F87R57减速机电机功率:F87R57Y0.12KW,F87R57Y0.18KW,F87R57Y0.25KW,F87R57Y0.37KW,F87R57Y0.55KW,F87R57Y0.75KW,F87R57Y1.1KW,F87R57Y1.5KW(可配http://www.bosiii.com/product/f87r57jiansuji-cn.html变频电机,刹车电机,防爆电机,伺服电机,交流电机,直流电机,三相电机,单相电机)。
F87R57减速机减速比:249比,300比,345比,452比,515比,609比,674比,780比,887比,1010比,1148比,1300比,1493比,1709比,1930比,2199比,2576比,2881比,3244比,3721比,4245比。
F87R57减速机输出转数:0.33转,0.37转,0.43转,0.48转,0.51转,0.54转,0.6转,0.63转,0.67转,0.68转,0.72转,0.76转,0.77转,0.81转,0.87转,0.88转,0.92转,1转,1.1转,1.2转,1.3转,1.4转,1.5转,1.6转,1.7转,1.8转,1.9转,2转,2.1转,2.3转,2.4转,2.7转,2.8转,3转,3.1转,3.2转,4转,4.1转,4.2转,4.7转,4.8转,5.7转(以上http://www.bosiii.com/product/list-pingxingzhoujiansuji-cn.html转数均为四级电机算出的,可用两级电机,六级电机计算,也可以用变频电机调速)
F87R57减速机输出扭矩:745N.m,820N.m,830N.m,970N.m,1020N.m,1030N.m,1040N.m,1080N.m,1150N.m,1160N.m,1170N.m,1230N.m,1250N.m,1300N.m,1370N.m,1390N.m,1410N.m,1500N.m,1510N.m,1540N.m,1550N.m,1590N.m,1670N.m,1690N.m,1760N.m,1780N.m,1830N.m,1930N.m,1990N.m,2010N.m,2050N.m,2080N.m,2160N.m,2210N.m,2240N.m,2280N.m,2290N.m,2320N.m,2330N.m,2440N.m,2490N.m,2610N.m,2670N.m,2760N.m,2790N.m,2920N.m,2930N.m,3040N.m,3050N.m,3080N.m,3130N.m(以上http://www.bosiii.com/product/list-fxiliejiansuji-cn.html扭矩均为四级电机得出扭矩,需要比上面更大的扭矩,可把电机功率加大,型号加大,或者两个组合使用)
F87R57减速机安装尺寸:输出轴Φ60+键4(可定做),高531*宽330*长561(带输出轴)
F87R57减速机电机型号:F87R57DM63L4,F87R57DM63M4,F87R57DM63MS4,F87R57DM63S4,F87R57DM71D4,F87R57DM71M4,F87R57DM71MS4,F87R57DM71S4,F87R57DM80K4,F87R57DM80M4,F87R57DM80MK4,F87R57DM80N4,F87R57DM80S4,F87R57DM90L4,F87R57DM90M4,F87R57DM90S4,F87R57DR63L4,F87R57DR63M4,F87R57DR63MS4,F87R57DR63S4,F87R57DR71D4,F87R57DR71M4,F87R57DR71MS4,F87R57DR71S4,F87R57DR80K4,F87R57DR80M4,F87R57DR80MK4,F87R57DR80N4,F87R57DR80S4,F87R57DR90L4,F87R57DR90M4,F87R57DR90S4,F87R57DRE63L4,F87R57DRE63M4,F87R57DRE63MS4,F87R57DRE63S4,F87R57DRE71D4,F87R57DRE71M4,F87R57DRE71MS4,F87R57DRE71S4,F87R57DRE80K4,F87R57DRE80M4,F87R57DRE80MK4,F87R57DRE80N4,F87R57DRE80S4,F87R57DRE90L4,F87R57DRE90M4,F87R57DRE90S4,F87R57DRN63L4,F87R57DRN63M4,F87R57DRN63MS4,F87R57DRN63S4,F87R57DRN71D4,F87R57DRN71M4,F87R57DRN71MS4,F87R57DRN71S4,F87R57DRN80K4,F87R57DRN80M4,F87R57DRN80MK4,F87R57DRN80N4,F87R57DRN80S4,F87R57DRN90L4,F87R57DRN90M4,F87R57DRN90S4,F87R57DRS63L4,F87R57DRS63M4,F87R57DRS63MS4,F87R57DRS63S4,F87R57DRS71D4,F87R57DRS71M4,F87R57DRS71MS4,F87R57DRS71S4,F87R57DRS80K4,F87R57DRS80M4,F87R57DRS80MK4,F87R57DRS80N4,F87R57DRS80S4,F87R57DRS90L4,F87R57DRS90M4,F87R57DRS90S4,F87R57DT63L4,F87R57DT63M4,F87R57DT63MS4,F87R57DT63S4,F87R57DT71D4,F87R57DT71M4,F87R57DT71MS4,F87R57DT71S4,F87R57DT80K4,F87R57DT80M4,F87R57DT80MK4,F87R57DT80N4,F87R57DT80S4,F87R57DT90L4,F87R57DT90M4,F87R57DT90S4,F87R57DV63L4,F87R57DV63M4,F87R57DV63MS4,F87R57DV63S4,F87R57DV71D4,F87R57DV71M4,F87R57DV71MS4,F87R57DV71S4,F87R57DV80K4,F87R57DV80M4,F87R57DV80MK4,F87R57DV80N4,F87R57DV80S4,F87R57DV90L4,F87R57DV90M4,F87R57DV90S4,F87R57DVE63L4,F87R57DVE63M4,F87R57DVE63MS4,F87R57DVE63S4,F87R57DVE71D4,F87R57DVE71M4,F87R57DVE71MS4,F87R57DVE71S4,F87R57DVE80K4,F87R57DVE80M4,F87R57DVE80MK4,F87R57DVE80N4,F87R57DVE80S4,F87R57DVE90L4,F87R57DVE90M4,F87R57DVE90S4,F87R57Y63M4,F87R57Y71M4,F87R57Y80M4,F87R57Y90M4,F87RF57Y63M4,F87RF57Y71M4,F87RF57Y80M4,F87RF57Y90M4。
