系统 |
Atmel ARM AT91RM9200 180 MHz | |
10/100 Based-Tx RJ-45接头x2 | |
RS232/422/485 x2 (RJ45接头) | |
USB flash, wireless dongle | |
Link/Activity x2 (绿灯亮/绿灯闪烁) Full Duplex/ Collision x2 (橙灯亮/橙灯闪烁) | |
Power On/off x2 (绿灯亮/灭) SD card x1 (绿灯亮/灭) | |
超过一个time-out时长,系统自动重启,默认为1sec | |
Single input 5.4W at 12V, 6.72W at 48V Dual inputs 5.28W at 12V, 7.2W at 48V | |
机械规格 |
66(D) x149(H) x 120.5(W) mm | |
工作环境 |
-40 ~ 176℉(-40 ~ 80℃), 5 ~ 95% RH | |
FCC class A, CE EN55022 class A EN55024 EN61000-3-2, 3 EN61000-4-2, 3, 4, 5, 6, 8, 11 | |
IEC60068-2-27 (50g peak 加速度) | |
IEC60068-2-6 (5g/ 10~150Hz/operating) IEC61373 (Random/ 5~150Hz/ operating) | |
嵌入式Linux |
JFFS2, NFS, Ext2, Ext3, VFAT, FAT | |
SD card, USB, Watchdog timer, UART, Ethernet | |
ARP, PPP, CHAP, IPv4, PAP, ICMP, TCP, UDP, NFS | |
busybox (telnetd, inetd, udhcp), microcom, setserial, bridge-utils, ethtool, iptables, net-snmp, ntp, openssh, openssl, pppd, ftpd, rp-pppoe, smtpclient, syslogd, goahead web server Korenix Linux auto-run功能 客制化设置 过程监控 | |
串口界面 |
LAN界面 |
10/100 Based-Tx RJ-45接头x2(冗余),自适应 MDI/MDI-X | |
网管及安全 |
SDK |
Gcc (C/C++ PC 交叉编译), uClibc, libstdc++ Linux示例代码 | |
