Delikon Electrical Flexible Conduit & Fittings Co., Ltd.
  • Emi shield over Braided Flexible Conduit for Variable frequency drive cable
  • 发布时间:2013/8/21 22:56:46   修改时间:2013/8/21 22:56:46 浏览次数:2266
    Emi shield over Braided Flexible Conduit for Variable frequency drive cable (VFD)
    Braided-shield flexible conduit provids excellent Radio Frequency,as well as mechanical protection to the wirings and cables.
    In environments such as airport or factory work shop, where higher than normal levels of electromagnetic radiation are present, power or data systems could be vulnerable to Electro Magnetic Interference (EMI). Delikon Over Braided Flexible Conduit has been designed to protect cables from EMI.
    EMI Shielding over braided flexible conduit provides exceptional shielding effectiveness from electromagnetic and radio frequency interference (EMI/RFI). Use it to protect sensitive electronic circuits from outside noise in such applications as communications, radar and data transmission. Shielded flexible conduit does not just keep interference out; it also keeps emissions in, which is vital to meeting EU standards.
    Shielding flexible conduit shields sensitive equipment and circuits from EMI/RFI emissions; both ingress and egress. Connector assemblies include a grounding ferrule that contacts the conduit internal metallic material with the connector body, producing a direct shield-to-drain (ground) simply by tightening the connector. Its flexibility and simple assembly means it takes less time to install.
    Over Braided Flexible Conduit is most suitable for installations in demanding industry environments, thereby giving increased protection to your critical power and data cabling
    Applications :
    Air handling equipment (HVAC)
    Test & Measurement Equipment
    Data Centers
    Radio Broadband/Antenna
    Solar / Wind Energy  Variable-frequency drive (VFD)
    Ship Building
    Medical Diagnostic Equipment
    Wireless Communications
    Healthcare / Medical
    http://www.delikon.com
    http://www.semiconduits.com
    <p align="center"><a href="http://www.delikon.com/shieldb3.htm"><img border="0" src="http://www.delikon.com/images/emisc3.jpg" alt="Electromagnetic Shielding Over Braided Flexible Conduit">
我司专业制造电线保护软管及接头: 1)金属软管 2)防水金属软管,接头,包塑金属软管 3)防爆电线保护软管:防水,防爆,耐磨损,抗干扰 主要用于: 机械设备电线保护; 仪器仪表电线保护; 汽车轮船电线保护. 工厂商业电线保护. ======================= http://www.del…  更多>>
联系人:delikon
地址:http://www.delikon.com
邮编:216000
电话:21_000000000
传真:_
公司网址:http://www.delikon.com
  • Craig PAN 在2023/7/3 16:12:00留言
  • 详细留言:关于贵司 YF-90604 Delikon 1/2" Reel 样品信息
