北京因科思国际贸易有限公司
  • LS200, LS200N, LS200NDVOR Series and L1100 Liquid Level Switches
  • 发布时间:2008/12/4 15:39:02   修改时间:2008/12/4 15:39:02 浏览次数:1789
  • LS200, LS200N, LS200NDVOR Series and L1100 Liquid Level Switches液位开关
    LS200 Liquid Level Switches with 2” NPT mounting are float activated to operate an electrical SPDT snap switch (optional DPDT on some models) for alarm or shutdown of an engine or electric motor. The LS200 connects directly into the vessel wall and can be used with a weld collar (P/N 15050375) or Murphy
    external float chamber. L1100 models (1-1/2” NPT) are also available.
    Features:
        * Designed for harsh gas compressor scrubber applications
        * 304 stainless steel float operates in 0.5 specific gravity and heavier fluids
        * LS200 series rated for 2000 psi (13.8 MPa) [138 bar] working pressure
        * Electric and pneumatic models available
        * Improved design provides better snap action and dependability with reduced number of moving parts
        * All models screw directly into the vessel or can be mounted via external float chamber
        * Nickel plated body to provide enhanced corrosion protection
        * Improved float connection thread design provides a more secure connection
        * Listed for Class I, Div. 1, Grp. C & D locations
        * Canadian Registration Number OF1476.2
北京因科思国际贸易有限公司是经中华人民共和国商务部批准成立的拥有自营进出口权的外贸企业。专业化从事工程机械、仪表、阀门、开关及工业控制产品的销售与服务。 经过多年的专业运作,我公司已与多家世界知名制造商建立了紧密的合作关系。同时…  更多>>
北京因科思国际贸易有限公司
联系人:杨健
地址:北京市朝阳区胜古中路2号金基业大厦201室
邮编:100029
电话:010-84282935,13910122694
传真:010-84288762
公司网址:http://www.increaseinc.cn
  • 吴文峰 在2018/12/3 9:57:00留言
  • 详细留言:argus球阀询价
  • 王力 在2014/12/15 17:53:00留言
  • 王建立 在2014/5/14 10:57:00留言
  • 详细留言:压力表 型号:25-1009-SW02L-1.6MPa ,品牌:Ashcroft
  • 尹先生 在2013/2/17 15:22:00留言
  • 详细留言:询: 原装进口罗茨风机真空泵 型号:16V-RA1-1 要求最大真空度50.8KPaV 真空量大于750mm3/h 能匹配15马力电机和SE-15型消音罩
