湖南斯罗克电气有限公司
  • MICROLOGIX 美国AB小型PLC总代理
  • 发布时间:2010/12/8 8:56:48   修改时间:2010/12/8 8:56:48 浏览次数:2442
  • 专业代理销售美国罗克韦尔A-B  MICROLOGIX1000/1200/1500 1761、1762、1764小型PLC,价格优惠、大量现货
    马亮    直拨:010-60139171、13466699506
    1762-L24AWA MICROLOGIX 1200, 24 PT.
    1762-L24AWAR ML1200 24AC/RLY/AC 2 PORT
    1762-L24BWA MICROLOGIX 1200, 24 PT.
    1762-L24BWAR ML1200 24DC/RLY/AC 2 PORT
    1762-L24BXB MICROLOGIX 1200, 24 PT.
    1762-L24BXBR ML1200 24DC/DC&RLY/DC 2PT
    1762-L40AWA MICROLOGIX 1200, 40 PT.
    1762-L40AWAR ML1200 40AC/RLY/AC 2 PORT
    1762-L40BWA MICROLOGIX 1200, 40 PT.
    1762-L40BWAR ML1200 40DC/RLY/AC 2 PORT
    1762-L40BXB MICROLOGIX 1200, 40 PT.
    1762-L40BXBR ML1200 40DC/DC&RLY/DC 2PT
    1762-MM1 MEMORY MODULE
    1762-MM1RTC MEMORY MODULE WITH RTC
    1762-IA8 8 POINT 120 VAC INPUT MODULE
    1762-IQ16 16 POINT 24 VDC SINK/SOURCE INPUT MODULE
    1762-IQ8 8 POINT 24 VDC SINK/SOURCE INPUT MODULE
    1762-OA8 8 POINT 120/240 VAC OUTPUT MODULE
    1762-OB16 16 POINT 24 VDC SOURCE OUTPUT MODULE
    1762-OB8 8 POINT 24 VDC SOURCE OUTPUT
    1762-OW16 16 POINT VAC/VDC RELAY OUTPUT MODULE
    1762-OW8 8 POINT VAC/VDC RELAY OUTPUT MODULE
    1762-OX6I 6CH ISOLATED HIGH CURRENT
    1762-IF2OF2 4 CHANNEL ANALOG COMBO MODULE
    1762-IF4 4 CHANNEL CURRENT/VOLTAGE ANALOG INPUT MODULE
    1762-IR4 4 CHANNEL, RTD/RESISTANCE MODULE
    1762-IT4 4 CHANNEL, THERMOCOUPLE/MILLIVOLT MODULE
    1762-OF4 4 CH ANALOG OUTPUT MODULE
    1761-NET-ENI ETHERNET INTERFACE FOR MICROLOGIX AND COMPACTLOGIX
    1761-NET-ENIW ETHERNET INTERFACE W/WEB FOR MICROCONTROLLER
    1762-RTC REAL TIME CLOCK
    D1762-RM001CENP MICROLOGIX 1200&1500 INSTR.SET REFERENCE MAN.
    D1762-RM001EENP MICROLOGIX 1200 AND 1500 INSTR. SET REF. MANUAL
    D1762-UM001BENP MICROLOGIX 1200 PROG. CONTROLLER USER MAN.
