steel conduit">
    <p align="center"><a href="http://www.delikon.com/d7.html"><img border="0" src="http://www.delikon.com/images/706nl1.jpg" alt="DELIKON BIG metal liquid tight conduit for water treatment plant and railway wiring">
我司专业制造电线保护软管及接头: 1)金属软管 2)防水金属软管,接头,包塑金属软管 3)防爆电线保护软管:防水,防爆,耐磨损,抗干扰 主要用于: 机械设备电线保护; 仪器仪表电线保护; 汽车轮船电线保护. 工厂商业电线保护. ======================= http://www.del…  更多>>
联系人:delikon
地址:http://www.delikon.com
邮编:216000
电话:21_000000000
传真:_
公司网址:http://www.delikon.com
  • Craig PAN 在2023/7/3 16:12:00留言
  • 详细留言:关于贵司 YF-90604 Delikon 1/2" Reel 样品信息
