易格斯(上海)拖链系统有限公司
  • 易格斯triflex R,“方便型”设计,易于装填电缆及管线-TRE.60
  • 发布时间:2021/2/20 8:49:34   修改时间:2021/2/20 8:49:34 浏览次数:1736
  •   System triflex R TRE.B
      1. multidimensionally movable - high flexibility for complicated movements even in the 6th axis. Twisting of approx. ± 10° per chain link possible in the longitudinal axis. This supports guiding of the cables around difficult geometries.
      2. high tensile force absorption due to special "trailer principle" (= principle ball / ball socket), means smooth movements in all axes
      3. simple opening principle - for easy filling and replacement of pre-assembled lines or media hoses
      4. excellent mechanical properties
      5. small bending radii and small pitch - for space-saving installation
      6. easy assembly and disassembly possible - one injection-moulded part, thus little assembly effort. No supporting elements (e.g. steel cables, spring balancers, etc.) required along the tensile force
      7. high stability - due to external stops, clear stops for radius and torsion
      8. minimise set-up times through simplest connection and intelligent accessories to your machine/robot.
      Possible applications:
      When to use the TRE.B series:
      ●When an easy-to-fill 3D chain is desired.
      ●When a safe energy supply system is required for multi-axis (3-D) movements
      ●When a high torsional capacity is required
      ●When the system should be easy to shorten and lengthen
      ●When a small bending radius is required
      ●When high tensile strength is important
      When not to use Series TRE.30
      ●For circular movements with high loads
      ●System twisterchain
      ●When a completely closed version is required
      ●System triflex R TRC
      ●When a more cost-effective, less demanding 3D solution is desire
      ●System triflex R TRL
易格斯(上海)拖链系统有限公司
联系人:黄小姐
地址:上海市奉贤区环城北路50号
邮编:201401
电话:021-80366382
传真:021-80366116
公司网址:http://www.igus.com.cn/
  • 廖小姐 在2025/5/15 8:40:00留言
  • 详细留言:需要无尘拖链生产设备
  • 王涛 在2025/4/21 10:47:00留言
  • 详细留言:K型热电偶补偿导线过拖链
  • 汪樱 在2025/2/7 11:25:00留言
  • 王佳璐 在2024/11/4 11:40:00留言
  • 周小姐 在2024/10/8 13:10:00留言