    1762-RPLDIN2 REPLACEMENT DIN LATCHES FOR 1762 I/O
    1762-RPLDR2 REPLACEMENT DOOR KIT FOR 1762 I/O
    1762-RPLRTB40 REPLACEMENT,40 PT TERM BLOCK FOR MICROCONTROLLER
    1762-RPLTLBL2 REPLACEMENT LABELS FOR 1762 I/O MODULES
    1764-LRP ML 1500 RS-232 PROCESSOR
    1764-LSP MICROLOGIX 1500 STANDARD PROCESSOR UNIT
    1764-MM1 MICROLOGIX 1500 MEMORY MODULE
    1764-MM1RTC MICROLOGIX 1500 MEMORY MODULE WITH REAL TIME CLOCK
    1764-MM2 MICROLOGIX 1500 16K MEMORY MODULE
    1764-MM2RTC MICROLOGIX 1500 16K MEM MOD W/RTC
    1764-24AWA ML 1500 BASE 120V AC IN / RELAY OUT / AC POWER
    1764-24BWA ML 1500 BASE 24V DC IN / RELAY OUT / AC POWER
    1764-28BXB ML 1500 BASE DC IN / DC FET & RELAY OUT / DC POWER
    1769-ADN 1769 COMPACT I/O DEVICENET ADAPTER
    1769-IA16 16 POINT 120 VAC INPUT MODULE
    1769-IA8I 8 POINT 120 VAC INDIVIDUALLY ISOLATED INPUT MODULE
    1769-IM12 12 POINT 240 VAC INPUT MODULE
    1769-IQ16 16 POINT 24 VDC SINKING/SOURCING INPUT MODULE
    1769-IQ16F 1769 16 POINT HIGH SPEED 24VDC INPUT MODULE
    1769-IQ32 1769 32 POINT 24VDC INPUT MODULE
    1769-IQ6XOW4 COMBO 6PT 24 VDC SNK/SRC IN, 4PT VAC/VDC RELAY OUT
    1769-OA16 16PT.120/240 VAC OUTPUT
    1769-OA8 8 POINT 120/240 VAC OUTPUT MODULE
    1769-OB16 16 POINT 24 VDC SOURCING OUTPUT MODULE
    1769-OB16P 16 PT. 24 VDC ELECTRONICALLY FUSED SOURCING OUTPUT
    1769-OB32 1769 32 POINT 24VDC OUTPUT MODULE
    1769-OB8 1769 8 POINT HIGH POWER 24VDC OUTPUT MODULE
    1769-OV16 16 POINT 24 VDC SINKING OUTPUT MODULE
    1769-OW16 16 PT.AC/DC RELAY OUTPUT
    1769-OW8 8 POINT VAC/VDC RELAY OUTPUT MODULE
    1769-OW8I 8 PT. VAC/VDC INDIV. ISOLATED RELAY OUTPUT MODULE
    1769-IF4 4 CHANNNEL ANALOG CURRENT/VOLTAGE INPUT MODULE
    1769-IF4XOF2 8 BIT RESOLUTION, HIGH SPEED 4 IN/2 OUT ANLG. COMB
    1769-IF8 8 CHANNEL ANALOG VOLTAGE/CURRENT INPUT MODULE
    1769-IR6 6 CHANNEL RTD/RESISTANCE INPUT MODULE
    1769-IT6 6 CHANNEL THERMOCOUPLE/MILLIVOLT INPUT MODULE
    1769-OF2 2 CHANNEL ANALOG CURRENT/VOLTAGE OUTPUT MODULE
    1769-OF8C 8 CHANNEL ANALOG CURRENT OUTPUT MODULE
    1769-OF8V 8 CHANNEL ANALOG VOLTAGE OUTPUT MODULE
    1769-HSC 2/4 CHANNEL HIGH SPEED COUNTER/ENCODER MODULE
    1764-RPLTB1 REMOVABLE TERMINAL BLOCK KIT (17 PT)
    1764-RPLTB2 REMOVABLE TERMINAL BLOCK KIT (21 PT)
    1761-NET-DNI DEVICENET INTERFACE (DNI)
    1769-SDN DEVICENET SCANNER FOR 1764 AND 1769 CONTROLLERS
    1761-NET-AIC AIC+ ADVANCED INTERFACE CONVERTER
    1769-CRL1 1 FT (305 MM) RIGHT-TO-LEFT BUS EXPANSION CABLE
    1769-CRR3 3.28 FT (1 M) RIGHT-TO-RIGHT BUS EXPANSION CABLE
    1769-PA2 PWR SUPPLY 120/240 VAC INPUT 2 AMP @ 5 VDC OUTPUT
    1769-PA4 120/240 VAC INPT. PWR SUPPLY 4A @ 5VDC, 2A @ 24VDC
    1769-PB2 PWR SUPPLY 24 VDC INPUT 2 AMP @ 5 VDC OUTPUT
    1769-PB4 24VDC INPUT P0WER SUPPLY: 4A @ 5VDC 2A @ 24VDC
    1764-DAT DATA ACCESS TOOL
    1764-RTC MICROLOGIX 1500 REAL TIME CLOCK
    1769-ECL LEFT END CAP/TERMINATOR
    1769-ECR RIGHT END CAP/TERMINATOR
    9399-RL50GR RSLOGIX 500 GETTING RESULTS GUIDE
    9399-RL50GRDE RSLOGIX 500 GETTING RESULTS GUIDE (GERMAN)
    9399-RL50GRES RSLOGIX 500 GETTING RESULTS GUIDE (SPANISH)
    9399-RL50GRFR RSLOGIX 500 GETTING RESULTS GUIDE (FRENCH)
    9399-RL50GRIT RSLOGIX 500 GETTING RESULTS GUIDE (ITALIAN)
    9399-RL50GRPT RSLOGIX 500 GETTING RESULTS GUIDE (PORTUGUESE)
    D1761-6.4 AIC + ADVANCED INTERFACE CONVERTER USER MANUAL
    D1764-UM001AUSP MICROLOGIX 1500 PROG. CONTROLLER USER MANUAL
    1764-RPLCDR1 PROCESSOR DOOR REPLACEMENT KIT
    1769-RD REPLACEMENT 1769 I/O TERMINAL DOORS
    1769-RL1 REPLACEMENT DOOR LABELS FOR DISC. I/O (2 PER KIT)
    1769-RL2 REPLACEMENT DOOR LABELS FOR SPEC. I/O (2 PER KIT)
    1769-RTBN10 REPLACEMENT 10 PIN NEMA TERMINAL BLOCK (1 PER KIT)
    1769-RTBN18 REPLACEMENT 18 PIN NEMA TERMINAL BLOCK (1 PER KIT)
“湖南斯罗克电气有限公司”是一家具有独立法人资格的高新技术企业,公司凭借雄厚的技术力量和专业的销售队伍创造了骄人的业绩。我公司为“ROCKWELL——罗克韦尔(AB)”中国华北地区的特许经销商,和AB公司有着多年的良好合作关系,价格优惠、…  更多>>
湖南斯罗克电气有限公司
联系人:马亮
地址:北京市大兴工业区金辅路2号凯驰大厦C310
邮编:102600
电话:13466699506
公司网址:
  • jeffrey tan 在2024/12/10 22:19:00留言
  • 留言类型:得到贵公司产品的价格信息,贵公司技术支持人员联系我,
  • 详细留言:你好, 请报价060g3928 x 2 个
  • 孙先生 在2022/7/2 9:40:00留言
  • 详细留言:有型号,需要报价,也需要知道对应型号的参数
  • Aly Chiman 在2018/6/28 8:15:00留言
  • 详细留言:Hello there, My name is Aly and I would like to know if you would have any interest to promote your website here at cechina.cn on our blog alychidesigns.com ? I am looking for people/businesses that would like to contribute promotional or helpful articles to our blog. If you are willing to post on our site, we would post an promotional link within the article as well as an (optional) author link. If you may be interested please let me know. Thanks, Aly
  • 王力 在2015/3/17 10:59:00留言
  • 楼琦 在2012/10/24 14:32:00留言
  • 详细留言:贵司是否提供现场培训服务。 我们是卡博特蓝星化工(江西)有限公司 地处江西省九江市。 或者是否知道我们最近的AB代理商信息
